I am trying to use the PCIe hot-plugging functionality with a broadcom wireless card.
I uses the GPIO pin gpio-250 (pcie_hotplug_detect ) for the hotplug detection. I have changed the dts file accordingly and /sys/kernel/debug/gpio shows that gpio-250 is available for the hotplug detection. My use case is as follows.
Boot TK1 with the Broadcom PCie card connected, the card got probed and the lspci output as below.
root@apalis-tk1:~# lspci
00:00.0 PCI bridge: NVIDIA Corporation TegraK1 PCIe x4 Bridge (rev a1)
01:00.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev ab)
02:01.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev ab)
02:02.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev ab)
02:03.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev ab)
04:00.0 Network controller: Broadcom Corporation Device 4355 (rev 05)
06:00.0 PCI bridge: NVIDIA Corporation TegraK1 PCIe x1 Bridge (rev a1)
07:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
I have loaded the broadcom driver, and unloaded it . Now I want to do a card disconnect. I switched the GPIO pin from low to high and the Pcie bus driver detects the interrupt and calls the hotplug handler and does pcie detach(drivers/pcie/host/pci-tegra.c). Now I removed the Broadcom pcie wireless card. Does lspci and it is working fine
[ 178.407857] work_hotplug_handler
[ 178.423972] PCIE Hotplug:DisConnected
[ 178.428458] PCIE Hotplug: DisConnected
gpio status is
gpio-250 (pcie_hotplug_detect ) in hi
Now I connect the card back to the pcie slot. set the GPIO to low, the bus driver detects the connection , does pci attach.
gpio status is
gpio-250 (pcie_hotplug_detect ) in lo
I am able to load the driver for the broadcom wireless card.lspci shows all the devices properly
So it is clear that PCie-hotplugging worked for the first round. So I repeated all the above steps. but this time I could see that on disconnection only the Intel Ethernet Gigabit Network controller got disconnected. Broadcom and the other PCI bridges still shows as connected.
[ 541.195440] work_hotplug_handler
[ 541.212234] PCIE Hotplug:DisConnected
[ 541.216597] PCIE Hotplug: DisConnected
[ 541.225337] igb 0000:07:00.0: removed PHC on enp7s0
root@apalis-tk1:~# cat /sys/kernel/debug/gpio
GPIOs 0-255, platform/6000d000.gpio, tegra-gpio:
gpio-63 (+V1.05_AVDD_HDMI_PLL) out lo
gpio-70 (temp_alert ) in hi
gpio-108 (VCC_USBO1 ) out lo
gpio-109 (VCC_USBH(2A|2C|2D|3|) out hi
gpio-111 (hdmi_hpd ) in hi
gpio-164 (RESET_MOCI_N ) out hi
gpio-171 (sdhci_cd ) in lo
gpio-221 (BKL1_ON ) out hi
gpio-233 (PEX_PERST_N ) out hi
gpio-235 (WAKE1_MICO ) in hi
GPIOs 1016-1023, platform/as3722-pinctrl, as3722-gpio, can sleep:
gpio-1018 (+V3.3 ) out hi
What could be the issue? Any advice would be greatly appreciated.
Pradeepkumar Soman
