I am using BSP 2.8.7, and I created a recipe to my nodejs application using TipsAndTricks/NPM and aparently everything compiles good, but fail with the error below:
WARNING: smar-api-1.0-r0 do_package_qa: QA Issue: non -staticdev package contains static .a library: smar-api-sqlite3 path '/work/armv7at2hf-neon-angstrom-linux-gnueabi/smar-api/1.0-r0/packages-split/smar-api-sqlite3/usr/lib/node_modules/smar-api/node_modules/sqlite3/build/Release/sqlite3.a'
non -staticdev package contains static .a library: smar-api-sqlite3 path '/work/armv7at2hf-neon-angstrom-linux-gnueabi/smar-api/1.0-r0/packages-split/smar-api-sqlite3/usr/lib/node_modules/smar-api/node_modules/sqlite3/build/Release/obj.target/deps/sqlite3.a' [staticdev]
ERROR: smar-api-1.0-r0 do_package_qa: QA Issue: /usr/lib/node_modules/smar-api/node_modules/sqlite3/tools/docker/architecture/linux-arm64/Dockerfile contained in package smar-api-sqlite3 requires /bin/echo, but no providers found in RDEPENDS_smar-api-sqlite3? [file-rdeps]
ERROR: smar-api-1.0-r0 do_package_qa: QA run found fatal errors. Please consider fixing them.
ERROR: smar-api-1.0-r0 do_package_qa: Function failed: do_package_qa
ERROR: Logfile of failure stored in: /home/vbalestero/df63ng/df63ng-imx6-bsp-287/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/smar-api/1.0-r0/temp/log.do_package_qa.17182
ERROR: Task (/home/vbalestero/df63ng/df63ng-imx6-bsp-287/build/../layers/meta-smar-df63ng/recipes-devtools/nodejs/smar-api.bb:do_package_qa) failed with exit code '1'
This is my recipe:
SUMMARY = "Webserver hello world from B2ML"
LICENSE = "MIT"
# Add missing RDEPENDS (should be implemented by npm class)
RDEPENDS_${PN} += "nodejs"
PV = "1.0.0"
##SRC_URI = "git:///home/vbalestero/build/webserver-helloworld.git;branch=main;protocol=git
SRC_URI = "git://github.com/diegomgerminiani/webserver-helloworld.git;branch=main;protocol=git \
file://node_modules.tar.gz;subdir=smar-api"
SRCREV = "${AUTOREV}"
#SRCREV = "1d0a1d36c96e45e7ddb3a870e5ef3c3de891f485"
#SRC_URI[md5sum] = "b9d79706255619bd45629331c8f13b6d"
#SRC_URI[sha256sum] = "230678dbe59ea6087d8c90233e098f0c33e72d71aa13c64b4607862d940d8349"
inherit npm
# npm class sets ${S} so we need to override it. This has to be done after 'inherit npm' directive
S = "${WORKDIR}/git"
# You must go through dependent modules extract licences and add them here.
# This snippet shows a subset
LIC_FILES_CHKSUM = "file://LICENSE;md5=0703cf6b93b62996588714ca1e28cfc0"
LICENSE_${PN} = "MIT"
Is there anyone to help me with this urgently please?
