quDev
June 4, 2025, 9:42pm
21
Hi @michael.tx ,
Thanks for checking in and apologies for the delayed response. Also, thanks @alex.tx for supporting me on this. The issue did end up being a hardware issue. I was able to test another adapter board and everything works great. I will post a detailed explanation of everything I did in the next couple of days.
Thank you for the update. I’m glad to hear that your issue has been resolved.
Alexander Samutin
Toradex
quDev
July 7, 2025, 7:28pm
23
Original Issues:
Overlay for Colibri iMX8X 24-bit parallel interface does not seem to work as there is no output to the display when using a custom display adapter.
Once there was output to the display, a yellowish tint appeared where darker grays should be.
Touch functionality not working even though driver appears in modules list.
Solution:
There was no output because there was no power. Once the backlight pin was set correctly, the output worked fine.
The yellow tinting issue was due to hardware; Using another display adapter fixed it.
The touch driver does not automatically load and has to be enabled manually or through a service i.e.
sudo modprobe edt-ft5x06
colibri-imx8x_panel-cap-touch-5inch_adapter_overlay.dts
#include "dt-bindings/pinctrl/pads-imx8qxp.h"
compatible = "toradex,colibri-imx8x";
// Touch driver
#include "colibri-imx8x_focaltouch-adapter_overlay.dtsi"
// Parallel RGB driver (24-bit mode)
#include "colibri-imx8x_parallel-rgb-17SH10933_overlay.dtsi"
// New Haven display timings
#include "display-nhd50800480tf_overlay.dtsi"
// Enable the parallel RGB interface on the Colibri iMX8X.
panel_dpi: panel-dpi {
compatible = "panel-dpi";
backlight = <&backlight>;
data-mapping = "bgr666";
power-supply = <®_module_3v3>;
port {
lcd_panel_in: endpoint {
remote-endpoint = <&adma_lcdif_out>;
&adma_lcdif {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
adma_lcdif_out: endpoint {
remote-endpoint = <&lcd_panel_in>;
&adma_pwm {
&adma_pwm_lpcg {
&backlight {
&colibri_gpio_keys {
status = "disabled";
/* Colibri LCD Back-Light GPIO change to SODIMM 45 instead of 71 */
&pinctrl_gpio_bl_on {
gpioblongrp {
fsl,pins = <IMX8QXP_QSPI0A_DATA1_LSIO_GPIO3_IO10 0x06000040>; /* SODIMM 45 */
// NH-5.0-800480TF-ATXL#-CTP panel with a resolution of 800x480 pixel.
&panel_dpi {
width-mm = <108>;
height-mm = <65>;
panel-timing {
clock-frequency = <40000000>;
hactive = <800>;
vactive = <480>;
hsync-len = <20>;
hfront-porch = <210>;
hback-porch = <26>;
vsync-len = <10>;
vfront-porch = <22>;
vback-porch = <13>;
pixelclk-active = <1>;
#include <dt-bindings/interrupt-controller/irq.h>
/* FocalTech I2C touch driver, compatible with FT5426 driver in NHD-5.0-800480TF-ATXL#-CTP touch display */
&i2c1 {
#size-cells = <0>;
/* Focaltech touch driver */
polytouch: edt-ft5x06@38 {
compatible = "edt,edt-ft5x06";
reg = <0x38>;
interrupt-parent = <&lsio_gpio0>;
interrupts = <21 IRQ_TYPE_EDGE_FALLING>; /* SODIMM 28, pin 38 of Iris V2 X16 connector */
/* Use atmel adapter pin group to access SODIMM 28 */
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_atmel_adap>;
/* To get correct feedback from touch driver */
touchscreen-size-x = <800>;
touchscreen-size-y = <480>;
&lsio_pwm0 {
&lsio_pwm1 {
