I use Toradex Analogue Camera Adapter (ACA) to connect Camera to Ixora V1.1A board and I can display the video input frames with gstreamer piplines. My camera has PAL video output.
I tested the OpenCV Example but I have these output after run the program:
[ 2783.943654] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 2783.950237] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
OpenCV Error: Unspecified error (GStreamer: unable to start pipeline
) in cvCaptureFromCAM_GStreamer, file /usr/src/debug/opencv/3.3+gitAUTOINC+87c27a074d_2a9d1b22ed_a62e20676a_34e4206aef_fccf7cd6a4-r0/git/modules/videoio/src/cap_gstreamer.cpp, line 881
VIDEOIO(cvCreateCapture_GStreamer (CV_CAP_GSTREAMER_FILE, filename)): raised OpenCV exception:
/usr/src/debug/opencv/3.3+gitAUTOINC+87c27a074d_2a9d1b22ed_a62e20676a_34e4206aef_fccf7cd6a4-r0/git/modules/videoio/src/cap_gstreamer.cpp:881: error: (-2) GStreamer: unable to start pipeline
in function cvCaptureFromCAM_GStreamer
ERROR: Could not access the camera!
I only change these lines before make:
//these part commented out
//if (!face_cascade.load( face_cascade_name ) ) {
//printf("--(!)Error loading training file: haarcascade_frontalface_alt2.xml\n");
//return -1;
try {
capture.open("v4l2:///dev/video3"); //video3 changed to video0
capture.set(CV_CAP_PROP_FRAME_WIDTH, 640); //640 changed to 720
capture.set(CV_CAP_PROP_FRAME_HEIGHT, 480); //480 changed to 576
Thanks for the dmesg log.
Which changes have you done to the local.conf when you compiled the custom Linux? Which SDK did you use to compile the opencv example?
root@apalis-imx6:~# ls /dev | grep video
video0
video1
video16
video17
video18
video19
video2
video20
root@apalis-imx6:~# v4l2-ctl --all -d /dev/video3
Failed to open /dev/video3: No such file or directory
Thanks for the Input. What is the output of v4l2-ctl --list-devices?
And what is the output of v4l2-ctl -d /dev/video* where for * you put the number which got from the list devices command?
