I have an FPGA board that connects via an adapter cable to “X45” on the Apalis board.
If I load a driver that is supposed to “talk” to the FPGA, I see via dmesg that it has failed loading:
probe():probe(pdev = 0xa844f800, pci_id = 0x7f0b7470)
alloc_dev_instance():probe() lro = 0xa937d000
probe():pci_set_master()
probe_scan_for_msi():pci_enable_msi()
request_regions():pci_request_regions()
map_single_bar():BAR #0 is not present - skipping
map_single_bar():BAR #1 is not present - skipping
map_single_bar():BAR #2 is not present - skipping
map_single_bar():BAR #3 is not present - skipping
map_single_bar():BAR #4 is not present - skipping
map_single_bar():BAR #5 is not present - skipping
map_bars():Failed to detect XDMA config BAR
probe():probe() returning -1
I never saw an error like that - lspci does show that there is the FPGA card, but no BARs… The driver is freshly compiled against the exact Linux source, and the config from the runnig system.
The setup, thus far, had worked on another ARM board and an x86 system, it’s the first time I see this fail to load.
Here I found someone with the same error messages, but I don’t think it quote applies to the apalis board:
was placing the card on a VGA-only PCIe slot … so the host was identifying it as “Non-VGA unclassified device”
But perhaps this hints at me using the PCIe slot wrong, or the wrong slot, is there some jumper that I maybe need to set or some such?
EDIT:
In the linux config from the running iMX6 system, in /proc/config.gz, there is one occurence of CONFIG_PCI_IOV, and it is commented out, marked as “not set”.
Here a listing of differences between my x86 vs. imx6 kernel config with regards to anything “pci”: download
Here the lspci output of the x86_64 system, where the driver loaded successfully:
As attachment, as it’s even longer than the other one
Here comes some lspci output of the iMX6D. The card of interest would be the Xilinx one.
root@apalis-imx6:~# lspci -x
00:00.0 PCI bridge: Synopsys, Inc. Device abcd (rev 01)
00: c3 16 cd ab 47 05 10 00 01 00 04 06 10 00 01 00
10: 00 00 00 01 00 00 00 00 00 01 05 00 10 10 00 20
20: f0 ff 00 00 f0 ff 00 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 40 00 00 00 00 00 00 00 64 01 01 00
01:00.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev ab)
00: b5 10 05 86 45 05 10 00 ab 00 04 06 10 00 01 00
10: 00 00 00 00 00 00 00 00 01 02 05 00 11 11 00 00
20: f0 ff 00 00 f1 ff 01 00 00 00 00 00 00 00 00 00
02:01.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev ab)
10: 00 00 00 00 00 00 00 00 02 03 03 00 11 11 00 00
30: 00 00 00 00 40 00 00 00 00 00 00 00 65 01 01 00
02:02.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev ab)
00: b5 10 05 86 44 05 10 00 ab 00 04 06 10 00 01 00
10: 00 00 00 00 00 00 00 00 02 04 04 00 f1 01 00 00
30: 00 00 00 00 40 00 00 00 00 00 00 00 66 01 01 00
02:03.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev ab)
10: 00 00 00 00 00 00 00 00 02 05 05 00 f1 01 00 00
30: 00 00 00 00 40 00 00 00 00 00 00 00 15 01 01 00
04:00.0 RAM memory: Xilinx Corporation Device 7011
00: ee 10 11 70 40 01 10 00 00 00 00 05 10 00 00 00
10: 04 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00
20: 0c 00 00 00 00 00 00 00 00 00 00 00 ee 10 07 00
30: 00 00 00 00 40 00 00 00 00 00 00 00 66 01 00 00
root@apalis-imx6:~# lspci -vv
00:00.0 PCI bridge: Synopsys, Inc. Device abcd (rev 01) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 324
Region 0: Memory at 01000000 (32-bit, non-prefetchable) [size=1M]
Bus: primary=00, secondary=01, subordinate=05, sec-latency=0
I/O behind bridge: 00001000-00001fff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
[virtual] Expansion ROM at 01100000 [disabled] [size=64K]
BridgeCtl: Parity+ SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1+ D2- AuxCurrent=375mA PME(D0+,D1+,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable+ 64bit+
Address: 0000000038581000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] Express (v2) Root Port (Slot-), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag- RBE+
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <8us
ClockPM- Surprise- LLActRep+ BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR-, OBFF Not Supported ARIFwd-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Kernel driver in use: pcieport
01:00.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev ab) (prog-if 00 [Normal decode])
Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 325
Bus: primary=01, secondary=02, subordinate=05, sec-latency=0
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=55mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [48] MSI: Enable+ Count=1/4 Maskable+ 64bit+
Address: 0000000038581000 Data: 0001
Masking: 00000001 Pending: 00000000
Capabilities: [68] Express (v2) Upstream Port, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr+ TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; Disabled- CommClk-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Via message/WAKE#
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
Capabilities: [a4] Subsystem: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch
Capabilities: [100 v1] Device Serial Number ab-86-02-10-b5-df-0e-00
Capabilities: [fb4 v1] Advanced Error Reporting
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 1f, GenCap- CGenEn- ChkCap- ChkEn-
Capabilities: [138 v1] Power Budgeting <?>
Capabilities: [148 v1] Virtual Channel
Status: InProgress-
Arb: Fixed+ WRR32- WRR64- WRR128- TWRR128- WRR256-
Capabilities: [950 v1] Vendor Specific Information: ID=0001 Rev=0 Len=028 <?>
02:01.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev ab) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 326
Bus: primary=02, secondary=03, subordinate=03, sec-latency=0
Address: 0000000038581000 Data: 0002
Capabilities: [68] Express (v2) Downstream Port (Slot+), MSI 00
ExtTag- RBE+
LnkCap: Port #1, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
ClockPM- Surprise+ LLActRep+ BwNot+ ASPMOptComp+
LnkSta: Speed 2.5GT/s, Width x0, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise-
Slot #1, PowerLimit 25.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet- Interlock-
Changed: MRL- PresDet- LinkState-
DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Via message/WAKE# ARIFwd+
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -6dB
Status: InProgress-
Status: NegoPending+ InProgress-
Capabilities: [520 v1] Access Control Services
ACSCap: SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd+ EgressCtrl+ DirectTrans+
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
02:02.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev ab) (prog-if 00 [Normal decode])
Control: I/O- Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 327
Bus: primary=02, secondary=04, subordinate=04, sec-latency=0
Address: 0000000038581000 Data: 0003
ExtTag- RBE+
LnkCap: Port #2, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk- DLActive+ BWMgmt+ ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #2, PowerLimit 25.000W; Interlock- NoCompl-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet+ LinkState+
Status: InProgress-
02:03.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev ab) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 328
Bus: primary=02, secondary=05, subordinate=05, sec-latency=0
Address: 0000000038581000 Data: 0004
ExtTag- RBE+
LnkCap: Port #3, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
Slot #3, PowerLimit 25.000W; Interlock- NoCompl-
Status: InProgress-
Subsystem: Xilinx Corporation Device 0007
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 358
Region 0: Memory at <unassigned> (64-bit, non-prefetchable) [disabled]
Region 2: Memory at <unassigned> (64-bit, non-prefetchable) [disabled]
Region 4: Memory at <unassigned> (64-bit, prefetchable) [disabled]
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
Capabilities: [48] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [60] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <64ns, L1 unlimited
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 25.000W
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s, Exit Latency L0s unlimited, L1 unlimited
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range B, TimeoutDis-, LTR-, OBFF Not Supported
Capabilities: [100 v1] Device Serial Number 00-00-00-00-00-00-00-00
