I am doing some developement with a colibri PXA310 running windows CE6.
I want to open the com 5 to conect with a modem on rasmode so the DTR have to be open.
The problem appeares when the program is running the com isn’t open. So, anybody know how to do this in this system ?
To be more clear, i’m using toradex library to open and configure gpios. i try to do it with gpiolib.
any code to be more specific, this is what i’m doing to open gpio’s but it does not workin…
[ I reformatted your previous message for better understanding. Please do a quick check whether I didn’t mess it up, and complain if I did ]
I don’t see any obvious mistake. I recommend you start the GpioConfig Tool , step through your code and verify line by line that it behaves as expected.
For a first test, you can also use the GpioConfig Tool to set up the pin configurations without code.
Is it posible the colibri don’t open the serial port because i have the debug traces activated?
I read in some documentation about this but i am not sure if this is applicable in my system.
I have activated all level traces to debug my application.
Anybody know something about that?
