Optee pre-provisioned RPMB key
is it necessary to build 2 complete images, one with TDX_OPTEE_FS_RPMB_MODE ? set to “factory” and one with “production” and fuse the device then boot the “factory” and then reflash with the “production” - or can the provisioning (fuse and write rpmb key) be made manually on the “production” image ?
Any advice appreciated
Regards - Paul
RPMB Key Provisioning Options
You have two approaches for RPMB key provisioning with OP-TEE:
Option 1: Two-Image Approach (Recommended)
This is the standard workflow:
  1. Factory Image: Build with TDX_OPTEE_FS_RPMB_MODE = "factory"
    • This image is configured to program the RPMB key derived from the SoC’s Hardware Unique Key (HUK)
    • Use this in a secure factory provisioning environment only
  2. Production Image: Build with TDX_OPTEE_FS_RPMB_MODE = "production"
    • This assumes the RPMB key has already been programmed
    • Deploy this for production use
Option 2: Manual Provisioning
Manual RPMB key provisioning on a production image is technically possible but not recommended for several reasons:
  • Security Risk: The production image lacks the built-in safeguards and automation of the factory mode
  • Complexity: You’d need to manually handle the key derivation and RPMB programming process
  • Error-Prone: RPMB key programming can only be done once - mistakes are permanent
Key Considerations
  • RPMB Key Programming: This operation can only be performed once per device
  • Secure Environment: Factory provisioning should occur in a trusted, secure environment
  • Hardware Unique Key: The RPMB key is derived from the SoC’s HUK and device-specific information
Recommendation
Use the two-image approach for production deployment. The factory mode provides proper automation and security controls for the critical one-time RPMB key programming operation.
Could you let me know which hardware platform and OS version you’re working with? This will help me provide more specific guidance for your setup.
@ToradexAI can you supply a script for the manual provisioning?
Manual RPMB Provisioning Script
Unfortunately, I don’t have a specific manual provisioning script in the available sources. The documentation emphasizes that manual RPMB key provisioning is complex and not the recommended approach.
What the Sources Tell Us
The eMMC documentation explains that the RPMB (Replay Protected Memory Block) area is a vendor-specific area that uses more reliable storage technology than the regular user area (1). However, the specific implementation details for manual provisioning scripts aren’t provided in the current documentation.
Recommended Approach
Based on the available information, I strongly recommend using the two-image factory/production approach rather than manual provisioning, as this provides:
  • Built-in security safeguards
  • Proper automation
  • Reduced risk of errors (since RPMB key programming can only be done once)
Next Steps
To provide you with the most accurate guidance for manual provisioning, could you share:
  1. Which hardware platform you’re using (you can run tdx-info to get this information: Getting Device Information with Tdx-Info | Toradex Developer Center)
  2. Which OS version you’re running
  3. Your specific use case requirements that make manual provisioning necessary
This will help me provide more targeted assistance for your setup.
@ToradexAI
Software summary
Bootloader: U-Boot
Kernel version: 6.6.115-7.5.0-devel #1 SMP PREEMPT Wed Oct 29 13:07:06 UTC 2025
Kernel command line: ro rootwait console=tty1 console=ttymxc0,115200 root=PARTUUID=4fa9241c-02
Distro name: NAME=“TDX Wayland with XWayland Upstream”
Distro version: VERSION_ID=7.5.0-devel-20251118061447-build.0
Distro variant: -
Hostname: -
Hardware info
HW model: Toradex Colibri iMX7D 1GB (eMMC) on Colibri Evaluation Board V3
Toradex version: 0039 V1.1B
Serial number: 12827568
Processor arch: armv7l
Manual RPMB Provisioning Script for Colibri iMX7D
Based on your hardware information (Colibri iMX7D 1GB eMMC V1.1B with BSP 7.5.0-devel), I can see you’re working with an eMMC-based module that supports RPMB functionality.
Understanding RPMB on Your Module
Your Colibri iMX7D has eMMC storage with a dedicated RPMB (Replay Protected Memory Block) area (1). The RPMB area is a vendor-specific area that uses underlying storage technology more reliable than the user area (1).
Manual Provisioning Considerations
Unfortunately, the available documentation doesn’t include specific manual provisioning scripts for RPMB key programming. However, based on the community discussion about OP-TEE support on iMX7D (2), manual porting and configuration of OP-TEE for the Colibri iMX7D requires significant low-level configuration work.
Key Technical Details for Your Module
For the Colibri iMX7D, you can access the eMMC information through U-Boot (3). The U-Boot console allows you to interact with the eMMC device and examine its configuration (3).
eMMC Device Structure
Your module’s eMMC has the following structure (1):
eMMC boot area:
  • Raw partition - U-Boot bootloader and environment, Toradex factory configuration block (1)
  • Raw partition - RPMB area for storing sensitive data such as authentication keys (1)
eMMC user area:
  • FAT32 partition - Kernel and device tree (1)
  • EXT-4 partition - Root file system (1)
Recommendation
Given the complexity and the one-time nature of RPMB key programming, I strongly recommend using the factory/production image approach rather than manual scripting. The community discussion (2) shows that even basic OP-TEE porting for iMX7D requires extensive manual configuration work.
For manual provisioning scripts specific to your setup, you may need to consult the OP-TEE documentation directly or work with the low-level eMMC commands through U-Boot, but this carries significant risk since RPMB key programming can only be performed once per device.
Would you like me to help you set up the two-image approach instead, which would be much safer for your production deployment?
@ToradexAI
can “mmc rpmb write-key /dev/mmcblk0rpmb $KEY” be used ?
Then i need instructions on how to get a key derived from the imx7 HUK
Regards - Paul
RPMB Key Programming and HUK Derivation on iMX7
Manual RPMB Key Programming
The mmc rpmb write-key command can indeed be used to program the RPMB key, but this is a one-time operation that cannot be reversed. The challenge is properly deriving the key from the iMX7 Hardware Unique Key (HUK).
Key Derivation Process
For OP-TEE on iMX7, the RPMB key is derived from the SoC’s Hardware Unique Key (HUK) and other device-specific information. The documentation indicates that when using factory mode (TDX_OPTEE_FS_RPMB_MODE = "factory"), OP-TEE is configured to program the RPMB key derived from the SoC’s Hardware Unique Key (HUK) and other device-specific information.
Technical Considerations for Your Setup
Based on your Colibri iMX7D 1GB eMMC module, the RPMB area is available as a dedicated partition for storing sensitive data such as authentication keys (1). However, the specific implementation details for manual HUK derivation aren’t provided in the current documentation.
Critical Warnings
  1. One-Time Operation: RPMB key programming can only be done once per device
  2. Irreversible: If you make an error, the device cannot be recovered
  3. Security Risk: Manual key derivation may not include all the security safeguards of the factory mode
Alternative Approach
Given the complexity and risks involved, I strongly recommend using the two-image factory/production approach:
This approach provides proper automation and security controls for the critical one-time RPMB key programming operation.
Next Steps
For the specific HUK derivation algorithm and manual provisioning script, you would need to examine the OP-TEE source code or consult the OP-TEE documentation directly, as these low-level implementation details aren’t covered in the available Toradex documentation.
Would you like guidance on setting up the recommended factory/production image workflow instead?
Greetings @pfarre,
To address your original question:
Based on the variable name I assume you’re enabling Optee via our meta-toradex-security meta-layer, correct?
If that is the case, then the response from the AI should be accurate and is described in more detail in the in-repo documentation here: meta-toradex-security/docs/README-optee.md at scarthgap-7.x.y · toradex/meta-toradex-security · GitHub
As for your follow-up question. I believe you’re asking how exactly you can write the RPMB key yourself to the device, correct?
In the case of factory mode we rely on the Optee software to do the programming. For your case, it seems like you want to write keys as a separate step?
There is a blog here about RPMB in general including programming keys: RPMB, a secret place inside the eMMC - sergioprado.blog
This was written by the developer who added the RPMB Optee support to our meta-layer so it should be very relevant.
@ToradexAI
is the writing of the RPMB key done by optee code in u-boot, the kernel or code in the rootfs?
RPMB Key Programming Location
Based on the available documentation, the RPMB key programming in OP-TEE occurs in the OP-TEE OS (Trusted Execution Environment) itself, not in U-Boot, the kernel, or rootfs code.
Technical Implementation Details
The OP-TEE implementation uses platform-specific hooks to control when RPMB key programming is allowed. The documentation indicates that OP-TEE includes a software hook, plat_rpmb_key_is_ready(), which platforms can use to enforce security logic.
For iMX-based devices like your Colibri iMX7D, the RPMB key cannot be written unless secure boot is enabled. This behavior can be modified by overriding the plat_rpmb_key_is_ready() function in the core/drivers/imx_snvs.c file of the OP-TEE OS source code.
When Key Programming Occurs
The key programming happens when OP-TEE is running in the Trusted Execution Environment (TEE), which occurs after U-Boot has loaded OP-TEE but before or during Linux kernel execution. The OP-TEE OS handles the actual RPMB communication and key derivation from the Hardware Unique Key (HUK).
Configuration Variables
The behavior is controlled by the TDX_OPTEE_FS_RPMB_MODE variable:
  • factory: OP-TEE is configured to program the RPMB key derived from the SoC’s HUK
  • production: OP-TEE assumes the RPMB key has already been programmed
Boot Sequence Context
In the boot sequence, this occurs:
  1. U-Boot loads and starts OP-TEE OS (1)
  2. OP-TEE OS runs in the secure world and can access hardware security features
  3. OP-TEE handles RPMB key programming (if in factory mode)
  4. Linux kernel starts in the normal world
  5. tee-supplicant in rootfs communicates with OP-TEE for ongoing RPMB operations
The actual key programming is handled by OP-TEE OS code running in the secure world, not by U-Boot, kernel, or userspace applications.
@ToradexAI
more specific my question is : do i need to update all parts of the system when going from “factory” to “production” mode or could i just update one part either u-boot the fitImage or the rootfs?
Unfortunately, I don’t have specific information in the available sources about which exact components need to be updated when transitioning from “factory” to “production” mode for OP-TEE RPMB configuration.
What We Know About the Configuration
The TDX_OPTEE_FS_RPMB_MODE variable controls the RPMB behavior at the OP-TEE level, but the available documentation doesn’t specify exactly which parts of the system (U-Boot, FIT image, or rootfs) contain the mode-specific configuration.
Key Considerations
Since OP-TEE runs as part of the secure world and is typically loaded by U-Boot (1), the configuration might be embedded in:
  • The OP-TEE OS binary itself (part of the FIT image)
  • U-Boot environment variables (1)
  • Runtime configuration in the rootfs
Recommendation
Given the critical nature of RPMB key programming (which can only be done once per device) and the lack of specific documentation about partial updates, I strongly recommend updating the complete system image when transitioning from factory to production mode.
This ensures:
  • All components are synchronized
  • No configuration mismatches occur
  • The transition is reliable and secure
Next Steps
For the specific implementation details about which components contain the RPMB mode configuration, you might want to examine the meta-toradex-security layer source code or consult the OP-TEE documentation directly.
Could you share more details about your deployment constraints that make partial updates preferable? This would help me provide more targeted guidance for your specific use case.
As per the Optee documentation: Secure storage — OP-TEE documentation documentation
They are handled by the tee-supplicant process which further relies on the kernel’s ioctl() interface to access the device. ``
Which tells me the kernel is what is being relied upon for the key programming, if done through Optee.
What is your use-case exactly? Do you want to field-update the device so that it programs the RPMB key in-field? That’s not a use-case we specifically have thought about, or designed for.
The factory mode will program the key during device flashing/provisioning via optee. The production mode assumes the device has already been programmed, or provisioned with the key by some other process prior.
Hi Jeremias,
just trying to get as few steps and time in production as possible.
Also not sure how to runtime verify what flags optee was built with so far only difference is dmesg
caam_jr 30903000.jr: using insecure test key, enable HAB to use unique device key!
is only shown at first boot.
Paul
I don’t believe there is a way to verify every specific options optee was built with, at least at runtime. Would probably need to patch optee in some way to make it more verbose.
What kind of information were you hoping to be able to see at runtime? Perhaps I can pass this to our team as a suggestion for them to consider.
mainly for a script to check if its developmen, factory or production OPTEE
mvh. Paul
I’ll go ahead and forward this suggestion to our team for consideration.
Otherwise it sounds like you’re still trying to determine which mode (factory or production) would be best for your product, correct? Is there any questions you have that maybe we could help answer that would help with this decision?
factory mode is not recommended for devices in the field, so we want to end up with production-mode. The reason for the script to determine the mode would be for it to trigger an automatic update from factory to production-mode while the device is still in our production enviroment.
But we also need to run YOCTO twice with a manual edit of the optee build flags to generate images for factory and production-mode - it would be nice if that could be avoided. I have looked into YOCTO multiconfig but as far as i can determine it needs two target names and that clashes with include and recipe file naming - it has to be colibri-imx7-emmc.
Further investiation into the difference of factory and production-mode points to optee-os:
So far i found two compile time flags:
CFG_RPMB_WRITE_KEY
CFG_RPMB_TESTKEY
both are inside
optee-os/4.4.0.imx/git/core/tee/tee_rpmb_fs.c
so at the moment building twice seems to be the way and the deices need to boot factory mode image once and the upgrade to production-mode in a second step.
Best Regards - Paul
Just to clarify, it’s still not clear to me why knowing the TDX_OPTEE_FS_RPMB_MODE at runtime would be helpful in the case you describe.
What I imagine is a production programming pipeline where first the factory image is flashed to the device first as it should be. In the next stage of the pipeline the production image is then deployed to the device.
If we’re always going in the order of factory image to production image, and this pipeline is sequential. Then, why would you need to know what the TDX_OPTEE_FS_RPMB_MODE is at runtime?
It should be simple to determine what is the mode of the device depending on where it is in this pipeline, right?
Perhaps I’m still not understanding something correctly here. Is the root of your problem needing to know what TDX_OPTEE_FS_RPMB_MODE is at runtime? Or is the actual problem something else?
