Oak G sensor replacement
Toradexs OS Oak G 3-Axes Acceleration Sensors are not in production anymore. I need an USB accelerometer that is similar to the Toradexs. What would be advised to get? I know I can get one made and that the datasheet has been provided to do so however I don’t believe that this method will be convenient.
Based on the provided context, there is no specific information about a replacement for the Toradex OS Oak G 3-Axes Acceleration Sensors. The context does not mention any recommended USB accelerometers or alternatives. You may need to explore other sources or contact Toradex technical support for further assistance in finding a suitable replacement.
Build image without LXDE and Qt5 support.
Toradex doesn’t manufacture sell any Oak product anymore. If you still want to use it, you will have to use the available design data and produce it on your own.
Toradex has now placed the entire Oak product range into the hands of the open source community.
Please check for details here :
If you wish to get ready to use USB accelerometer there are lot of them available.
Any specific ready to use USB accelerometer you recommend?
Simply choose any USB accelerometer that meets your requirements.
