Hi @CoQuarksde ,
Thanks for using the Toradex community.
Up to BSP2.8 we used OPKG as the package manager. With it you can install “.ipk” packages. You can have a look at this community post where installing a webserver was discussed as reference.
We do not recommend this and instead we recommend you build your application into the image itself. More information on how to integrate it into the image you can find here.
Are you intending to update and install software packages over the internet as well?
Kevin
