I am testing OpenCL on Colibri iMX8X with the demo from imx-gpu-sdk. Below is the demo and its description from L4.9.123_2.3.0 i.MX Linux User’s Guide.
• cl11: This contains unit tests and FFT samples for OpenCL 1.1 Embedded Profile. OpenCL is implemented on the i.MX 6Quad, i.MX 6QuadPlus, and i.MX 8 boards.
The result is :
root@colibri-imx8qxp:/opt/viv_samples/cl11/fft# ./fft 1024
Block size: 16
Print result: yes
Initializing device(s)...
[ 1] Failed to open device: No such file or directory, Try again...
[ 2] Failed to open device: No such file or directory, Try again...
[ 3] Failed to open device: No such file or directory, Try again...
[ 4] Failed to open device: No such file or directory, Try again...
[ 5] _OpenDevice(1229): FATAL: Failed to open device, errno=No such file or directory.
Another OpenCL application clFFT also has the same issue. However, GC7000L dose support OpenCL 1.1/1.2. Is the OpenCL not available with L4.9.123 or this A0 version silicon ?
Thanks!
