I am trying to use an AVC8000 nano PCIe card on a Toradex Apalis-iMX6 reference board 1.1A with an imx6q SoM. I have asked for help from Advanced Micro and they have given me an updated kernel driver and patch. I am using 3.14.28 kernel. The results I am getting are the same with or without the driver update. So now it seems to be something else and I am unsure where to investigate right now. I am leaning towards the PCI bus as being the problem. But how do I debug this? I have posted the PCI boot messages that shows that this seems to be the issue. The card is seen as 0000:04:00.0 below. Where do I go from here?
I have searched google for possible “can’t get IRQ 0” solutions and ACPI seems to be a big help. I have attempted to look for ACPI in 3.14.28 and it does not exist. I figured I should try and post and ask for help but will continue to search around for possible ideas.
Thank you for your time in reading.
Cheers,
Pete
[ 3.778837] imx6q-pcie 1ffc000.pcie: Configuration forces GEN1
[ 3.779042] imx6q-pcie 1ffc000.pcie: PCI host bridge to bus 0000:00
[ 3.779053] pci_bus 0000:00: root bus resource [io 0x1000-0x10000]
[ 3.779062] pci_bus 0000:00: root bus resource [mem 0x01000000-0x01efffff]
[ 3.779070] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.779438] PCI: bus0: Fast back to back transfers disabled
[ 3.799290] PCI: bus1: Fast back to back transfers disabled
[ 3.799307] pci 0000:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.803733] PCI: bus2: Fast back to back transfers disabled
[ 3.803749] pci 0000:02:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.803798] pci 0000:02:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.803846] pci 0000:02:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.804322] PCI: bus3: Fast back to back transfers enabled
[ 3.804903] pci 0000:04:00.0: Setting PCI class for AVC8000 PCIe device
[ 3.806241] PCI: bus4: Fast back to back transfers disabled
[ 3.806696] PCI: bus5: Fast back to back transfers enabled
[ 3.806868] pci 0000:02:01.0: of_irq_parse_pci() failed with rc=-22
[ 3.806913] pci 0000:02:02.0: of_irq_parse_pci() failed with rc=-22
[ 3.806958] pci 0000:02:03.0: of_irq_parse_pci() failed with rc=-22
[ 3.807020] pci 0000:04:00.0: of_irq_parse_pci() failed with rc=-22
[ 3.807276] pci 0000:00:00.0: BAR 0: assigned [mem 0x01000000-0x010fffff]
[ 3.807288] pci 0000:00:00.0: BAR 8: assigned [mem 0x01100000-0x013fffff]
[ 3.807297] pci 0000:00:00.0: BAR 9: assigned [mem 0x01400000-0x016fffff pref]
[ 3.807305] pci 0000:00:00.0: BAR 6: assigned [mem 0x01700000-0x0170ffff pref]
[ 3.807312] pci 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 3.807324] pci 0000:01:00.0: BAR 8: assigned [mem 0x01100000-0x012fffff]
[ 3.807332] pci 0000:01:00.0: BAR 9: assigned [mem 0x01400000-0x016fffff pref]
[ 3.807338] pci 0000:01:00.0: BAR 0: assigned [mem 0x01300000-0x01303fff]
[ 3.807364] pci 0000:01:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 3.807375] pci 0000:02:01.0: BAR 8: assigned [mem 0x01100000-0x012fffff]
[ 3.807385] pci 0000:02:01.0: BAR 9: assigned [mem 0x01400000-0x015fffff 64bit pref]
[ 3.807393] pci 0000:02:02.0: BAR 9: assigned [mem 0x01600000-0x016fffff pref]
[ 3.807400] pci 0000:02:01.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 3.807406] pci 0000:02:01.0: PCI bridge to [bus 03]
[ 3.807422] pci 0000:02:01.0: bridge window [io 0x1000-0x1fff]
[ 3.807455] pci 0000:02:01.0: bridge window [mem 0x01100000-0x012fffff]
[ 3.807479] pci 0000:02:01.0: bridge window [mem 0x01400000-0x015fffff 64bit pref]
[ 3.807523] pci 0000:04:00.0: BAR 0: assigned [mem 0x01600000-0x01600fff pref]
[ 3.807547] pci 0000:02:02.0: PCI bridge to [bus 04]
[ 3.807598] pci 0000:02:02.0: bridge window [mem 0x01600000-0x016fffff pref]
[ 3.807637] pci 0000:02:03.0: PCI bridge to [bus 05]
[ 3.807721] pci 0000:01:00.0: PCI bridge to [bus 02-05]
[ 3.807735] pci 0000:01:00.0: bridge window [io 0x1000-0x1fff]
[ 3.807767] pci 0000:01:00.0: bridge window [mem 0x01100000-0x012fffff]
[ 3.807790] pci 0000:01:00.0: bridge window [mem 0x01400000-0x016fffff pref]
[ 3.807829] pci 0000:00:00.0: PCI bridge to [bus 01-05]
[ 3.807835] pci 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 3.807844] pci 0000:00:00.0: bridge window [mem 0x01100000-0x013fffff]
[ 3.807851] pci 0000:00:00.0: bridge window [mem 0x01400000-0x016fffff pref]
[ 3.808172] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 3.808179] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 3.808183] pci 0000:02:01.0: Signaling PME through PCIe PME interrupt
[ 3.808188] pci 0000:02:02.0: Signaling PME through PCIe PME interrupt
[ 3.808192] pci 0000:04:00.0: Signaling PME through PCIe PME interrupt
[ 3.808197] pci 0000:02:03.0: Signaling PME through PCIe PME interrupt
[ 3.808784] PCI: enabling device 0000:01:00.0 (0140 -> 0143)
[ 3.809778] pcieport 0000:02:01.0: device [10b5:8605] has invalid IRQ; check vendor BIOS
[ 3.809803] PCI: enabling device 0000:02:01.0 (0140 -> 0143)
[ 3.810871] pcieport 0000:02:02.0: device [10b5:8605] has invalid IRQ; check vendor BIOS
[ 3.810895] PCI: enabling device 0000:02:02.0 (0140 -> 0143)
[ 3.811883] pcieport 0000:02:03.0: device [10b5:8605] has invalid IRQ; check vendor BIOS
[ 3.811907] PCI: enabling device 0000:02:03.0 (0140 -> 0143)
[ 3.812955] PCI: enabling device 0000:04:00.0 (0140 -> 0142)
[ 3.813011] avc8k[0]: subsystem: 0000:0000
[ 3.814222] avc8k[0]: registered device video 0 [v4l2]
[ 3.823154] avc8k[0]: registered device video 1 [v4l2]
[ 3.831863] avc8k[0]: registered device video 2 [v4l2]
[ 3.840592] avc8k[0]: registered device video 3 [v4l2]
[ 3.849321] avc8k[0]: registered device video 4 [v4l2]
[ 3.858044] avc8k[0]: registered device video 5 [v4l2]
[ 3.866799] avc8k[0]: registered device video 6 [v4l2]
[ 3.875533] avc8k[0]: registered device video 7 [v4l2]
[ 3.884483] avc8k[0]: found at 0000:04:00.0, bus: 4, rev: 1, irq: 0, latency: 0, mmio: 0x1600000, device:0x6869
[ 3.884499] avc8k[0]: can't get IRQ 0
[ 3.885371] avc8k: probe of 0000:04:00.0 failed with error -22
