I have successfully added additional ubi volume to image by adding entry to image.json file.
That’s was done by hand so my question is what is the right way to add additional ubi volue to image.json file inside build process? Can I somehow append custom ubi volume to data[“blockdevs”] variable?
I have checked image_type_tezi.bbclass but did’t came up with solution yet..
Greetings and thank you for writing to Toradex Community!
There is a way to modify the UBI volumes while building the image by modifying the .bbclass and here I found a blog that modifies the UBI image that way: yocto | Arkadiusz Marud
