Hi Community,
I have issue with the last Nvflash Tool 2.6 and last WinCe image for T20 : v2.2.
APX Driver is ok and module is recognized.
Here is the output of the update.bat script.
Nvflash version 2.6 started
rcm version 0X20001
System Information:
chip name: t20
chip id: 0x20 major: 1 minor: 4
chip sku: 0x8
chip uid: 0x0000000000000000021ca145449fe3d7
macrovision: disabled
hdcp: enabled
jtag: enabled
sbk burned: false
dk burned: false
boot device: nand
operating mode: 3
device config strap: 0
device config fuse: 4128
sdram config strap: 0
Sending generated BCT...333Mhz Done
file not found: loader.nb0
command failure: bootloader download failed
As you can see loader.nb0 is not found… But it’s in the same folder of the bat and I’ve put a copy on the same folder of the ce6.cfg file. I don’t understand why this is not working.
Thanks a lot for your answers.
