Understanding Torizon OTA Update Behavior
Your issue with OTA updates transitioning to “Update in Progress” before user acceptance is a known challenge with the default Torizon OTA implementation. Let me address your questions based on the available information:
1. Expected Behavior vs. Bug
This behavior appears to be the default implementation of Torizon Remote Updates (1). The system uses Aktualizr, which polls the server for updates every 5 minutes and applies them automatically when available (1)(2). This automatic behavior is by design for seamless OTA functionality.
2. Customizing Update Behavior for User Approval
Based on the community discussion, there are approaches to implement user approval workflows (2):
- Using
flockcommand: You can block updates using theflockcommand to prevent automatic application until user confirmation (2) - Custom notification mechanism: Implement a system to notify your application when updates are available, allowing you to present the choice to users (2)
- User confirmation workflow: Only proceed with updates after explicit user acceptance (2)
The flock approach is considered safe even after reboots and can effectively maintain update blocking until you explicitly allow them (2).
3. Update Cancellation Limitations
Regarding update cancellation, the API documentation shows that updates can only be cancelled when they are in “Pending” status (3). Once a device has received its update instructions, the update can no longer be cancelled from the server side (3).
Recommended Approach
To achieve your desired workflow:
- Implement update blocking: Use
flockto prevent automatic updates - Create notification system: Set up a mechanism to notify your application when updates are available
- User interaction handling: Present update options to users and only release the
flockupon user acceptance - Configuration files: Investigate
.tomlconfiguration files for Aktualizr customization (2)
This approach ensures updates remain in a controllable state until user approval, maintaining your ability to cancel or replace updates as needed.
