The issue you’re encountering is likely due to the order in which the variables are being set and used during the build process. The os-release file is being generated before your custom image variables like IMAGE_VERSION are set, which is why they are not appearing in the final os-release file.
Here are a few suggestions to address this issue:
Ensure Variable Expansion: Make sure that the variables are being expanded correctly. You can try using
:=instead of=for immediate variable expansion in youros-release.bbappendfile. This forces the variable to be expanded at the time of assignment.NAME:="${IMAGE_NAME}" VERSION:="${IMAGE_VERSION}" -
Check the Order of Execution: The
os-releasefile might be getting generated before your image recipe is fully processed. You can try to ensure that youros-release.bbappendis processed after your image recipe by using dependencies or by adjusting the order of operations. -
Use BitBake Debugging: Use BitBake’s debugging tools to check the order of operations and see when the
os-releasefile is being generated. You can usebitbake -e <recipe>to inspect the environment and see the values of variables at different stages. -
Custom Task: If the above methods do not work, consider creating a custom task in your image recipe that modifies the
os-releasefile after it has been initially created. This task can be set to run after thedo_rootfstask. -
Check for Conflicts: Ensure there are no other layers or recipes that might be overriding your settings for
os-release.
By ensuring the correct order of operations and variable expansion, you should be able to get your custom variables into the os-release file.
