The build of the angstrom-lxde-image as descibed here fails with the following error:
DEBUG: Executing shell function do_install
NOTE: make -j 4 CERTSDIR=/local/home/user/3rdparty/toradex/oe-core/build/out-glibc/sysroots/x86_64-linux/usr/share/ca-certificates SBINDIR=/local/home/user/3rdparty/toradex/oe-core/build/out-glibc/sysroots/x86_64-linux/usr/sbin DESTDIR=/local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/image install
for dir in mozilla spi-inc.org; do \
mkdir /local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/image//local/home/user/3rdparty/toradex/oe-core/build/out-glibc/sysroots/x86_64-linux/usr/share/ca-certificates/$dir; \
make -C $dir install CERTSDIR=/local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/image//local/home/user/3rdparty/toradex/oe-core/build/out-glibc/sysroots/x86_64-linux/usr/share/ca-certificates/$dir; \
done
make[1]: Entering directory '/local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/git/mozilla'
for p in *.crt; do \
install -m 644 $p /local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/image//local/home/user/3rdparty/toradex/oe-core/build/out-glibc/sysroots/x86_64-linux/usr/share/ca-certificates/mozilla/$p ; \
done
make[1]: Leaving directory '/local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/git/mozilla'
make[1]: Entering directory '/local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/git/spi-inc.org'
install -m 644 $p /local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/image//local/home/user/3rdparty/toradex/oe-core/build/out-glibc/sysroots/x86_64-linux/usr/share/ca-certificates/spi-inc.org/$p ; \
done
make[1]: Leaving directory '/local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/git/spi-inc.org'
for dir in sbin; do \
done
make[1]: Entering directory '/local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/git/sbin'
install -d /local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/image/local/home/user/3rdparty/toradex/oe-core/build/out-glibc/sysroots/x86_64-linux/usr/sbin
install -m755 update-ca-certificates /local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/image/local/home/user/3rdparty/toradex/oe-core/build/out-glibc/sysroots/x86_64-linux/usr/sbin/
make[1]: Leaving directory '/local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/git/sbin'
Updating certificates in /local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/image/local/home/user/3rdparty/toradex/oe-core/build/out-glibc/sysroots/x86_64-linux/etc/ssl/certs...
WARNING: /local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/temp/run.do_install.26760:1 exit 1 from
SYSROOT="/local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/image/local/home/user/3rdparty/toradex/oe-core/build/out-glibc/sysroots/x86_64-linux" /local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/image/local/home/user/3rdparty/toradex/oe-core/build/out-glibc/sysroots/x86_64-linux/usr/sbin/update-ca-certificates
ERROR: Function failed: do_install (log file is located at /local/home/user/3rdparty/toradex/oe-core/build/out-glibc/work/x86_64-linux/ca-certificates-native/20150426-r0/temp/log.do_install.26760)
It seems like there is a faulty concatenation of several directory paths, e.g. line 4:
There should be a whitespace between the slashes in “…image//local”. And my guess is that “$dir” should have been expanded.
