I was trying to follow the instruction of “Txx Recovery Mode” to update my newly purchased Apalis T30 from pre-installed linux to WinCE 2013. The process failed at “update.bat” (nvflash). It was hung at “sending file: loader.nb0”. Here is the full output:
Yes, the module is booting with Linux – even after the failed “update.bat”. My original post includes all the output from the command prompt (the same as in log file). The carrier board is Ixora. I was using Windows 10 installed on VMware Fusion hosted by iMac Pro. There are two USB ports used: one for USB-serial and one for APX. All drivers installed without any issue. One more interesting I have noticed during the trials is that, if I open command prompt and run nvflash.exe --configfile ce8.cfg --create --go directly instead of update.bat, I got a bit further (some bytes sent, but not all after sending file: loader.nb0. Here is the output:
It turns out the issue is with doing it from Windows 10 installed on VMWare – for whatever reason. I was able to flash the board from a pure windows PC.
Yes, the module is booting with Linux – even after the failed “update.bat”. My original post includes all the output from the command prompt (the same as in log file). The carrier board is Ixora. I was using Windows 10 installed on VMware Fusion hosted by iMac Pro. There are two USB ports used: one for USB-serial and one for APX. All drivers installed without any issue. One more interesting I have noticed during the trials is that, if I open command prompt and run “nvflash.exe --configfile ce8.cfg --create --go” directly instead of “update.bat”, I got a bit further (some bytes sent, but not all after “sending file: loader.nb0”. Here is the output:
