I’m using Colibri VF50 Modules and built a customized WinCE 6.0 OS image with BSP V1.4beta1. Version of bootloader is also V1.4beta1. I tried to update OS image with Update Tool 5.7.0 but when i select image and click OK, message “Update Successful” appear immediately after less than 1 sec and nothing has changed. When I reset module, OS Image is unchanged.
The problem is when image file is not at the root of USB flash drive, for example “\USB HD\FlashUpdate\NK.bin”. In that case i get message “Update Successful” on Update Tool, but nothing has done. When i put image file to the root of USB flash drive everything is OK.
