I am trying to build a custom image and hit this exception:
Building image as per configuration file 'tcbuild.yaml'...
=>> Handling input section
Unpacking Toradex Easy Installer image.
Copying Toradex Easy Installer image.
Unpacking TorizonCore Toradex Easy Installer image.
Importing OSTree revision 7b671c2c471331a20eb8c36485acddcdf9abf27d5c725b6a8baaad2692656341 from local repository...
1140 metadata, 12738 content objects imported; 529.7 MB content written
0 metadata, 0 content objects imported; 0 bytes content written
Unpacked OSTree from Toradex Easy Installer image:
Commit checksum: 7b671c2c471331a20eb8c36485acddcdf9abf27d5c725b6a8baaad2692656341
TorizonCore Version: 5.7.2+build.20
=>> Handling customization section
=> Setting splash screen
splash screen merged to initramfs
=> Handling device-tree subsection
=> Selecting custom device-tree 'linux/arch/arm64/boot/dts/freescale/imx8mp-verdin-nonwifi-dev.dts'
'imx8mp-verdin-nonwifi-dev.dts' compiles successfully.
warning: removing currently applied device tree overlays
Device tree imx8mp-verdin-nonwifi-dev.dtb successfully applied.
=> Adding device-tree overlay 'device-trees/overlays/touch-atmel-mxt_overlay.dts'
'touch-atmel-mxt_overlay.dts' compiles successfully.
/tmp/tmp6pu1tdvy: Device Tree Blob version 17, size=89671, boot CPU=0, string block size=7071, DT structure block size=82544
'touch-atmel-mxt_overlay.dtbo' can successfully modify the device tree 'imx8mp-verdin-nonwifi-dev.dtb'.
Overlay touch-atmel-mxt_overlay.dtbo successfully applied.
=> Adding device-tree overlay 'device-trees/overlays/verdin-imx8mp_sn65dsi84-lt170410_overlay.dts'
'verdin-imx8mp_sn65dsi84-lt170410_overlay.dts' compiles successfully.
Failed to apply '/tmp/tmpgr55l_ir': FDT_ERR_NOTFOUND
error: cannot apply device tree overlays ['/storage/dt/usr/lib/modules/5.4.193-5.7.2+git.b60d3160fd04/dtb/overlays/touch-atmel-mxt_overlay.dtbo', '/tmp/tmpgr55l_ir'] against device tree /storage/dt/usr/lib/modules/5.4.193-5.7.2+git.b60d3160fd04/dtb/imx8mp-verdin-nonwifi-dev.dtb.
error: overlay 'device-trees/overlays/verdin-imx8mp_sn65dsi84-lt170410_overlay.dts' is not applicable.
I got my overlay configuration here, I have the capacitive touch 10.1 with lvds adapter to a verdin imx8mp SoM. When I applied these overlays to an existing image on the module it worked fine and got my display working, why won’t it let me build with them?
