Hi!
I’m facing a similar issue than this post, but the proposed fixes doesn’t fix my problem. After flashing my device with NVIDIA’s rootfs, my device prints the following message several time and I cannot access logging prompt:
init: Failed to create pty - disabling logging for job
I know it’s a problem related to upstart which is mentioned in the release notes for L4T R16.5. I tried to modify my /etc/init/nv.conf by commenting the line and changing the “Y” for “N”.
# nv
description "NVIDIA specific init script"
start on started udev
task
script
# power state
if [ -e /sys/power/state ]; then
chmod 0666 /sys/power/state
fi
if [ -e /sys/module/cpu_tegra3/parameters/auto_hotplug ] ; then
#echo 1 > /sys/module/cpu_tegra3/parameters/auto_hotplug
fi
# lp2 idle state
if [ -e /sys/module/cpuidle/parameters/lp2_in_idle ] ; then
echo "N" > /sys/module/cpuidle/parameters/lp2_in_idle
fi
# mmc read ahead size
if [ -e /sys/block/mmcblk0/queue/read_ahead_kb ]; then
echo 2048 > /sys/block/mmcblk0/queue/read_ahead_kb
fi
if [ -e /sys/block/mmcblk1/queue/read_ahead_kb ]; then
echo 2048 > /sys/block/mmcblk1/queue/read_ahead_kb
fi
end script
However, these changes didn’t fix the problem and I don’t really know what to do next.
Here are the details about my setup:
- Colibri T30 v1.1B with Iris Board v2.0A
- Linux LXDE BSP 2.8.7 with L4T rootfs as described in this guide.
Any help would be appreciated.
