Hi all,
As we’re using a PCB antenna on our custom carrier board we need a small coax cable to connect to the wifi module. We’re currently using Amphenol RF U-1PU-113-035B2 35mm cables, and on our carrier board we are using Amphenol RF A-4JA sockets.
The strangest thing is we seem to be having issues with the cable coming loose from the carrier board. The connector used on the AzureWave module has a much better fit. I’ve looked around what I can find on the public internet but nothing seems to mention the part number of the connector used (the datasheet I found doesn’t even mentioned MHF4). Can Toradex ask AzureWave which connector they use (since I assume you have a decent volume with them), or do you have any other recommendations for part numbers?
