Hi there,
I would like some help with out tensorflow python application where the Dockerfile.debug is working (NPU delegate is working and UINT8 model loaded) and running our camera at 20FPS. When trying to build a production image, the NPU delegate is not loaded and defaults to CPU making the camera inferencing run at 1FPS. I have posted the working Dockerfile.debug below and the not working Dockerfile also (all of the requirements.txt files and torizonPackages.json are the same). I believe the issue is the .venv and how the APP_ROOT dir is handled between them but I can’t quite figure it out.
Please help.
Kind regards,
btj2.
Dockerfile.debug:
ARGUMENTS --------------------------------------------------------------------
Board architecture
ARG IMAGE_ARCH=
Base container version
ARG BASE_VERSION=3.3.1-bookworm
Debug port
ARG DEBUG_SSH_PORT=
Run as
ARG SSHUSERNAME=
Directory of the application inside container
ARG APP_ROOT=
Build image ----------------------------------------------------------------
FROM --platform=linux/${IMAGE_ARCH} \
torizon/debian:${BASE_VERSION} AS Base
Install Python
RUN apt-get -y update && apt-get install -y
python3 python3-dev python3-numpy python3-pybind11
&& apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*
Install Pip and Wheel
python3-pip python3-setuptools python3-wheel
Install Build tools
cmake build-essential gcc g++ git wget unzip patchelf imx-gpu-viv-wayland-dev
I uncommented this section to build tensorflow lite from source ###4:38PM
libovxlib-dev libneuralnetworks libnnrt-dev
Prepare build output directory
COPY global_variables.sh global_variables.sh
Build nn-imx
COPY nn-imx_1.3.0.sh nn-imx_1.3.0.sh
RUN chmod +x nn-imx_1.3.0.sh && ./nn-imx_1.3.0.sh
Build tim vx
COPY tim-vx.sh tim-vx.sh
RUN chmod +x tim-vx.sh && ./tim-vx.sh
Build tensorflow lite
COPY tensorflow-lite_2.9.1.sh tensorflow-lite_2.9.1.sh
RUN chmod +x tensorflow-lite_2.9.1.sh && ./tensorflow-lite_2.9.1.sh
Build tflite vx delegate
COPY tflite-vx-delegate.sh tflite-vx-delegate.sh
RUN chmod +x tflite-vx-delegate.sh && ./tflite-vx-delegate.sh
Deploy image ---------------------------------------------------------------
commontorizon/debian:${BASE_VERSION} AS debug
ARG IMAGE_ARCH
ARG DEBUG_SSH_PORT
ARG APP_EXECUTABLE
ARG SSHUSERNAME
ENV APP_EXECUTABLE ${APP_EXECUTABLE}
ARG APP_ROOT
SSH for remote debug
EXPOSE ${DEBUG_SSH_PORT}
EXPOSE 6512
Make sure we don’t get notifications we can’t answer during building.
ENV DEBIAN_FRONTEND=“noninteractive”
your regular RUN statements here
Install required packages
RUN apt-get -q -y update &&
apt-get -q -y install
openssl
openssh-server
rsync
file
screen
python3-minimal
python3-pip
python3-setuptools
python3-venv
automate for torizonPackages.json
apt-get -q -y install \
DO NOT REMOVE THIS LABEL: this is used for VS Code automation
# __torizon_packages_dev_start__
python3-debugpy:arm64 \
python3-opencv:arm64 \
python3-libgpiod:arm64 \
python3-setuptools:all \
python3-pybind11:all \
python3-scipy:arm64 \
python3-psutil:arm64 \
lsof:arm64 \
v4l-utils:arm64 \
bc:arm64 \
python3-spidev:arm64 \
# __torizon_packages_dev_end__
apt-get clean && apt-get autoremove && \
Create virtualenv
RUN python3 -m venv ${APP_ROOT}/.venv --system-site-packages
Install pip packages on venv
COPY requirements-debug.txt /requirements-debug.txt
RUN . ${APP_ROOT}/.venv/bin/activate &&
pip3 install --upgrade pip && pip3 install -r requirements-debug.txt &&
rm requirements-debug.txt &&
chown -R ${SSHUSERNAME}:${SSHUSERNAME} ${APP_ROOT}
Install TF Lite
Rebember to unzip build.zip before running it
COPY build /build
If you want to build it from source, comment the line above and uncomment the line below
#COPY --from=Base /build /build
RUN cp -r /build/* /
RUN . ${APP_ROOT}/.venv/bin/activate && pip3 install tflite_runtime-2.9.1-cp311-cp311-linux_aarch64.whl && rm -rf *.whl
Print current working directory and list files
echo “Python path:” && which python3 &&
python3 --version &&
echo “Pip path:” && which pip3 &&
pip3 --version &&
pwd > /home/torizon/dir_check.txt && ls -la . >> /home/torizon/dir_check.txt
libneuralnetworks libovxlib-dev libnnrt-dev
Install GStreamer and rtsp libraries
RUN apt-get -y update && apt-get install -y --no-install-recommends libgstreamer1.0-0
gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad
gstreamer1.0-plugins-ugly gstreamer1.0-tools gstreamer1.0-OpenCV
python3-gst-1.0 gstreamer1.0-rtsp libgstrtspserver-1.0-0 gir1.2-gst-rtsp-server-1.0 &&
Set the environment variable to enable NPU acceleration
ENV USE_HW_ACCELERATED_INFERENCE=1
ENV USE_GPU_INFERENCE=0
ENV ACCEPT_FSL_EULA=1
ENV CAPTURE_DEVICE=/dev/video2
DEBUG PURPOSES ONLY!!
THIS CONFIGURES AN INSECURE SSH CONNECTION
create folders needed for the different components
configures SSH access to the container and sets environment by default
RUN mkdir /var/run/sshd &&
sed ‘s@session\srequired\spam_loginuid.so@session optional pam_loginuid.so@g’
-i /etc/pam.d/sshd &&
if test $SSHUSERNAME != root ;
then mkdir -p /home/$SSHUSERNAME/.ssh ;
else mkdir -p /root/.ssh ; fi &&
echo “PermitUserEnvironment yes” >> /etc/ssh/sshd_config &&
echo “PermitRootLogin yes” >> /etc/ssh/sshd_config &&
echo “Port ${DEBUG_SSH_PORT}” >> /etc/ssh/sshd_config &&
echo “PasswordAuthentication yes” >> /etc/ssh/sshd_config &&
echo “PermitEmptyPasswords yes” >> /etc/ssh/sshd_config &&
su -c “env” $SSHUSERNAME > /etc/environment &&
echo “$SSHUSERNAME:” | chpasswd -e
RUN rm -r /etc/ssh/ssh*key &&
dpkg-reconfigure openssh-server
Copy the application source code in the workspace to the $APP_ROOT directory
path inside the container, where $APP_ROOT is the torizon_app_root
configuration defined in settings.json
pip3 --version &&
COPY --chown=$SSHUSERNAME:$SSHUSERNAME ./src ${APP_ROOT}/src
CMD [ “/usr/sbin/sshd”, “-D” ]
Dockerfile:
Board architecture
ARG IMAGE_ARCH=
ARG APP_ROOT=app
Install Python
Install Build tools
Build nn-imx
Build tim vx
openssl
rsync
file
screen
python3-minimal
python3-pip
python3-setuptools
python3-venv
lsof:arm64 \
v4l-utils:arm64 \
bc:arm64 \
Create virtualenv inside the container (removed the COPY ./.venv line)
COPY requirements-release.txt /requirements-release.txt
pip3 install --upgrade pip && pip3 install -r requirements-release.txt &&
rm requirements-release.txt
Install TF Lite
COPY build /build
No need to COPY ./.venv anymore; create the virtualenv inside the container
ENV CAPTURE_DEVICE=/dev/video3
COPY --chown=${APP_ROOT}:${APP_ROOT} ./src ${APP_ROOT}/src
Final CMD for running the application using Python from the virtual environment
CMD ${APP_ROOT}/.venv/bin/python3 ${APP_ROOT}/src/main.py --no-sandbox
