Openembedded: Disable sshd.socket in Linux Image
I am trying to close all the ports on the default imx6 Linux 2.7b4 Image. By default sshd.socket service is enabled which opens port 22.
How can I disable sshd.socket in openembedded build ?
Hi @Darion!
If you’re not using SSH at all, you could remove the openssh package from your build.
Alternatively, you could follow these instructions which deal with the same issue.
Gustavo.
Hi @gustavo.tx
I plan on using ssh but just not enabled all the time.
How can I disable sshd.socket ?
HI @Darion
You can temporarily disable and enable sshd socket like this:
systemctl stop sshd.socket
systemctl start sshd.socket
Hey @jaski.tx
I have running custom services on Linux. I am having them installed and disabled in the Linux Image using the following command:
SYSTEMD_AUTO_ENABLE_servicename = “disable”
Is there anything like this for sshd.socket service which can be used to disable in the Linux Image ? I want the service installed though.
Hi
You can disable a service in Systemd like this:
systemctl disable service-name
