Not able to use Easy Installer in custom carrier board
Hi Toradex-Team,
We’ve developed a custom carrier word for the Verdin AM62. Now I’m evaluating if the production process will work. We’ve reused a lot of the Verdin Development Board schematic on our custom development board. For example the reset and recovery buttons and the USB port to flash the Easy Installer, as well as the ethernet port.
The flashing of the easy installer (Verdin-AM62_ToradexEasyInstaller_6.6.0+build.6) in the custom carrier board works. But I can’t get a remote session with the TightVNC Viewer to work. If I used the ip address of the ethernet port I only get a gray screen but to connection seems to be established. If I use the the USB NCM at IP 192.168.11.1 the connection is refused. But I can Ping both addresses.
If I plug in an USB drive with a autoinstall Torizon-Image and a manipulated wrapup.sh (like described here) nothing happens.
But if I use the Verdin Development Board everything described above works as expected.
Here is the hardware information:
Hardware info
HW model:                 Toradex Verdin AM62 on Verdin Development Board
Toradex version:          0075 V1.1A
Serial number:            15207085
Here is the console output from the Easy Installer flashing on the custom carrier board
U-Boot SPL 2023.04-ti-gca551722e0b5 (Mar 22 2024 - 08:10:43 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
SPL initial stack usage: 13408 bytes
Trying to boot from DFU
###################################################DOWNLOAD ... OK
Ctrl+C to exit ...
Authentication passed
Loading Environment from nowhere... OK
init_env from device 10 not supported!
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
SPL initial stack usage: 1856 bytes
Ctrl+C to exit ...
U-Boot 2023.04-ti-gca551722e0b5 (Mar 22 2024 - 08:10:43 +0000)
SoC:   AM62X SR1.0 HS-FS
DRAM:  1 GiB
Core:  143 devices, 31 uclasses, devicetree: separate
MMC:   mmc@fa10000: 0, mmc@fa00000: 1
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Model: Toradex 0075 Verdin AM62 Dual 1GB WB IT V1.1A
Serial#: 15207085
i2c_write: error waiting for data ACK (status=0x116)
get_tdx_eeprom: cannot find EEPROM by node
MISSING TORADEX CARRIER CONFIG BLOCKS
am65_cpsw_nuss ethernet@8000000: K3 CPSW: nuss_ver: 0x6BA01103 cpsw_ver: 0x6BA81103 ale_ver: 0x00290105 Ports:2 mdio_freq:1000000
Setting variant to wifi
Net:
Warning: ethernet@8000000port@1 MAC addresses don't match:
Address in ROM is               28:b5:e8:cb:56:e2
Address in environment is       00:14:2d:e8:0a:ad
eth0: ethernet@8000000port@1 [PRIME]Could not get PHY for ethernet@8000000port@1: addr 7
am65_cpsw_nuss_port ethernet@8000000port@2: phy_connect() failed
generic_phy_get_bulk : no phys property
Starting download of 50334046 bytes
dwc3-generic-peripheral usb@31000000: request 0000000099f1f300 was not queued to ep1in-bulk
downloading of 50334046 bytes finished
Starting download of 82 bytes
downloading of 82 bytes finished
Starting download of 1675 bytes
downloading of 1675 bytes finished
## Executing script at 90280000
Bootargs: quiet video=HDMI-A-1:640x480-16@60D rootfstype=squashfs root=/dev/ram autoinstall
## Loading kernel from FIT Image at 90300000 ...
   Using 'conf-ti_k3-am625-verdin-wifi-dev.dtb' configuration
   Verifying Hash Integrity ... OK
   Trying 'kernel-1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x90300104
     Data Size:    7680490 Bytes = 7.3 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x80200000
     Entry Point:  0x80200000
     Hash algo:    sha512
     Hash value:   117b55aee6f045bb92089e5365514606d731813497fc7b9091be95cd7908a17c7638f995d5afae91588460427b0ec62f4882103112ff72006791cbb1930d965e
   Verifying Hash Integrity ... sha512+ OK
## Loading ramdisk from FIT Image at 90300000 ...
   Trying 'ramdisk-1' ramdisk subimage
     Description:  tezi-initramfs
     Type:         RAMDisk Image
     Compression:  uncompressed
     Data Start:   0x90ae24d8
     Data Size:    42045440 Bytes = 40.1 MiB
     OS:           Linux
     Load Address: 0x84000000
     Entry Point:  0x84000000
     Hash algo:    sha512
     Hash value:   da8a5a75cbeb7b43a167acfcf57a84c7287459f484041574e9e0757a314697c8d86eb917a15ff38244b90d09ce360f17ed5d1e012472cfd99756f48e40ad63e2
   Loading ramdisk from 0x90ae24d8 to 0x84000000
## Loading fdt from FIT Image at 90300000 ...
   Trying 'fdt-ti_k3-am625-verdin-wifi-dev.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x90aa829c
     Data Size:    70049 Bytes = 68.4 KiB
     Load Address: 0x83000000
     Hash algo:    sha512
     Hash value:   5aa70705daac5fe5e4e9b32db9d87fcf8107cce1306694eed0b3bb214e97cb25a4966f1ba927104315dcc26494ad58298f28fbe6432cc385e9030d7158f03666
   Loading fdt from 0x90aa829c to 0x83000000
   Using 'conf-verdin-am62_dsi-to-hdmi_overlay.dtbo' configuration
   Trying 'fdt-verdin-am62_dsi-to-hdmi_overlay.dtbo' fdt subimage
     Data Start:   0x90adb41c
     Data Size:    3050 Bytes = 3 KiB
     Load Address: 0x83080000
     Hash algo:    sha512
     Hash value:   5ced6b5ab11cabe4aeae808365b7164ecc5a43b15e8a8fda545db693e133ca2bfd036bce2c1d6b45456e88eadf9c6ad6521eebf9c8815f72d756c3ece4a1676f
   Using 'conf-verdin-am62_spidev_overlay.dtbo' configuration
   Trying 'fdt-verdin-am62_spidev_overlay.dtbo' fdt subimage
     Data Start:   0x90ae21b0
     Data Size:    560 Bytes = 560 Bytes
     Hash algo:    sha512
     Hash value:   4bd8efa1ddf06d7e8fa7d3aea24a556c7745e945a554d32215f71140f637f01ed033f5bcc06b23f5ec23e046b2fe6f822927fc121ed58f76e8625d8d011a5a58
   Booting using the fdt blob at 0x83000000
Working FDT set to 83000000
   Uncompressing Kernel Image
   Loading Ramdisk to 966ca000, end 98ee3000 ... OK
ERROR: reserving fdt memory region failed (addr=9e780000 size=80000 flags=4)
ERROR: reserving fdt memory region failed (addr=9e800000 size=1800000 flags=4)
ERROR: reserving fdt memory region failed (addr=9db00000 size=c00000 flags=4)
   Loading Device Tree to 00000000966b5000, end 00000000966c95db ... OK
Working FDT set to 966b5000
Starting kernel ...
[    0.335618] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=81, clk=20, ret=-19
[    0.720282] mdio_bus 8000f00.mdio: MDIO device at address 7 is missing.
[    0.732827] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    0.748785] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=81, clk=20, ret=-19
Running /etc/rc.local...
Toradex Easy Installer 6.6.0+build.6 ()
Starting udev
[    2.619622] ina2xx 1-0040: error configuring the device: -121
[    2.747633] k3-m4-rproc 5000000.m4fss: device does not reserved memory regions, ret = -22
[    2.756933] k3-m4-rproc 5000000.m4fss: reserved memory init failed, ret = -22
[    2.871787] platform 78000000.r5f: device does not have reserved memory regions, ret = -22
[    2.900160] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: reserved memory init failed, ret = -22
[    2.917741] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_cluster_rproc_init failed, ret = -22
[    2.971826] omap_i2c 20020000.i2c: Arbitration lost
System time was Fri Mar  9 12:44:01 UTC 2018.
Setting the System Clock using the Hardware Clock as reference...
System Clock set. System local time is now Fri Mar  9 12:44:01 UTC 2018.
[    3.998431] omap_i2c 20020000.i2c: controller timed out
[    4.027785] omap_i2c 20020000.i2c: Arbitration lost
[    5.054554] omap_i2c 20020000.i2c: controller timed out
[    5.083900] omap_i2c 20020000.i2c: Arbitration lost
[    6.110409] omap_i2c 20020000.i2c: controller timed out
[    6.139785] omap_i2c 20020000.i2c: Arbitration lost
[    7.166428] omap_i2c 20020000.i2c: controller timed out
[    7.195877] omap_i2c 20020000.i2c: Arbitration lost
[    8.222505] omap_i2c 20020000.i2c: controller timed out
[    8.331809] omap_i2c 20020000.i2c: Arbitration lost
Welcome to the Toradex Easy Installer
This is a Linux based installer for Toradex modules. Currently, the installer
does not have a serial console interface. You can use the Toradex Easy Installer
via any of the available display interfaces using USB mouse/keyboard or via a
network connection using VNC. Use:
  # ip addr show
to display the Ethernet IP address(es) or use USB NCM at IP 192.168.11.1.
Check our documentation at:
  https://developer.toradex.com/software/toradex-easy-installer
/ # [    9.342483] omap_i2c 20020000.i2c: controller timed out
[    9.371890] omap_i2c 20020000.i2c: Arbitration lost
[   10.398655] omap_i2c 20020000.i2c: controller timed out
[   10.427825] omap_i2c 20020000.i2c: Arbitration lost
Here is the console output from the Easy Installer flashing on the Verdin Development Board
Ctrl+C to exit ...
Ctrl+C to exit ...
DRAM:  1 GiB
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Serial#: 15207085
Carrier: Toradex Verdin Development Board V1.1F, Serial# 11305462
Net:
eth0: ethernet@8000000port@1 [PRIME], eth1: ethernet@8000000port@2
dwc3-generic-peripheral usb@31000000: request 0000000099f1f440 was not queued to ep1in-bulk
     Type:         Kernel Image
     OS:           Linux
     Hash algo:    sha512
     Type:         RAMDisk Image
     OS:           Linux
     Hash algo:    sha512
     Hash algo:    sha512
     Hash algo:    sha512
     Hash algo:    sha512
Starting kernel ...
[    0.330424] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=81, clk=20, ret=-19
[    0.396300] rtc-ds1307 0-0032: hctosys: unable to read the hardware clock
[    0.702572] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    0.719057] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=81, clk=20, ret=-19
Starting udev
[    2.739770] k3-m4-rproc 5000000.m4fss: device does not reserved memory regions, ret = -22
[    2.764747] k3-m4-rproc 5000000.m4fss: reserved memory init failed, ret = -22
[    2.832172] platform 78000000.r5f: device does not have reserved memory regions, ret = -22
[    2.846827] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: reserved memory init failed, ret = -22
[    2.861355] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_cluster_rproc_init failed, ret = -22
System time was Thu Jan  1 00:00:03 UTC 1970.
hwclock: RTC_RD_TIME: Invalid argument
System Clock set. System local time is now Thu Jan  1 00:00:03 UTC 1970.
Fri Mar  9 12:34:56 UTC 2018
Saving the System Clock time to the Hardware Clock...
Hardware Clock updated to Fri Mar  9 12:34:56 UTC 2018.
  # ip addr show
There are some differences/errors on the custom carrier board log, but i don’t know if the are related to my problem.
Like:
or
Do you have any idea what is the problem and how to fix it? Do I have to configure the Easy Installer somehow?
Kind Regards
Uwe
Greetings @buw3,
I’m checking internally to see if anyone else has seen this behavior before.
Just one question. On your custom carrier board is there a difference in terms of i2c? Much of the differences in the logs messages seem to be complaining about the i2c subsystem. I don’t think this would have an effect on Easy Installer. But it would be good to know if there is a difference in i2c on your custom carrier board versus our carrier board.
Also can you get the logs from the following:
$ journalctl -b -u weston
$ cat /var/volatile/tezi.log
Hallo @jeremias.tx,
I checked back with the hardware developer. Our carrier board does not contain the following i2c stuff:
  • i2c stuff for power suppy (IMHO no related to the problem)
  • i2c audio chip (IMHO no related to the problem)
  • MIPI DSI (IMHO no related to the problem - because if the Verdin DSI to HDMI Adapter is not connected to the Verdin Eval Board everything sill works)
  • i2c stuff for PCIE (IMHO no related to the problem)
  • EEPROM IC29 (addr 0x57) - maybe this is somehow the problem?
As the logs say - the software is trying to connect to it:
What does this EEPROM contains?
I also removed the jumper A1 and A2 on X3 to cut off the ic2 on the Verdin Eval Board. This cause the same error messages in the logs but the Easy Installer remote connection and GUI still works as expected.
Ethernet - maybe another straw
We are also just have one Ethernet-Jack (ETH_1)! The ETH_2 is not present and the logs say:
Does this maybe cause the problem?
But we also disabled the ETH_2 on the Verdin Eval Board by pulling the RESET_N on IC22 to GND and still everything worked as expected.
Weston - an additional Information
After flashing the Easy Installer the ps command only shows this entry regarding to weston on our custom carrier board:
 229 root     32888 S    /usr/bin/weston --backend=vnc-backend.so --modules=s
in comparison to the Verdin Eval board:
 232 root     26004 S    /usr/bin/weston --tty=2 --current-mode
 235 root     31540 S    /usr/bin/weston --backend=vnc-backend.so --shell=ful
So the GUI application is not working and thats why there is just a gray screen?
TEZI log
The command you mentioned
returned the following on both carrier boards:
# cat /var/volatile/tezi.log
qt.qpa.wayland: Failed to load client buffer integration: "wayland-egl"
qt.qpa.wayland: Available client buffer integrations: ()
USB Gadget: NCM enabled
Trying to read configblock from "mmcblk0boot0" at -512
Running Command:  "/usr/bin/avahi-set-host-name" ("verdin-am62-15207085")
Finished with exit code: 0
avahi-set-host-name:
"AVAHI_CLIENT_S_REGISTERING"
Scanning media initially...
Network up in 0.096 seconds
NCM up in 0.166 seconds
Tezi Server lookup successfully
Downloading image list from  "http://tezi.toradex.com/image_list.json?PID8=00751100"
Downloading image list from  "http://tezi.toradex.com/image_list_3rdparty.json?PID8=00751100"
"AVAHI_CLIENT_S_RUNNING"
"AVAHI_BROWSER_CACHE_EXHAUSTED"
"AVAHI_BROWSER_ALL_FOR_NOW"
Thanks for your help.
Kind Regard
Uwe
On our modules that feature an EEPROM, it contains the toradex config block that contains some information about the hardware. Though this shouldn’t be needed for Easy Installer to at least run. As proven by the test you ran on our eval board.
This shouldn’t have any effect either. Easy Installer can run without any network connections.
This is my impression yes. The gray screen indicates that Weston is running, but since you don’t see anything else that means the Easy Installer GUI app is not running.
You’re saying the log file here is identical on both carrier boards? That’s odd, I was hoping to see some kind of error or crash since it appears that Easy Installer isn’t running on your carrier board. Maybe then it is actually running? In the output for ps do you see any application running for Easy Installer? The application itself should be called “tezi” or something similar.
By the way you didn’t return the output of journalctl -b -u weston. Could you share this please.
Hi @jeremias.tx,
thanks for the answers :slight_smile:
let me get that straight… I could swear the output on both carrier boards contained the same prints, just in a different order. So I figured they are “equal”. But I’ve redone the commands and here are both prints - they are NOT equal:
Custom carrier board tezi.log
/ # cat /var/volatile/tezi.log
Failed to create wl_display (No such file or directory)
qt.qpa.plugin: Could not load the Qt platform plugin "wayland" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: minimal, offscreen, vnc, wayland.
Verdin eval board tezi.log
NCM up in 0.315 seconds
Network up in 1.219 seconds
I didn’t know that the GUI application was called "tezi", but this was a good hint. Only on the Verdin eval board the process was running, but not on our custom carrier board.
/ # ps | grep tezi
  248 root      412m S    /usr/bin/tezi -autoinstall -platform wayland
  305 root      3412 R    grep tezi
So i tried to run it manually on your board… and what a surprise the Easy Installer GUI worked - I got an image on the remote desktop and was able to flash the SOM!
/ # /usr/bin/tezi -autoinstall -platform wayland
NCM up in 0.164 seconds
So why isn’t the tezi process able the start automatically in the first place on your hardware?
Yeah, I didn’t share that on purpose, because there is no output. After flashing the Easy Installer with the recovery script and running the command it returns the following on both carrier boards:
/ # journalctl -b -u weston
sh: journalctl: not found
And after starting into the Torizon linux the command returns:
torizon@verdin-am62-15207085:~$ journalctl -b -u weston
-- No entries --
Kind Regards
Uwe
Thank you for double-checking the logs here. With the latest information we can confirm that Easy Installer is not running on your custom carrier board for whatever reason. Though it’s interesting that starting the tezi application manually does work.
This suggests there’s some kind of "bad’ initial state when the system boots up where tezi can’t execute properly. Now how and why your custom carrier board causes this, is still unclear. But, at least now we have the logs showing Easy Installer is indeed not starting on boot.
Let me take these logs to our team and see what can be determined. At least for the time-being you have an short-term workaround for using Easy Installer.
Hi @jeremias.tx
I’m just curious. Are there any news on this topic? Did the Torizon-Team get an idea through the logs of what causes this problem?
Uwe
Our team has a few ideas. So it’s obvious that Weston is starting in your system automatically as expected, but Easy Installer is not. Furthermore as per your tests, manually starting Easy Installer afterwards does work.
In Easy Installer the startup is automated by /etc/rc.local. The contents of this is something like:
nohup /usr/bin/weston --tty=2 --current-mode >> ${RW_MEMORY_DIR}/${WESTON_LOGFIL
sleep 0.5
nohup /usr/bin/tezi $DEFAULT_KBD $DEFAULT_LANG $AUTOINSTALL $FULLSCREEN \
        -platform wayland < /dev/null >> ${RW_MEMORY_DIR}/${TEZI_LOGFILE} &
Basically we start Weston then after a 0.5 second delay we start the Easy Installer application. Looking at the logs for Easy Installer you provided, it looks like the application is complaining that there is no Wayland/Weston client available.
Our theory is that perhaps on your custom carrier board the timings of things are slightly different. Maybe it’s taking longer for certain software stacks in the system to startup which causes Weston to take longer to start. If the timing is affected in this way, then maybe the 0.5 second delay isn’t enough of a delay. This would cause the Easy Installer application to be started before Weston is ready.
This would explain why you can start the Easy Installer application afterwards manually. Since by then Weston has had enough time to start and stabilize. It’s difficult to say for sure though what on your custom carrier board could cause such a change in timing.
Assuming this theory is correct you may be able to try some things. Perhaps you can modify the Easy Installer image to increase this delay in /etc/rc.local. Even though it’s a bit unorthodox, we do have a rough guide on modifying Easy Installer: How to Modify a Toradex Easy Installer Image | Toradex Developer Center
Hello @jeremias.tx
sorry for the super late reply. I’m only now returning to this topic. I have read the How to Modify a Toradex Easy Installer Image | Toradex Developer Center and several other related suff. But I couldn’t figure out how to get or find the /etc/rc.local file to manipulate the delay.
In addition I want to modify the image list like described here to realize the Unattended flashing Over the Ethernet. But I also can’t figure where to get or find the tezi_config.json.
Can you guide me to instructions or descriptors I might missing?
Do I have to somehow extract the rootfs from the UBoot with dumpimage to get the required files?
Kind Regards,
Uwe
You need to dump the ramdisk from the tezi.itb you can then mount the ramdisk and see the file in /etc/rc.local. I checked on my side and I can see the file contents in this way. Double-checking the latest version of Easy Installer I can see we have the following at the end of this file:
# Start in background
# if the first command fails due to any reason e.g. no card available we spin
# only vnc-backend up
        nohup /usr/bin/weston --tty=2 --current-mode --continue-without-input \
                >> ${RW_MEMORY_DIR}/${WESTON_LOGFILE} || \
        nohup /usr/bin/weston --backend=vnc-backend.so \
                --modules=screen-share.so --shell=kiosk-shell.so \
                >> ${RW_MEMORY_DIR}/${WESTON_LOGFILE};
# Wait for the completion of the Weston init process. In the very last turn, it
# starts sharing the screen over VNC
max_wait_cnt=0
while ! ps | grep -q [v]nc-backend && [ $max_wait_cnt -le 10 ]
do
    sleep 0.5
    max_wait_cnt=$((max_wait_cnt + 1))
done
It seems we already loop waiting for weston before we start the Easy Installer application. Though it might still be the case that the timing needs to be adjusted for whatever reason on your custom carrier board. Again hard to say for sure since we can’t reproduce this behavior on Toradex standard carrier boards. You’ll need to play around with it for a bit and investigate.
I believe this is a file you create yourself. It should be provided via local media (i.e USB). If you check the info box in this section: Detailed Manual | Toradex Developer Center
It even states that:
Without a local media there is currently no way to provide the Installer with a custom URL. There exists a workaround documented further below.
You could also setup a server with your images via zerconf as described here: Detailed Manual | Toradex Developer Center
In this way Easy Installer would automatically seek and find your server serving your images for flashing.
Hi @jeremias.tx,
thanks for the fast reply :slight_smile:
first up…
You are right. I got that to work.
secondly…
This modification unfortunately doesn’t solve the problem on our custom carrier board.
thirdly…
Yea i tried that. But I didn’t get it to work.
  • tried to dump it like described here Modify the Toradex Easy Installer Image
  • tried to dump it like: dumpimage -T flat_dt -p 19 -o ramdisk tezi.itb. Also with type ramdisk - which failed. Then I mountet the image and could see the /etc/rc.local, but no matter what I did, the filesystem was always Read-Only (because its of type squashfs) so I coudn’t modify anything.
  • tried to dump it like: dumpimage -T flat_dt -p 19 -o ramdisk.zip tezi.itb. Then tried to modify the file in the archive. Tough i could opened the archive, I can’t modify anything because an error occured where is was stated “it is no archive”.
So I didn’t even get to the step where I repack anything.
Hopefully that is not too much to ask, but is it possible, that you could tell me which commands you use for:
  • dump the ramdisk?
  • mount the ramdisk?
  • and maybe the command to repack the manipulated image?
Kind Regards,
Uwe
Wait so you already tried modifying the startup script with an increased delay, and it didn’t help on your custom carrier board? That’s odd, I’m not sure what to suggest next then. Since you’re still asking about modifying the ramdisk, do you have another idea of what to try?
As for the ramdisk, you are correct it is a squashfs which are read-only by design. First of all use dumpimage to get the ramdisk out of the tezi.itb as you did before. Then install squashfs-tools on your system.
You can then use the unsquashfs utility to unpack the ramdisk in a writable form. After doing your modification you can then use mksquashfs on the unpacked ramdisk to create a new ramdisk that should have your modifications. You then need to re-pack everything as documented here: How to Modify a Toradex Easy Installer Image | Toradex Developer Center
Hi @jeremias.tx ,
thanks again for the fast reply :slight_smile:
You misunderstood me. I tried the new EasyInstaller Version with the Fix you mentioned.
This modification was done by Toradex. Until now I didn’t get my own modification (insert a additional sleep) to work.
In the meantime I already figured/tried your suggestion with the squashfs-tools which seems to work. Unfortunately now I got the problem, that I probably didn’t configure the tezi.its file correctly. Here is the error I get.
Starting download of 50244772 bytes
dwc3-generic-peripheral usb@31000000: request 0000000099f1f340 was not queued to ep1in-bulk
downloading of 50244772 bytes finished
Could not find configuration node
ERROR: can't get kernel image!
And here is the tezi.its based on How to Modify a Toradex Easy Installer Image | Toradex Developer Center - it’s more or less the same as in the example but I had to change the parameters load, entry, and hash algo dependent on the output from dumpimage -l tezi.itb:
/dts-v1/;
    description = "U-Boot fitImage for Toradex Easy Installer";
    #address-cells = <1>;
    images {
        kernel {
            description = "Linux Kernel";
            data = /incbin/("./zImage");
            type = "kernel";
            arch = "arm64";
            os = "linux";
            compression = "gzip";
            load = <0x80200000>;
            entry = <0x80200000>;
            hash {
                algo = "sha512";
        fdt-0 {
            description = "Flattened Device Tree blob";
            data = /incbin/("./system.dtb");
            type = "flat_dt";
            arch = "arm64";
            compression = "none";
            hash {
                algo = "sha512";
        ramdisk-0 {
            description = "tezi-initramfs";
            data = /incbin/("./ramdisk");
            type = "ramdisk";
            arch = "arm64";
            os = "linux";
            hash {
                algo = "sha512";
    configurations {
        default = "config-1";
        config-1 {
            description = "Boot Linux kernel with FDT blob + ramdisk";
            kernel = "kernel";
            fdt = "fdt-0";
            ramdisk = "ramdisk-0";
            hash {
                algo = "sha512";
I used these 3 command to extract all images that later are required to repack:
dumpimage tezi.itb -T flat_dt -p 0 -o zImage
dumpimage tezi.itb -T flat_dt -p 2 -o system.dtb
For the sake of completeness, here is a snippet (otherwise this post will go beyond max allowed character) of the output from dumpimage -l tezi.itb:
FIT description: Kernel fitImage for Toradex Easy Installer/6.1.83+gitAUTOINC+0a32d33d5f/verdin-am62
Created:         Fri Jun 28 11:20:37 2024
 Image 0 (kernel-1)
  Type:         Kernel Image
  Data Size:    7881903 Bytes = 7697.17 KiB = 7.52 MiB
  OS:           Linux
  Hash algo:    sha512
  Hash value:   e15d116b85ec698d75a394ece315aba43f94e61c07d634d7301dc024604438922499a331715f26092ac1e3f44b4b468ed41c22b99674b12ab1d2a98ee89f8735
 Image 1 (fdt-ti_k3-am625-verdin-nonwifi-dahlia.dtb)
  Data Size:    69647 Bytes = 68.01 KiB = 0.07 MiB
  Hash algo:    sha512
  Hash value:   e68b6fc0437bfccbb66794ceb426d1f9bbecb036e76a8ea80895d7c61bc6391df3b59e4857411e3f17eb4e2602fdadeb696611732f8a35daaaa3b3af528b390d
 Image 2 (fdt-ti_k3-am625-verdin-nonwifi-dev.dtb)
  Data Size:    69614 Bytes = 67.98 KiB = 0.07 MiB
  Hash algo:    sha512
  Hash value:   05b7a2e524ecbdfc037f54c83a00091ba93a57515139b89ff58274972f5661f601279f950e9ec2ba8ce96f294616ca8e0b0190f90e7786be5dbcb83c288f7585
 Image 3 (fdt-ti_k3-am625-verdin-nonwifi-mallow.dtb)
  Data Size:    68682 Bytes = 67.07 KiB = 0.07 MiB
  Hash algo:    sha512
  Hash value:   4aa8d63fd6391512e4c6e3f49c411eae6c12e4aca35c9445a13ca3636267c1d427e288ebe283a61d6d4f49daf114b79b8db6a113dab85a49e14ee286dcf6538f
 Image 4 (fdt-ti_k3-am625-verdin-nonwifi-yavia.dtb)
  Data Size:    68675 Bytes = 67.07 KiB = 0.07 MiB
  Hash algo:    sha512
  Hash value:   b89d18d59d8fab6fe509492a5bd49305255d5710d9088820a0dccef5c4c0156e58b07a1b70d36aac11b102c2c28114e3a9e4b4a933e38a1d1f192d55c6a57f43
 Image 5 (fdt-ti_k3-am625-verdin-wifi-dahlia.dtb)
  Data Size:    70084 Bytes = 68.44 KiB = 0.07 MiB
  Hash algo:    sha512
  Hash value:   05a52c93ab1aafb7a5e8e1a340eb46813d5911d568a77698fdd474da74b0f8b021249964d208da1f0c8a0ded4c17c5c2f88e3f36baa65488221f7515b86e4b70
 Image 6 (fdt-ti_k3-am625-verdin-wifi-dev.dtb)
  Data Size:    70047 Bytes = 68.41 KiB = 0.07 MiB
  Hash algo:    sha512
  Hash value:   493b2a750b895b11021b71de6b850648c79469a6f3d6e0b93b8050055ef8c4a26b7cbbe37ebf4caf396d2d15a67af4a898c1ab3cd405642cb42a3f329e56cb83
 Image 9 (fdt-verdin-am62_dsi-to-hdmi_overlay.dtbo)
  Data Size:    3415 Bytes = 3.33 KiB = 0.00 MiB
  Hash algo:    sha512
  Hash value:   daa45cc5a4a15363695c4b2ebf34f287d9529f54d3ea5c321a8b122d6a32b679fa98dcadeb4fa7900c586b1724ca0691cc3f12789ce95a0e1a188886fbeb6f89
 Image 19 (ramdisk-1)
  Type:         RAMDisk Image
  Data Size:    42291200 Bytes = 41300.00 KiB = 40.33 MiB
  OS:           Linux
  Hash algo:    sha512
  Hash value:   56773662e9566cff1c762bd2b71af3e253b76d35b45c0daa2a66a8805cb3f9d305e8873b247778587991afb3a0f34f18050d32471e509e5bbc0a7f9b407d8440
 Default Configuration: 'conf-ti_k3-am625-verdin-nonwifi-dahlia.dtb'
 Configuration 0 (conf-ti_k3-am625-verdin-nonwifi-dahlia.dtb)
  Description:  1 Linux kernel, FDT blob, ramdisk
  Kernel:       kernel-1
  Init Ramdisk: ramdisk-1
  FDT:          fdt-ti_k3-am625-verdin-nonwifi-dahlia.dtb
  Hash algo:    sha512
  Hash value:   unavailable
  Sign algo:    sha512,rsa4096:custMpk
  Sign padding: pkcs-1.5
  Sign value:   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
  Timestamp:    Fri Jun 28 11:20:37 2024
 Configuration 1 (conf-ti_k3-am625-verdin-nonwifi-dev.dtb)
  Description:  0 Linux kernel, FDT blob, ramdisk
  Kernel:       kernel-1
  FDT:          fdt-ti_k3-am625-verdin-nonwifi-dev.dtb
  Hash algo:    sha512
  Sign value:   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
 Configuration 2 (conf-ti_k3-am625-verdin-nonwifi-mallow.dtb)
  Kernel:       kernel-1
  FDT:          fdt-ti_k3-am625-verdin-nonwifi-mallow.dtb
  Hash algo:    sha512
  Sign value:   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
 Configuration 3 (conf-ti_k3-am625-verdin-nonwifi-yavia.dtb)
  Kernel:       kernel-1
  FDT:          fdt-ti_k3-am625-verdin-nonwifi-yavia.dtb
  Hash algo:    sha512
  Sign value:   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
 Configuration 4 (conf-ti_k3-am625-verdin-wifi-dahlia.dtb)
  Kernel:       kernel-1
  FDT:          fdt-ti_k3-am625-verdin-wifi-dahlia.dtb
  Hash algo:    sha512
  Sign value:   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
 Configuration 5 (conf-ti_k3-am625-verdin-wifi-dev.dtb)
  Kernel:       kernel-1
  FDT:          fdt-ti_k3-am625-verdin-wifi-dev.dtb
  Hash algo:    sha512
  Sign value:   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
 Configuration 6 (conf-ti_k3-am625-verdin-wifi-mallow.dtb)
  Kernel:       kernel-1
  FDT:          fdt-ti_k3-am625-verdin-wifi-mallow.dtb
  Hash algo:    sha512
  Sign value:   82742159cc1e5938c578a1b4d2775048ad73057f05b2cbc016f3ef1392a71ffd3278bb95c1df402b9d82940c6a2731de28473ad3b8fec3ff0415b2fcd949b2a76bc487791a7e59a5d5dad95108c838f537d51ed9328c5a35215ceee564c4c7d64af61d69929ec74c92c563fc2082b9c11511171604ccb2403394b8ccfb903cf646fa0c3b0fd19a08b426e2f6778e6910b4ce579d6c096e16dd2ed02bc884a829e649c3f42a25dbacf3cd682feb3b3c3d9b2e23145dac9de614fff23495df8b952030b2d386f96aab77b4f67b9a37e0a4758b461046303d61430f3da811a5ed0d31c0c5f673be9f87066e2024be7bc7484bf63f2278986cd57661312cdb26d249bdc3c7cf3bc11017722957f6545aba45dc091cd8d581e5812b473f1d90ea396588cf7c51440cfd094d68d75ee2bc6e93a8d2adaed92fdb0d2493c2a98c949f9b17d27bff3ba386886b3ecc1c59bf6ff4a7a3240e2ddc7fa29c7efa33d0e3fac4d37fef6189a0d4a4589843aa8f4fa35b879b8e3a457de79682e212059302f49ee9dce61167ef5692f4fcb5e37e9e6bc651d671c9424d183d8ab244263eaedac66eb6278ea70700e9c684570404a9e8ea29fd93592b3e5641250c97203c593f56ba685ff52dabee3dc4bbaa6b557e92e34e2e2b25c693e0465d8a6f77587743855a61477eb84765c0ade56f9deda8d21ff28b7963fe9db75c515f2d24296dc754
 Configuration 7 (conf-ti_k3-am625-verdin-wifi-yavia.dtb)
  Kernel:       kernel-1
  FDT:          fdt-ti_k3-am625-verdin-wifi-yavia.dtb
  Hash algo:    sha512
  Sign value:   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
 Configuration 8 (conf-verdin-am62_dsi-to-hdmi_overlay.dtbo)
  Description:  0 FDT blob
  Kernel:       unavailable
  FDT:          fdt-verdin-am62_dsi-to-hdmi_overlay.dtbo
  Hash algo:    sha512
  Sign value:   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
I will try to figure that out until your reply (with which you may help me again?)
Kind Regards,
Uwe
In the documentation example that fit-image only had 3 components. In this case as seen from your dumpimage -l tezi.itb output there are a lot more than just 3 components here. I would think the image would need to be reassembled with all of it’s parts to behave the same again.
This will probably help. Here’s the original tezi.its file for 6.7.0: https://artifacts.toradex.com/artifactory/tezi-oe-prod-frankfurt/kirkstone-6.x.y/release/7/verdin-am62/tezi/tezi-run/oedeploy/fitImage-its-verdin-am62
You can probably just copy this and modify the changed values as necessary. It’s a bit tedious but you’ll probably need to extract and re-pack all the components to match the original behavior.
Hello @buw3,
In addition to what @jeremias.tx said, we could also have a look at the hardware aspect of the issue.
As this only happens in your custom carrier board, I would be curious to understand exactly what differences it has when compared to the Toradex designs.
The idea is to have a look at the schematics to see if there is anything that may cause such problems.
If this is something that you would be open to, please let us know via support.eu@toradex.com.
Bruno
Hi @jeremias.tx ,
Sorry, but I think you are wrong. The output of dumpimage -l tezi.itb in the documentation example also got a lot more than just 3 components… see the dropdown element FIT description: U-Boot fitImage on Modify the Toradex Easy Installer Image.
But I don’t get why they use dumpimage tezi.itb -T flat_dt -p 1 -o ramdisk in the example, even though the ramdisk image number is clearly 25 (not 1).
All the other components are just different device tree files which are not necessarily required (please proof me wrong).
But in my opinion everything I stated does not justify the error message:
I can’t figure where I made the mistake?!?
Kind Regards,
Uwe
Could you please reply to Bruno’s message as well. I think we should take a look again at your custom carrier board and why it exhibits this behavior with Easy Installer. This is probably a more ideal approach than trying to create a custom Easy Installer for your specific case.
Hello @bruno.tx
Thank you, I have to discuss this internally and then will get back to you :slight_smile:
Kind Regards,
Uwe
