Hello I have watched a video that is on toradex’s channel https://youtu.be/TTcP3xeLrEY?si=DSlYZ4anFMJrxL91
and also I want to compile and deploy this image to my development board. Is there any guidenence about it, I want to use the same project that is on video. If it is possible is there any yocto layer for it?
Hello @erdemkahraman ,
Maybe it’s batter that you contact the author of the original post here:
Fast-Booting Qt Devices, Part 4: Hardware Matters
Josep
Hi @josep.tx
I’ve contacted with Risto but he did not answered me.
I am using Colibri iMX6DL and booting with emmc
root@colibri-imx6:~# cat /etc/os-release
VERSION_ID="v2017.12"
NAME="Angstrom"
ID="angstrom"
PRETTY_NAME="The Ångström Distribution v2017.12"
ANSI_COLOR="1;35"
HOME_URL="http://www.angstrom-distribution.org"
root@colibri-imx6:~# uname -r
4.9.87-rt62-2.8.4+g3bb6e32
BSP: 2.8b4
And my systemd-analyze blame output is
root@colibri-imx6:~# systemd-analyze blame
8.637s dev-mmcblk0p2.device
1.965s systemd-hwdb-update.service
1.497s systemd-udev-trigger.service
1.162s usbg.service
961ms systemd-resolved.service
899ms rc-local.service
639ms rpcbind.service
599ms systemd-logind.service
527ms systemd-networkd.service
460ms tmp.mount
457ms systemd-remount-fs.service
448ms systemd-journal-flush.service
405ms systemd-fsck-root.service
338ms sys-kernel-debug.mount
332ms systemd-journald.service
307ms systemd-udevd.service
284ms sshd.socket
242ms systemd-sysctl.service
225ms alsa-restore.service
194ms systemd-timesyncd.service
177ms user@0.service
137ms systemd-random-seed.service
127ms systemd-journal-catalog-update.service
127ms ldconfig.service
115ms systemd-sysusers.service
102ms systemd-modules-load.service
95ms sys-fs-fuse-connections.mount
95ms gpio-export.service
92ms systemd-user-sessions.service
80ms systemd-update-utmp.service
73ms dev-mmcblk0p1.device
69ms kmod-static-nodes.service
60ms systemd-update-utmp-runlevel.service
58ms var-volatile.mount
45ms systemd-tmpfiles-setup.service
40ms systemd-tmpfiles-setup-dev.service
40ms systemd-update-done.service
32ms sys-kernel-config.mount
My question is why this dev-mmcblk0p2.device cost to me 8 seconds? For example on my ubuntu laptop even if it is using ssd but the dev-sdb3.device is costing only 2 seconds. As far as I know emmc is faster than ssd, but on my image it is too slow. What may be the problem.
Hi @erdemkahraman!
Using an up-to-date version of our BSP, the same behavior is not observed:
root@colibri-imx6-10672468:~# tdx-info
Software summary
Bootloader: U-Boot
Kernel version: 6.1.71-6.5.0+git.38fb82ecd144 #1 SMP Fri Jan 5 14:18:41 UTC 2024
Kernel command line: enable_wait_mode=off galcore.contiguousSize=50331648 root=PARTUUID=a0f512ac-02 ro rootwait fec_mac=00:14:2d:a2:d9:54 consoleblank=0 no_console_suM
Distro name: NAME="TDX Wayland with XWayland Upstream"
Distro version: VERSION_ID=6.5.0-build.9
Distro variant: -
Hostname: colibri-imx6-10672468
Hardware info
HW model: Toradex Colibri iMX6DL/S on Colibri Evaluation Board V3
Toradex version: 0017 V1.1A
Serial number: 10672468
Processor arch: armv7l
root@colibri-imx6-10672468:~# systemd-analyze blame
5.970s dev-mmcblk2p2.device
5.952s systemd-udev-settle.service
2.556s weston.service
2.248s ldconfig.service
1.695s systemd-timesyncd.service
1.288s set-hostname.service
1.057s systemd-udev-trigger.service
944ms user@0.service
666ms ofono.service
637ms sys-kernel-debug.mount
619ms tmp.mount
599ms modprobe@configfs.service
593ms kmod-static-nodes.service
553ms modprobe@fuse.service
546ms alsa-restore.service
545ms systemd-logind.service
545ms media-BOOT\x2dmmcblk2p1.mount
545ms systemd-networkd.service
535ms usbg.service
519ms modprobe@drm.service
509ms systemd-sysctl.service
483ms systemd-fsck-root.service
456ms ip6tables.service
453ms systemd-network-generator.service
446ms iptables.service
442ms systemd-hostnamed.service
425ms systemd-journal-catalog-update.service
385ms systemd-machine-id-commit.service
361ms systemd-journald.service
339ms dbus.service
318ms systemd-update-done.service
296ms systemd-fsck@dev-mmcblk2p1.service
280ms systemd-update-utmp.service
246ms systemd-udevd.service
243ms rpcbind.service
241ms systemd-tmpfiles-setup.service
235ms systemd-userdbd.service
234ms systemd-backlight@backlight:backlight.service
202ms connman.service
138ms systemd-random-seed.service
121ms systemd-tmpfiles-setup-dev.service
119ms sys-kernel-config.mount
118ms wpa_supplicant.service
116ms sys-fs-fuse-connections.mount
114ms systemd-update-utmp-runlevel.service
111ms systemd-remount-fs.service
85ms systemd-sysusers.service
85ms user-runtime-dir@0.service
84ms systemd-journal-flush.service
81ms avahi-daemon.service
74ms var-volatile.mount
66ms weston.socket
40ms boot.mount
33ms systemd-user-sessions.service
Also, BSP 2 is End-Of-Life (EOL) since a while, so the recommendation is to use the newer BSP.
Please refer to the following articles to know more about Toradex’s support strategy for Linux and the current state of our BSPs:
Hi @henrique.tx
Got it, your offer is moving to the new BSP for example 6.x etc.
But still there is still something are not fitting to my mind. Why dev-mmcblk2p2.device is taking 5.970s.
What are the dependencies about the dev-mmcblk2p2.device. RAM? eMMC?
Because as far as I know eMMC is almost the fastest storage device.
For example If I have 2 gig ram on the device, Will it be faster?
Hi @erdemkahraman!
To answer this question, you would need to invest some time investigating why this is happening in your case. Using the critical-chain of Systemd helps to analyze the longest chain that causes the biggest impact in your boot time.
It is possible that what you are witnessing is not necessarily related to the devices’s performance for read and write operations, but to how it is being recognized by the OS.
With more RAM, the device can withstand more data at the same time, which would make it perform better, but if your use case is not reaching the the maximum amount of RAM available, it isn’t an issue.
