I have Colibri eval board with iMx6dl com module. I am trying to short the pad as mentioned in datasheet to force the device to recovery but not able to do it. Is there anything else i am supposed to do?
Actually you first have to power off the carrier board. Then shorten the pins and keep them shorted and turn on the carrier board. After 1-2 seconds, you can release the shorten pins.
If this is done correctly, then you see a new device in your host OS.
Note: For iMX6 Recovery mode, make sure that you don’t have any SD Card Inserted in the SD Card Slot.
