Open-AI with python
Dear community,
We want to include in our image the openai package for python and we can’t find any way. We are using YOCTO and your BSP 6.3.
We have installed the package using PIP and everything works correctly, but this is not an option because our system is read-only.
Any ideas?
Julián
Hello Julián,
To include the OpenAI package for Python in your Yocto Project build for a read-only system, you’ll need to create a custom recipe that fetches and installs the package into your image during the build process. Since you are using BSP 6.3, here’s a general approach to achieve this:
  1. Create a Custom Layer: If you haven’t already, create a custom layer in your Yocto Project setup to hold your custom recipes. This keeps your customizations separate from the default layers provided by Toradex.
  2. Write a Bitbake Recipe for OpenAI: You need to create a new recipe for the OpenAI Python package. This recipe will specify how to fetch, compile (if necessary), and install the package into your image. Here’s an example of what the recipe (python-openai_1.0.bb) might look like:
SUMMARY = "OpenAI Python package"
SECTION = "devel/python"
LICENSE = "CLOSED"
inherit pypi setuptools
PYPI_PACKAGE = "openai"
RDEPENDS_${PN} += " \
    python3-core \
    python3-setuptools \
    python3-pip \
do_install_append() {
    # Ensure the package is installed into the image's site-packages directory
    oe_runpip install --root ${D} ${S}
This is a simplified example. Depending on the OpenAI package dependencies, you might need to add more to the RDEPENDS_${PN} variable or adjust the installation command.
  1. Add the Package to Your Image: Once the recipe is created, you need to add the package to your image. Modify your image recipe or the local.conf file to include the OpenAI package:
IMAGE_INSTALL_append = " python-openai"
  1. Build Your Image: With the recipe in place and the package added to your image configuration, you can now build your Yocto Project image. The build process should fetch the OpenAI package, build it (if necessary), and include it in your read-only system image.
  2. Testing: After the build completes, deploy the image to your target device and verify that the OpenAI package is correctly installed and functional.
This approach allows you to include Python packages directly in your Yocto Project builds, making them part of the read-only system image and eliminating the need for runtime installation via PIP.
Torad
Python in Linux | Toradex Developer Center.
Hi @ToradexAI,
Thank you very much for your answer :wink:, I tried what you said and it gives an error with the setuptools package :pleading_face:.
Could not inherit file classes/setuptools.bbclass
Hello @jbruno,
The answer from the @ToradexAI is likely not too far from what is actually needed to add a python-openai recipe to your Yocto build.
I am looking into this topic, but here are some preliminary findings:
  • The suggested do_install_append is incorrect and not needed.
  • Instead of inheriting the setuptools class, python_setuptools_build_meta should be used.
  • Some runtime dependencies still need to be resolved, such as python3-pandas.
When I have further updates I will send them here.
Bruno
Hello @jbruno,
I did some more research and tests and installing this package with Yocto will not be a very easy task but should be possible.
You will need to make sure that the build system used by the openai-python package is available in Yocto.
Looking at the project’s pyproject.toml, you can see that the used build system is hatchling:
[build-system]
requires = ["hatchling", "hatch-fancy-pypi-readme"]
build-backend = "hatchling.build"
Unfortunately the support for this build system is not available by default.
It could be added, but would require some work.
The following are some useful examples which could be helpful in this process:
Bruno
HI @bruno.tx,
Our version of YOCTO does not support those packages. We are trying to install one by one the openai-python requirements and we have copied the openai-python repository to a compressed file. When we have something clear we will share it in this post.
Thank you very much for the information.
Julián
Dear @bruno.tx ,
We have been doing a lot of testing and have not been able to come up with a reasonable solution. Have you come up with a solution? Does this problem disappear in BSP 7.X?
Any comments will be of great help.
Julián
Hello @jbruno,
We have not investigated this topic, as it is related to integration of custom packages into our Yocto BSP which is specific to your application.
It is possible that a newer BSP has more of the needed dependencies from the upstream layers.
I would recommend that you check OpenEmbedded’s layer index to confirm this: OpenEmbedded Layer Index - layers
Otherwise, I can also recommend using Torizon OS with Docker containers, which would allow a simpler workflow to create containers with the required python packages.
You could still customize this image with Yocto if needed, but the currently blocking issue of using the OpenAI python package could be done in a container.
If you want to go the Yocto route and are stuck, we can recommend partners that would be able to customize a BSP to fit your application’s needs.
Bruno
