I explain my need and what i have already done.
I need an NTSC video output for Apalis on a CVBS connector.
I use the AD723 chip from Analog device.
I update the file bellow for the kernel update :
~/linux-toradex/drivers/video/fbdev/mxc/mxc_vdacif.c
/* 3 640x480-60 VESA */
{ NULL, 60, 640, 480, 79364, 48, 16, 33, 10, 96, 2,
FB_SYNC_OE_LOW_ACT, FB_VMODE_INTERLACED, FB_MODE_IS_VESA },
The output of the AD723 is readable but awful.
The apalis show this error periodicaly :
[ 552.730680] imx-ipuv3 2800000.ipu: IPU Warning - IPU_INT_STAT_10 = 0x00080000
[ 552.730711] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=12600000 Hz
[ 552.779673] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=12600000 Hz
[ 552.829093] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=12600000 Hz
[ 552.879105] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=12600000 Hz
[ 552.945523] imx-ipuv3 2800000.ipu: IPU Warning - IPU_INT_STAT_10 = 0x00080000
The fbset give this information
mode "640x480-60"
# D: 12.600 MHz, H: 15.750 kHz, V: 60.001 Hz
geometry 640 480 640 480 16
timings 79364 48 16 33 10 96 2
laced true
rgba 5/11,6/5,5/0,0/0
endmode
My monitor has detected a 480i entry yesterday but does not detect anything today.
Where are my mistakes?
Regards
