Dear Support Team,
we are testing Opencv 3.3 function on Apalis iMX6 under latest Linux BSP v2.8b5 according to below developer articles, and met some issue making the sample code running on Apalis imx6, detailed information is as below, could you help on this?
add opencv support to linux bsp v2.8b5, have tried both opkg and openembedded way as below:
./ opkg wayroot@apalis-imx6:~# opkg update
root@apalis-imx6:~# opkg install opencv
./ openembedded way
a. add opecv and qt support to local.conf file IMAGE_INSTALL_append = " opencv tslib tslib-calibrate tslib-tests qtserialbus qtserialport qtwebengine qtwebengine-dev" PACKAGECONFIG_append_pn-qtbase = " tslib sql-sqlite linuxfb" PACKAGECONFIG_append_pn-qtmultimedia = " gstreamer"b. patch the opencv_3.3.bb file as below
— a/layers/meta-openembedded/meta-oe/recipes-support/opencv/opencv_3.3.bb 2019-03-04 16:54:14.478234788 +0800
+++ b/layers/meta-openembedded/meta-oe/recipes-support/opencv/opencv_3.3.bb 2019-03-04 17:08:42.423893780 +0800
@@ -78,9 +78,8 @@
EXTRA_OECMAKE_append_x86 = " -DX86=ON"-PACKAGECONFIG ??= "python3 eigen jpeg png tiff v4l libv4l gstreamer samples tbb gphoto2 \
- ${@bb.utils.contains(“DISTRO_FEATURES”, “x11”, “gtk”, “”, d)} \
- ${@bb.utils.contains(“LICENSE_FLAGS_WHITELIST”, “commercial”, “libav”, “”, d)}"
+PACKAGECONFIG ??= "python3 eigen jpeg png tiff v4l libv4l gstreamer samples tbb gphoto2 libav \
- ${@bb.utils.contains(“DISTRO_FEATURES”, “x11”, “gtk”, “”, d)}"
PACKAGECONFIG[amdblas] = “-DWITH_OPENCLAMDBLAS=ON,-DWITH_OPENCLAMDBLAS=OFF,libclamdblas,”
PACKAGECONFIG[amdfft] = “-DWITH_OPENCLAMDFFT=ON,-DWITH_OPENCLAMDFFT=OFF,libclamdfft,”
@@ -192,3 +191,5 @@
cp -f bin/-tutorial- bin/-example- ${D}${datadir}/OpenCV/samples/bin/
fi
+CXXFLAGS += " -Wa,-mimplicit-it=thumb" -
compile the sample code in the developer article with the SDK compiled from above oe configuration, the source file and make file is in the attachment.
link text
3. run the binary app on apalis imx6 under either official v2.8b5 image with opkg way or openembedded way image got the same issue as below:
root@apalis-imx6:~# ./facedetect
VIDEOIO ERROR: V4L: device v4l2:///dev/video3: Unable to query number of channels
[ 874.462777] usb 1-1.1.3: reset high-speed USB device number 4 using ci_hdrc
[ 874.837488] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 874.844194] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 874.850734] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 875.002212] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 875.008136] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 875.014488] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[INFO] Product Info: i.MX6Q/D/S
display(/dev/fb0) resolution is (1920x1080).
[ 875.881909] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 875.888105] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 875.894321] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
(facedetect:1398): GStreamer-CRITICAL **: gst_element_link_pads_full: assertion 'GST_IS_ELEMENT (dest)' failed
OpenCV Error: Unspecified error (GStreamer: cannot link color -> sink
) in cvCaptureFromCAM_GStreamer, file /usr/src/debug/opencv/3.3+gitAUTOINC+87c27a074d_2a9d1b22ed_a62e20676a_34e4206aef_fccf7cd6a4-r0/git/modules/video
io/src/cap_gstreamer.cpp, line 816
VIDEOIO(cvCreateCapture_GStreamer (CV_CAP_GSTREAMER_FILE, filename)): raised OpenCV exception:
/usr/src/debug/opencv/3.3+gitAUTOINC+87c27a074d_2a9d1b22ed_a62e20676a_34e4206aef_fccf7cd6a4-r0/git/modules/videoio/src/cap_gstreamer.cpp:816: error: (
-2) GStreamer: cannot link color -> sink
in function cvCaptureFromCAM_GStreamer
ERROR: Could not access the camera!
4. the attached usb camera is /dev/video3
root@apalis-imx6:~# v4l2-ctl --list-devices
[ 2009.637361] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 2009.643685] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 2009.649534] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
DISP3 BG ():[ 2009.747259] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
/dev/video16
/dev/video17
UVC Camera (046d:081b) (usb-ci_hdrc.1-1.1.3):
/dev/video3
Failed to open /dev/video0: Resource temporarily unavailable
