I am trying to compile embedded linux with mesa package. i am able to generate image(core-image-x11) and sdk. but opengl lib and include header files are not found in sysroot. mesa recipe is available in meta/recipes-graphics. how to add openg(libGL.so) lib in sdk and rootfs. is there any alternative way to compile mesa library for imx.
we are using Colibri iMX7d with Voila plus.
Bala
Hi @balakumaran
Welcome to Toradex Community.
Could you provide the hardware and software versions of your setup? Have you checked our reference-multimedia-image?
Hardware setup:
Colibri iMX7 Dual 512MB
Voila plus 1.1
Software setup:
Host Machine: ubuntu 20.04.
Actually libGL.so is found in rootfs(tmp/work/aarch64-poky-linux/core-image-x11/1.0-r0/rootfs/usr/lib). but not able to find in sdk.
Hi @balakumaran
Add the following line to the local.conf file and build again.
DISTRO_FEATURES_append = " opengl"
Hi @ashok.tx
Thank you for input.
I added DISTRO_FEATURES_append = " opengl" in local.conf file. It is throwing following error when starting bitbake server.
admin@admin:~/poky/build$ bitbake core-image-x11
ERROR: Variable DISTRO_FEATURES_append contains an operation using the old override syntax. Please convert this layer/metadata before attempting to use with a newer bitbake.
Hi @balakumaran
Hope you have followed oecore/yocto article?Have you done any chabnges in local.conf/layers?
