Offline updates not detecting lockbox
I am running a custom image with torizoncore 6.3 build 4 as the base. With this image I am including an application bundle via a docker-compose file and provisioning with a shared-data file in offline mode. see below the provisioning section of my tcbuild.yaml file.
I am following this guide for setting up offline updates with torizon: How to Use Secure Offline Updates with Torizon OS | Toradex Developer Center
I can confirm that actualizr is running with offline updates via journalctl:
I am using this 99-offline-updates.toml file:
[uptane]
enable_offline_updates =  true
enable_online_updates = false
offline_updates_source = "/media/'USB DISK'/update"
when I plug in my usb I can confirm the offline_updates_source directory exists.
The update only contains an application update via docker-compose and contains two directories: images and metadata. The images directory contains a .images file and my docker-compose.lock file. The metadata directory contains: director, docker, image-repo
However, it seems that it is never initiating the update and is stuck looking for connections even if the directory exists and I am unsure why. Any help would be appreciated!
Thanks, Mike
Greetings @MikeHA,
I believe the issue here is that your path "/media/'USB DISK'/update" has a space in it. The way you have it defined here would probably not result in it being processed correctly by the update client. This would probably explain why it’s not being detected.
I would suggest just not having a space in the path if possible as having a space could cause more issues and complications going forward.
Hey Jeremias,
that seemed to fix the detection issue now I am running into another issue during the update upload. See below image for the result of journalctl -f -u aktualizr*. Three errors seem to pop out to me:
“Unable to read filesystem statistics: error code -l”
“curl error 60 (http code 0): SSL peer certificate or SSH remote key was not OK”
“Offline loading failed: Bad manifest type”
I am using docker images that used buildx to be made. I know that caused issues on the torizoncore-builder side of lockbox but that seemed to be fixed on that end is this a similar issue here?
Thanks, Mike
We did actually fix this in our update client as seen here: Handle OCI image type · toradex/aktualizr@5286b45 · GitHub
However, this fix did not make it into the 6.3.0 release that you are using. Therefore you should use a more recent image that should have this fix. Do note that our upcoming 6.4.0 release will have this fix.
Updating to the monthly 6.4 image seemed to do the trick.
Thanks for the help!
Glad I was able to help!
