Here’s a puzzler. gst-inspect-1.0 lists the omxh264enc video encoder just fine, but when I try to launch a pipeline, I get the following errors for the omxh264enc video encoder:
OMX-Component not found with current ST static component loader.
ERROR: from element /GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0: Could not initialize supporting library.
../gst-plugins-base-1.16.3/gst-libs/gst/video/gstvideoencoder.c(1636): gst_video_encoder_change_state (): /GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0:
Failed to open encoder
Here’s my gstomx.conf:
[omxh264enc]
type-name=GstOMXH264Enc
core-name=/usr/lib/libomxil-bellagio.so.0
component-name=OMX.mesa.video_encoder.avc
rank=0
in-port-index=0
out-port-index=1
When I attempt to do omxregister-bellagio -v
, here’s what I get:
Scanning directory /usr/lib/bellagio/
Scanning library /usr/lib/bellagio/libomxclocksrc.so
Component OMX.st.clocksrc registered with 0 quality levels
Specific role OMX.st.clocksrc registered
Scanning library /usr/lib/bellagio/libomxaudio_effects.so
Component OMX.st.volume.component registered with 2 quality levels
Specific role OMX.st.volume.component registered
Component OMX.st.audio.mixer registered with 1 quality levels
Specific role OMX.st.audio.mixer registered
Scanning library /usr/lib/bellagio/libomxvideosched.so
Component OMX.st.video.scheduler registered with 2 quality levels
Specific role OMX.st.video.scheduler registered
4 OpenMAX IL ST static components in 3 libraries succesfully scanned
It doesn’t even recognize the libomxil-bellagio.so.0 library because it’s scanning a different directory. So, when I pass it the component path to scan ( /usr/lib
), I get this:
Scanning library /usr/lib/libelf-0.178.so
0 OpenMAX IL ST static components in 0 libraries succesfully scanned
So the issue appears to be that the omxh264component isn’t registering with omxregister-bellagio
Here’s the pipeline I was attempting:
gst-launch-1.0 -v videotestsrc num-buffers=100 ! video/x-raw,width=1920,height=1080,framerate=30/1 ! videoconvert ! omxh264enc ! autovideosink
When I do grep "omxh264enc" /usr/lib/libomxil-bellagio.so.0
, I get nothing. When I do grep "omxh264enc" /usr/lib/gstreamer-1.0/libgstomx.so
I get
omxh264enc
../gst-omx-1.16.3/omx/gstomxh264enc.c
When I update gstomx.conf
to point to libgstomx.so
, I still get the Could not initialize supporting library
error for the encoder.
Any thoughts?
