Toradex Easy Installer 5.4.0 is the last version that supports the V1.0B early access module. It should work to still use it, however we implemented a compatibility mode in the Easy Installer which will only try for 1s to download the Easy Installer to V1.0B module after calling recovery-windows.bat. Make sure to follow this guide to make it work:
Put your module into recovery mode (keep recovery pressed for >10s until it shows up in device-manager as NXP recovery device)
After you see it being in recovery-mode in device-manager you can call the recovery-windows.bat
You can still use your module with BSP version up to 5.4.0, however we do no longer release software for it going forward.
I confirm the problem is solved !
The order matters for version V1.0B , first recovery mode then recovery script
My bad habits: on iMX8QXP always start first recovery script then turn on device in recovery mode Everything is clear
