I am building the image torizon-minimal for version 7.3.0 of the distro torizon. I noticed that the bitbake step “Parsing recipe” takes more than 10 minutes - compared to the normal 30-60 seconds.
I could identify the culprit: the function get_layer_revision_information in meta-toradex-torizon/classes/torizon_base_image_type.inc. The class image_type_torizon.bbclass includes the file torizon_base_image_type.inc. As the class image_type_torizon is added to IMAGE_CLASSES, the function is executed 366 times during parsing because of
OSTREE_LAYER_REVISION_INFO := "${@get_layer_revision_information(d)}"
This assignment executes the function get_layer_revision_information several times for each image recipe found in the available layers. And there are more than 110 image recipes.
A closer look at get_layer_revision_information reveals that it will always calculate the same value for OSTREE_LAYER_REVISION_INFO for all image recipes. The commit shas for the layer repositories do not change during a build. Moreover, the task do_image_ostreecommit from image_types_ostree.bbclass, which evaluates OSTREE_LAYER_REVISION_INFO, is only executed by a single image recipe torizon-minimal.
The idea is to calculate the layer revision information only once. I can achieve this by moving the definition of get_layer_revision_information and the immediate assignment for OSTREE_LAYER_REVISION_INFO from meta-toradex-torizon/classes/torizon_base_image_type.inc to a class of its own, say, meta-toradex-torizon/classes/ostree_layer_revisions.bbclass.
We inherit the new class ostree_layer_revisions in meta-toradex-torizon/recipes-images/images/toradex-base.inc just before inheriting the class core-image:
IMAGE_OVERHEAD_FACTOR = "2.3"
inherit ostree_layer_revisions
inherit core-image
do_rootfs[cleandirs] += "${IMAGE_ROOTFS}"
OSTREE_LAYER_REVISION_INFO is calculated exactly once. The OSTree metadata for EXTRA_OSTREE_COMMIT used in meta-updater/classes/image_types_ostree.bbclass is the same as before. The step “Parsing recipes” is executed in 10 seconds instead of 10 minutes.
Now, I can customise torizon-minimal incrementally - without having to wait 10 extra minutes.
I hope that it’s a good enough fix for you to build on. Feel free to use it or improve it.
Cheers, Burkhard
