I build a custom image with openembeded and eyerything was fine. Then I changed my machine-configuration to build a realtime-kernel like described here. Since that do_imagedeploy failes to rename a not existing file:
ERROR: grimme-minimal-0.1-r0 do_imagedeploy: Function failed: do_imagedeploy (log file is located at /home/dietmar/oe-core/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/grimme-minimal/0.1-r0/temp/log.do_imagedeploy.27071)
ERROR: Logfile of failure stored in: /home/dietmar/oe-core/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/grimme-minimal/0.1-r0/temp/log.do_imagedeploy.27071
Log data follows:
| DEBUG: Executing shell function do_imagedeploy
| Image Name: Flash Apalis/Colibri module
| Created: Mon Dec 3 10:17:08 2018
| Image Type: PowerPC Linux Script (uncompressed)
| Data Size: 4193 Bytes = 4.09 KiB = 0.00 MiB
| Load Address: 00000000
| Entry Point: 00000000
| Contents:
| Image 0: 4185 Bytes = 4.09 KiB = 0.00 MiB
| Data Size: 3953 Bytes = 3.86 KiB = 0.00 MiB
| Contents:
| Image 0: 3945 Bytes = 3.85 KiB = 0.00 MiB
| Data Size: 646 Bytes = 0.63 KiB = 0.00 MiB
| Contents:
| Image 0: 638 Bytes = 0.62 KiB = 0.00 MiB
| Data Size: 380 Bytes = 0.37 KiB = 0.00 MiB
| Contents:
| Image 0: 372 Bytes = 0.36 KiB = 0.00 MiB
| Data Size: 243 Bytes = 0.24 KiB = 0.00 MiB
| Contents:
| Image 0: 235 Bytes = 0.23 KiB = 0.00 MiB
| /home/dietmar/oe-core/build/../deploy/images/colibri-imx6/imx6dl-colibri-aster.dtb
| /home/dietmar/oe-core/build/../deploy/images/colibri-imx6/imx6dl-colibri-cam-eval-v3.dtb
| /home/dietmar/oe-core/build/../deploy/images/colibri-imx6/imx6dl-colibri-eval-v3.dtb
| /home/dietmar/oe-core/build/../deploy/images/colibri-imx6/uImage--4.9-1.0.x+git0+3bb6e3284a-r0-imx6dl-colibri-aster-20181203095544.dtb
| /home/dietmar/oe-core/build/../deploy/images/colibri-imx6/uImage--4.9-1.0.x+git0+3bb6e3284a-r0-imx6dl-colibri-cam-eval-v3-20181203095544.dtb
| /home/dietmar/oe-core/build/../deploy/images/colibri-imx6/uImage--4.9-1.0.x+git0+3bb6e3284a-r0-imx6dl-colibri-eval-v3-20181203095544.dtb
| /home/dietmar/oe-core/build/../deploy/images/colibri-imx6/uImage-imx6dl-colibri-aster.dtb
| /home/dietmar/oe-core/build/../deploy/images/colibri-imx6/uImage-imx6dl-colibri-cam-eval-v3.dtb
| /home/dietmar/oe-core/build/../deploy/images/colibri-imx6/uImage-imx6dl-colibri-eval-v3.dtb
| mv: cannot stat ‘/home/dietmar/oe-core/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/grimme-minimal/0.1-r0/grimme-minimal_0.1.0/rootfs/../colibri-imx6_bin/u-boot-colibri-imx6.img’: No such file or directory
| ERROR: Function failed: do_imagedeploy (log file is located at /home/dietmar/oe-core/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/grimme-minimal/0.1-r0/temp/log.do_imagedeploy.27071)
ERROR: Task (/home/dietmar/oe-core/build/../layers/meta-grimme/recipes/grimme-minimal.bb:do_imagedeploy) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2543 tasks of which 2493 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
I reverted my changes but still got the same error.
After I changed the U-Boot-extension like here I was able to build the image but now the update.sh failes because it depends on the old filename:
$ ./update.sh -o /media/dietmar/DC31-C3EB/ -m 2
Colibri iMX6 rootfs specified
colibri-imx6_bin/u-boot.img does not exist
What is wrong?
Why is u-boot-colibri-imx6.img not built anymore?
Is there a way to get rid of that without removing and rebuilding the deploy- and build-trees what will take half the night?
What exact Linux distribution and flavour thereof are you running on your build machine? Are you running a regular bash shell? Any other exotic configuration?
Wow, I thought 64-bit build machines are long since mandatory for OpenEmbedded builds. At least more complex builds involving Qt and such are definitely no longer possible on 32-bit. Nothing against VMware but I guess that also does not increase on the beefiness of a build machine.
Anyway, did you also update from an older BSP version to a later one? As we did change the U-Boot configuration at some point. You may find this documented here.
I had something like this happen to me before. Check you available recipes and layer setup:
bitbake-layers show-recipes
bitbake-layers show-layers
You want to make sure you select the right U-boot to go with mainline kernel. For me, I think I had to setup the PREFERRED_PROVIDER_u-boot = in the machine.conf. Mine looks like this, but you will need the right platform and layers setup to match your machine:
Note that u-boot.img would be new while u-boot.imx-spl would be older and u-boot.imx the oldest.
I believe that you copied some recipes/files into your own layer and then updated the other layers to something later which now causes this.
Delete all U-Boot output to start on a clean plate: bitbake -c cleansstate virtual/bootloader
Try to build an image for on of our regular machines to see if your installation can produce a working image.
MACHINE=colibri-imx6 bitbake console-tdx-image
Assuming that works I would compare:
the u-boot-toradex recipe to the one you are using in your layer, assuming you did actually provide your own u-boot recipe
the colibri-imx6 machine configuration files to your custom machine configuration.
build your u-boot and check what files are actually deployed into oe-core/deploy/images//u-boot*
Max
P.S.:
I guess the following two commits changed the behaviour.
Meanwhile, after I got u-boot be build as u-boot.img but the the kernel as uImage instead of zImage, I got it using the following machine configuration:
I get my kernel modules compiled and deployed (there is a tarball “modules-colibri-imx6.tgz” in deploy/images/colibri-imx6) but not integrated into the rootfs.
MACHINE_EXTRA_RRECOMMENDS = “kernel-modules”
to my machine config: no effect
I included imx-base.inc in my machine config with the only effect to get a coulpe of warnings about duplicate inclusions.
In the contless configuration files I found nothing that deletes my MACHINE_EXTRA_RRECOMMENDS, there is only appended to it or set to empty as default.
the -e option is a little bit scary because it creates about 2MB of output, but it helps.
I found this:
# $NO_RECOMMENDATIONS [2 operations]
# set /home/dietmar/oe-core/build/../layers/openembedded-core/meta/conf/documentation.conf:291
# [doc] "When set to '1', no recommended packages will be installed. Realize that some recommended packages might be required for certain system functionality, such as kernel-modules. It is up to the user to add packages to IMAGE_INSTALL as needed."
# set? /home/dietmar/oe-core/build/../layers/openembedded-core/meta/conf/bitbake.conf:828
# pre-expansion value:
NO_RECOMMENDATIONS=""
I added
IMAGE_INSTALL += "kernel-modules"
to my recipe and now it works.
Thanks.
Now I move to the next construction area: kernel and device-tree.
