Overlay for LCD backlight
Hi there,
Hardware:
Colibri iMX6DL
with Viola Carrier Board Rev 1.2
TorizonCore 5.7.2
We’re trying to use a LCD connected to the Unified Interface Display Connect (X7 on the Viola Rev 1.2 carrier board).
And wanted to initially check that the backlight is working.
Checking the X7 connection details, we can see that…
BL_ON SOIMM Number = 71 –> GPIO3_IO26
PWM_A SOIMM Number = 59 –> PW3_OUT, GPIO2_IO09, GPIO2_IO16
We then created a new overlay file…
colibri-imx6_panel-st7789v-2.8inch_overlay.dts, with the following settings…
(taking the timings from the MIDAS MDT0280A1IHR-MULTI 240x320 display datasheet using the ST7789V Controller IC)
/* Copyright 2023 */
// Enable the parallel RGB interface on the Colibri iMX6DL.
// Make sure to also select a valid display configuration.
/dts-v1/;
/plugin/;
        compatible = "toradex,colibri_imx6dl";
&backlight {
	pwms = <&pwm3 0 6666667>;
&lcd_display {
&pwm3 {
&panel_dpi {
	compatible = "panel-dpi";
	data-mapping = "bgr666";
	width-mm = <44>;
	height-mm = <58>;
	panel-timing {
		clock-frequency = <6350000>;
		hactive = <240>;
		vactive = <320>;
		hsync-len = <30>;
		hfront-porch = <10>;
		hback-porch = <20>;
		vsync-len = <22>;
		vfront-porch = <4>;
		vback-porch = <18>;
After deploying the overlay and rebooting, the backlight does not show.
Is there a way in which to test BL_ON & PWM just to confirm that is working?
Many Thanks Jon
Hello @jon2023 ,
Would it be possible for you to share the datasheet of the display that you are using?
Josep
Yeah sure,
Should be attached…
MDT0280A1IHR-MULTI.pdf (1.7 MB)
Timings on Page 6
And page 7
And the calculated values…
hsync-len: HORIZONTAL_BLANKING_PERIOD =
tHBP + tHFP = 20 + 10 = 30
tHBP = 20
tHFP = 10
vsync-len: VERTICAL_BLANKING_PERIOD =
tVBP + tVFP = 18 + 4 = 22
tVBP = 18
tVFP = 4
And from the MIDAS datasheet…
DOTCLK (DCLK) frequency: 6.35MHz
Let me know if you need any more details
Many Thanks Jon
Hi there,
Hardware:
Colibri iMX6DL
TorizonCore 5.7.2
We’ve managed to get the backlight (BL_ON) and brightness to change using the command line…
$ echo 0 > bl_power
$ echo 7 > brightness
Next we a looking to output something on the connected LCD screen…
Checking the modes…
$ cat /sys/class/graphics/fb0/modes
U:240x320p-0
and running the fbset command, we get…
mode “240x320-0”
# D: 0.000 MHz, H: 0.000 kHz, V: 0.000 Hz
geometry 240 320 240 320 16
timings 0 0 0 0 0 0 0
accel true
rgba 5/11,6/5,5/0,0/0
endmode
Should the D:, H: and V: details show different values?
Should the timings show different values?
$ cat /proc/cmdline shows this…
enable_wait_mode=off galcore.contiguousSize=50331648 root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/138ddb3d76cc0356ed5c9f44787061a6af39984f5b69bd5c5bcb7a907219187c/0
Which seems to indicate that the lcd display isn’t enabled correctly.
Let me know if there is something that I’m missing or can try out.
Many Thanks
Jon
Hi @jon2023 ,
I noticed in your overlay that you considered hsync-len = hfront-porch + hback-porch and vsync-len = vfront-porch + vback-porch, and I don’t think that’s correct value for them, based on the kernel documentation.
hsync-len and vsync-len are the horizontal and vertical sync lengths respectively, and each one should have its own value in the datasheet. From the datasheet you provided they should be (typical values):
  • hsync-len: 10 DOTCLKs
  • vsync-len: 2 lines
Try setting these new values to your overlay and see if you can get the display to work.
Lucas Akira
Thanks Lucas,
I shall try updating values and hopefully that will do the trick :slight_smile:
Cheers
Jon
Hello @jon2023 ,
Do you have any updates on this topic?
Josep
Hi there Josep, just a quick update on the LCD overlay issue…
We’ve followed the steps below, but unable to see any output on the LCD display.
Steps
  1. Update the Device Tree Overlays
These are the two dts files used for to set up the above…
File: colibri-imx6_st7789v-2.8inch_overlay.dts
// Enable the LCD interface on the Colibri iMX6DL.
/dts-v1/;
/plugin/;
&backlight {
&lcd_display {
&panel_dpi {
File: display-lcd2.8_overlay.dts
 * Copyright 2020-2021 Toradex
// LCD 2.8 display with a resolution of 240x320 pixel
/dts-v1/;
/plugin/;
	compatible = "toradex,apalis_imx6q",
		     "toradex,apalis-imx8x",
		     "toradex,colibri_imx6dl",
		     "toradex,colibri-imx6ull-emmc",
		     "toradex,colibri-imx7d",
		     "toradex,colibri-imx7s",
		     "toradex,colibri-imx8x";
&{/panel-dpi} {
	width-mm = <44>;
	height-mm = <58>;
	panel-timing {
		hactive = <240>;
		vactive = <320>;
		hsync-len = <10>;
		hback-porch = <20>;
		vsync-len = <2>;
		vfront-porch = <4>;
		vback-porch = <2>;
  1. Updated the /etc/xdg/weston.ini file
[core]
idle-time=0
require-input=false
xwayland=true
modules=screen-share.so
# uncomment line below to use kiosk shell
#shell=kiosk-shell.so
[shell]
background-image=
background-color=0x00000000
panel-position=none
locking=false
allow-zap=false
num-workspaces=1
[keyboard]
vt-switching=false
# uncomment the [output] line below if you set any output configuration
[output]
# you must uncomment the "name” line and provide the name of the output interface being customized, otherwise, changes will not apply
name=DPI-1
# uncomment line below to configure screen rotation/flipping
#transform=rotate-90
# uncomment line below to redirect the output; supported by kiosk shell
#app-ids=my-app-id
# uncomment line below to turn off the output
#mode=off
# uncomment line below to set an output resolution. Run for example 'cat /sys/class/drm/card1-HDMI-A-1/modes' to list the available modes.
mode=240x320@69.1
# or use the more detailed (mode=dotclock hdisp hsyncstart hsyncend htotal vdisp vsyncstart vsyncend vtotal hflag vflag)
#mode=146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync
# uncomment line below to make this output a clone of another
#same-as=DPI-1
#For multi-display support and other configurations, please read the article: https://developer.toradex.com/knowledge-base/working-with-weston-on-torizoncore
  1. Checked the modes…
/sys/class/drm/card1-DPI-1
cat modes
240x320
  1. Checked the dri
    ls -al /dev/dri
  2. Checked the class
    ls -al /sys/class/drm
  1. Cleared any running docker containers
    docker stop $(docker ps -a -q)
  2. Run the weston docker container
    docker run -d --rm --name=wayland-app --user=torizon -v /dev/dri:/dev/dri -v /tmp:/tmp --device-cgroup-rule='c 226:* rmw' torizon/weston:$CT_TAG_WESTON weston-terminal
  3. Checked the logs
docker logs torizon_weston_1
SoC is: 'i.MX6DL'
SoC has GPU: true
SoC has DPU: false
g2d implementation: viv
Removing previously created '.X*-lock' entries under /tmp before starting Weston. Pass 'IGNORE_X_LOCKS=1' environment variable to Weston container to disable this behavior.
dos2unix: converting file /etc/xdg/weston/weston.ini to Unix format...
dos2unix: converting file /etc/xdg/weston-dev/weston.ini to Unix format...
Couldn't open /dev/tty1
/usr/bin/entry.sh: line 89: [: =: unary operator expected
Date: 2023-11-05 UTC
[20:49:35.524] weston 9.0.0
               https://wayland.freedesktop.org
               Bug reports to: https://gitlab.freedesktop.org/wayland/weston/issues/
               Build: 9.0.0
[20:49:35.524] Command line: /usr/bin/weston --current-mode
[20:49:35.525] OS: Linux, 5.4.193-5.7.2+git.f5d73fd6e9f8, #1-TorizonCore SMP Fri Jun 24 10:15:32 UTC 2022, armv7l
               Build: 9.0.0
[20:49:35.527] Using config file '/etc/xdg/weston/weston.ini'
[20:49:35.539] Output repaint window is 7 ms maximum.
[20:49:35.542] Loading module '/usr/lib/arm-linux-gnueabihf/libweston-9/drm-backend.so'
[20:49:35.583] initializing drm backend
[20:49:35.592] logind: not running in a systemd session
[20:49:35.593] logind: cannot setup systemd-logind helper (-61), using legacy fallback
[20:49:35.620] using /dev/dri/card1
[20:49:35.621] DRM: supports atomic modesetting
[20:49:35.623] DRM: supports GBM modifiers
[20:49:35.624] DRM: supports picture aspect ratio
[20:49:35.630] Loading module '/usr/lib/arm-linux-gnueabihf/libweston-9/gl-renderer.so'
[20:49:37.204] EGL client extensions: EGL_EXT_device_base
               EGL_EXT_device_enumeration EGL_EXT_device_query
               EGL_EXT_platform_base EGL_KHR_client_get_all_proc_addresses
               EGL_EXT_client_extensions EGL_KHR_debug EGL_EXT_platform_device
               EGL_EXT_platform_wayland EGL_KHR_platform_wayland
               EGL_EXT_platform_x11 EGL_KHR_platform_x11 EGL_MESA_platform_gbm
               EGL_KHR_platform_gbm EGL_MESA_platform_surfaceless
[20:49:37.213] EGL version: 1.4
[20:49:37.213] EGL vendor: Mesa Project
[20:49:37.213] EGL client APIs: OpenGL OpenGL_ES
[20:49:37.213] EGL extensions: EGL_ANDROID_blob_cache
               EGL_ANDROID_native_fence_sync EGL_EXT_buffer_age
               EGL_EXT_image_dma_buf_import
               EGL_EXT_image_dma_buf_import_modifiers EGL_KHR_cl_event2
               EGL_KHR_config_attribs EGL_KHR_create_context
               EGL_KHR_create_context_no_error EGL_KHR_fence_sync
               EGL_KHR_get_all_proc_addresses EGL_KHR_gl_renderbuffer_image
               EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image
               EGL_KHR_gl_texture_cubemap_image EGL_KHR_image
               EGL_KHR_image_base EGL_KHR_image_pixmap
               EGL_KHR_no_config_context EGL_KHR_reusable_sync
               EGL_KHR_surfaceless_context EGL_EXT_pixel_format_float
               EGL_KHR_wait_sync EGL_MESA_configless_context
               EGL_MESA_drm_image EGL_MESA_image_dma_buf_export
               EGL_MESA_query_driver EGL_WL_bind_wayland_display
[20:49:37.214] EGL_KHR_surfaceless_context available
[20:49:37.274] GL version: OpenGL ES 2.0 Mesa 20.3.5
[20:49:37.274] GLSL version: OpenGL ES GLSL ES 1.0.16
[20:49:37.274] GL vendor: etnaviv
[20:49:37.274] GL renderer: Vivante GC880 rev 5106
[20:49:37.275] GL extensions: GL_EXT_blend_minmax GL_EXT_multi_draw_arrays
               GL_EXT_texture_filter_anisotropic
               GL_EXT_texture_compression_s3tc GL_EXT_texture_compression_dxt1
               GL_EXT_texture_format_BGRA8888
               GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24
               GL_OES_element_index_uint GL_OES_fbo_render_mipmap
               GL_OES_mapbuffer GL_OES_rgb8_rgba8 GL_OES_standard_derivatives
               GL_OES_stencil8 GL_OES_texture_3D GL_OES_texture_npot
               GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_depth_texture
               GL_AMD_performance_monitor GL_OES_packed_depth_stencil
               GL_EXT_texture_type_2_10_10_10_REV GL_OES_get_program_binary
               GL_APPLE_texture_max_level GL_EXT_discard_framebuffer
               GL_EXT_read_format_bgra GL_EXT_frag_depth
               GL_NV_fbo_color_attachments GL_OES_EGL_image_external
               GL_OES_EGL_sync GL_OES_vertex_array_object
               GL_ANGLE_pack_reverse_row_order
               GL_ANGLE_texture_compression_dxt3
               GL_ANGLE_texture_compression_dxt5
               GL_EXT_occlusion_query_boolean GL_EXT_unpack_subimage
               GL_NV_draw_buffers GL_NV_read_buffer GL_NV_read_depth
               GL_NV_read_depth_stencil GL_NV_read_stencil GL_EXT_draw_buffers
               GL_EXT_map_buffer_range GL_KHR_debug
               GL_KHR_texture_compression_astc_ldr GL_NV_pixel_buffer_object
               GL_OES_required_internalformat GL_OES_surfaceless_context
               GL_EXT_separate_shader_objects
               GL_EXT_compressed_ETC1_RGB8_sub_texture
               GL_EXT_draw_elements_base_vertex GL_EXT_texture_border_clamp
               GL_KHR_context_flush_control GL_OES_draw_elements_base_vertex
               GL_OES_texture_border_clamp GL_KHR_no_error
               GL_KHR_texture_compression_astc_sliced_3d
               GL_EXT_texture_compression_s3tc_srgb
               GL_KHR_parallel_shader_compile
[20:49:37.275] GL ES 2 renderer features:
               read-back format: BGRA
               wl_shm sub-image to texture: yes
               EGL Wayland extension: yes
[20:49:37.452] event0  - gpio-keys: is tagged by udev as: Keyboard
[20:49:37.453] event0  - gpio-keys: device is a keyboard
[20:49:37.598] libinput: configuring device "gpio-keys".
[20:49:37.599] DRM: head 'DPI-1' found, connector 43 is connected, EDID make 'unknown', model 'unknown', serial 'unknown'
[20:49:37.600] Registered plugin API 'weston_drm_output_api_v1' of size 12
[20:49:37.600] Registered plugin API 'weston_drm_virtual_output_api_v1' of size 24
[20:49:37.601] Chosen EGL config details: id:  13 rgba: 8 8 8 0 buf: 24 dep:  0 stcl: 0 int: 1-1 type: win vis_id: XRGB8888 (0x34325258)
[20:49:37.601] Output DPI-1 (crtc 34) video modes:
               240x320@69.1, preferred, current, 6.3 MHz
[20:49:37.601] associating input device event0 with output DPI-1 (none by udev)
[20:49:37.601] Output 'DPI-1' enabled with head(s) DPI-1
[20:49:37.601] Compositor capabilities:
               arbitrary surface rotation: yes
               screen capture uses y-flip: yes
               presentation clock: CLOCK_MONOTONIC, id 1
               presentation clock resolution: 0.000000001 s
[20:49:37.606] Loading module '/usr/lib/arm-linux-gnueabihf/weston/desktop-shell.so'
[20:49:37.612] launching '/usr/lib/arm-linux-gnueabihf/weston-keyboard'
[20:49:37.624] Loading module '/usr/lib/arm-linux-gnueabihf/weston/screen-share.so'
[20:49:37.656] Screen share failed: No wl_shm found
[20:49:37.658] Loading module '/usr/lib/arm-linux-gnueabihf/libweston-9/xwayland.so'
[20:49:38.072] Registered plugin API 'weston_xwayland_v1' of size 16
[20:49:38.072] Registered plugin API 'weston_xwayland_surface_v1' of size 8
[20:49:38.072] xserver listening on display :0
[20:49:38.073] launching '/usr/lib/arm-linux-gnueabihf/weston-desktop-shell'
[20:49:38.227] unknown child process exited
could not load cursor 'dnd-move'
could not load cursor 'dnd-copy'
could not load cursor 'dnd-none'
[20:49:48.955] libwayland: error in client communication (pid 0)
[20:50:40.445] deactivating session
[20:50:40.450] event0  - gpio-keys: device removed
The docker container just seems to terminate without any detailed error.
Let me know if you spot any error or something that we can check on.
Cheers Jon
Hi there,
Let me know if you have any updates on this, or need any more details that may help.
Cheers Jon
We think we have fixed this issue with using the scope to check the data lines.
We do have an another issue tho, but we will include the details on a new topic
Cheers Jon
