Hello all,
So I am currently attempting to build an RT kernel using BSP 3.0 Poky distribution for an Apalis iMX6Q IT on a custom carrier board. I have some experience with openembedded as I currently have a functioning angstrom distribution BSP 2.8, but I would like to use the newer kernel version for longevity reasons.
I have made the appropriate modifications to bblayers.conf and local.conf but I am getting the following error during the bitbake process
ERROR: console-tdx-image-${TDX_VER_PACKAGE_MIN}-r0 do_populate_lic: Error executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
0001:
*** 0002:sstate_hardcode_path(d)
0003:
File: '/home/mmorgan/oe-core/build/../layers/openembedded-core/meta/classes/sstate.bbclass', lineno: 587, function: sstate_hardcode_path
0583: bb.note("Removing hardcoded paths from sstate package: '%s'" % (sstate_hardcode_cmd))
0584: subprocess.check_output(sstate_hardcode_cmd, shell=True, cwd=sstate_builddir)
0585:
0586: # If the fixmefn is empty, remove it..
*** 0587: if os.stat(fixmefn).st_size == 0:
0588: os.remove(fixmefn)
0589: else:
0590: bb.note("Replacing absolute paths in fixmepath file: '%s'" % (sstate_filelist_relative_cmd))
0591: subprocess.check_output(sstate_filelist_relative_cmd, shell=True)
Exception: FileNotFoundError: [Errno 2] No such file or directory: '/home/mmorgan/oe-core/build/tmp/work/apalis_imx6-poky-linux-gnueabi/console-tdx-image/${TDX_VER_PACKAGE_MIN}-r0/sstate-build-populate_lic/fixmepath'
ERROR: console-tdx-image-${TDX_VER_PACKAGE_MIN}-r0 do_populate_lic: Function failed: sstate_hardcode_path
ERROR: Logfile of failure stored in: /home/mmorgan/oe-core/build/tmp/work/apalis_imx6-poky-linux-gnueabi/console-tdx-image/${TDX_VER_PACKAGE_MIN}-r0/temp/log.do_populate_lic.9094
Now I have done searches for both the TDX_VER_PACKAGE_MIN variable and the tdx_version.conf file that I saw in another thread, neither are present which I assume is the issue. I didn’t have to mess with either of these for V2.8 so I am curious as to what I am missing. Any help would be greatly appreciated.
Below are my bblayers.conf and local.conf
bblayers.conf
# LAYER_CONF_VERSION is increased each time build/conf/bblayers.conf
# changes incompatibly
LCONF_VERSION = "7"
BBPATH = "${TOPDIR}"
BBFILES ?= ""
BBLAYERS ?= " \
${TOPDIR}/../layers/meta-toradex-nxp \
${TOPDIR}/../layers/meta-freescale \
${TOPDIR}/../layers/meta-freescale-3rdparty \
${TOPDIR}/../layers/meta-toradex-bsp-common \
${TOPDIR}/../layers/meta-openembedded/meta-oe \
${TOPDIR}/../layers/meta-openembedded/meta-filesystems \
${TOPDIR}/../layers/meta-openembedded/meta-gnome \
${TOPDIR}/../layers/meta-openembedded/meta-xfce \
${TOPDIR}/../layers/meta-openembedded/meta-initramfs \
${TOPDIR}/../layers/meta-openembedded/meta-networking \
${TOPDIR}/../layers/meta-openembedded/meta-webserver \
${TOPDIR}/../layers/meta-openembedded/meta-multimedia \
${TOPDIR}/../layers/meta-openembedded/meta-python \
${TOPDIR}/../layers/meta-lxde \
${TOPDIR}/../layers/meta-browser \
${TOPDIR}/../layers/meta-qt5 \
${TOPDIR}/../layers/meta-qt5-extra \
${TOPDIR}/../layers/meta-rust \
${TOPDIR}/../layers/meta-freescale-distro \
${TOPDIR}/../layers/meta-toradex-demos \
${TOPDIR}/../layers/meta-toradex-distro \
${TOPDIR}/../layers/meta-yocto/meta-poky \
${TOPDIR}/../layers/openembedded-core/meta \
local.conf
# This file is your local configuration file and is where all local user settings
# are placed. The comments in this file give some guide to the options a new user
# to the system might want to change but pretty much any configuration option can
# be set in this file. More adventurous users can look at local.conf.extended
# which contains other examples of configuration which can be placed in this file
# but new users likely won't need any of them initially.
# Lines starting with the '#' character are commented out and in some cases the
# default values are provided as comments to show people example syntax. Enabling
# the option is a question of removing the # character and making any change to the
# variable as required.
# Parallelism Options
# These two options control how much parallelism BitBake should use. The first
# option determines how many tasks bitbake should run in parallel:
#BB_NUMBER_THREADS ?= "4"
# Default to setting automatically based on cpu count
BB_NUMBER_THREADS ?= "${@oe.utils.cpu_count()}"
# The second option controls how many processes make should run in parallel when
# running compile tasks:
#PARALLEL_MAKE ?= "-j 4"
PARALLEL_MAKE ?= "-j ${@oe.utils.cpu_count()}"
# For a quad-core machine, BB_NUMBER_THREADS = "4", PARALLEL_MAKE = "-j 4" would
# be appropriate for example.
# Machine Selection
# You need to select a specific machine to target the build with. These are the
# machines which for the Toradex Colibri and Apalis computer on module families
MACHINE ?= "apalis-imx6"
#MACHINE ?= "apalis-imx8"
#MACHINE ?= "apalis-imx8x"
#MACHINE ?= "apalis-tk1"
#MACHINE ?= "apalis-tk1-mainline"
#MACHINE ?= "colibri-imx6"
#MACHINE ?= "colibri-imx6ull"
#MACHINE ?= "colibri-imx7"
#MACHINE ?= "colibri-imx7-emmc"
#MACHINE ?= "colibri-imx8x"
#MACHINE ?= "verdin-imx8mm"
# There are also a selection of emulated machines available which can boot and run
# in the QEMU emulator:
#MACHINE ?= "qemuarm"
#MACHINE ?= "qemumips"
#MACHINE ?= "qemuppc"
#MACHINE ?= "qemux86"
#MACHINE ?= "qemux86-64"
# Where to place downloads
# During a first build the system will download many different source code tarballs
# from various upstream projects. This can take a while, particularly if your network
# connection is slow. These are all stored in DL_DIR. When wiping and rebuilding you
# can preserve this directory to speed up this part of subsequent builds. This directory
# is safe to share between multiple builds on the same machine too.
# The default is a downloads directory under TOPDIR which is the build directory.
DL_DIR ?= "${TOPDIR}/../downloads"
# It seems that uninative is racy when building multiple builds in parallel.
# Work around by storing the uninative tarball in a per-build location.
UNINATIVE_DLDIR = "${TMPDIR}/uninative/"
# Where to place shared-state files
# BitBake has the capability to accelerate builds based on previously built output.
# This is done using "shared state" files which can be thought of as cache objects
# and this option determines where those files are placed.
# You can wipe out TMPDIR leaving this directory intact and the build would regenerate
# from these files if no changes were made to the configuration. If changes were made
# to the configuration, only shared state files where the state was still valid would
# be used (done using checksums).
# The default is a sstate-cache directory under TOPDIR.
SSTATE_DIR ?= "${TOPDIR}/../sstate-cache"
# Where to place the build output
# This option specifies where the bulk of the building work should be done and
# where BitBake should place its temporary files and output. Keep in mind that
# this includes the extraction and compilation of many applications and the toolchain
# which can use Gigabytes of hard disk space.
# The default is a tmp directory under TOPDIR.
#TMPDIR = "${TOPDIR}/tmp"
# Where to place images and sw packages
# This places the build output in parallel to build and layers thus
# if you have several build directories you need to adjust deploy
# to something unique, e.g. "${TOPDIR}/../deploy_fb" "${TOPDIR}/../deploy_x11"
DEPLOY_DIR = "${TOPDIR}/deploy"
# Package Management configuration
# This variable lists which packaging formats to enable. Multiple package backends
# can be enabled at once and the first item listed in the variable will be used
# to generate the root filesystems.
# Options are:
# - 'package_deb' for debian style deb files
# - 'package_ipk' for ipk files are used by opkg (a debian style embedded package manager)
# - 'package_rpm' for rpm style packages
# E.g.: PACKAGE_CLASSES ?= "package_rpm package_deb package_ipk"
# We default to ipk:
PACKAGE_CLASSES ?= "package_ipk"
# SDK/ADT target architecture
# This variable specifies the architecture to build SDK/ADT items for and means
# you can build the SDK packages for architectures other than the machine you are
# running the build on (i.e. building i686 packages on an x86_64 host).
# Supported values are i686 and x86_64
#SDKMACHINE ?= "i686"
# Extra image configuration defaults
# The EXTRA_IMAGE_FEATURES variable allows extra packages to be added to the generated
# images. Some of these options are added to certain image types automatically. The
# variable can contain the following options:
# "dbg-pkgs" - add -dbg packages for all installed packages
# (adds symbol information for debugging/profiling)
# "dev-pkgs" - add -dev packages for all installed packages
# (useful if you want to develop against libs in the image)
# "ptest-pkgs" - add -ptest packages for all ptest-enabled packages
# (useful if you want to run the package test suites)
# "tools-sdk" - add development tools (gcc, make, pkgconfig etc.)
# "tools-debug" - add debugging tools (gdb, strace)
# "eclipse-debug" - add Eclipse remote debugging support
# "tools-profile" - add profiling tools (oprofile, exmap, lttng, valgrind)
# "tools-testapps" - add useful testing tools (ts_print, aplay, arecord etc.)
# "debug-tweaks" - make an image suitable for development
# e.g. ssh root access has a blank password
# There are other application targets that can be used here too, see
# meta/classes/image.bbclass and meta/classes/core-image.bbclass for more details.
# We default to enabling the debugging tweaks.
# package-management deploys the package meta data of deployed packeges
EXTRA_IMAGE_FEATURES = "debug-tweaks package-management"
# Additional image features
# The following is a list of additional classes to use when building images which
# enable extra features. Some available options which can be included in this variable
# are:
# - 'buildstats' collect build statistics
# - 'image-mklibs' to reduce shared library files size for an image
# - 'image-prelink' in order to prelink the filesystem image
# - 'image-swab' to perform host system intrusion detection
# NOTE: if listing mklibs & prelink both, then make sure mklibs is before prelink
# NOTE: mklibs also needs to be explicitly enabled for a given image, see local.conf.extended
USER_CLASSES ?= "buildstats image-mklibs image-prelink"
# Runtime testing of images
# The build system can test booting virtual machine images under qemu (an emulator)
# after any root filesystems are created and run tests against those images. To
# enable this uncomment this line. See classes/testimage(-auto).bbclass for
# further details.
#TEST_IMAGE = "1"
# Interactive shell configuration
# Under certain circumstances the system may need input from you and to do this it
# can launch an interactive shell. It needs to do this since the build is
# multithreaded and needs to be able to handle the case where more than one parallel
# process may require the user's attention. The default is iterate over the available
# terminal types to find one that works.
# Examples of the occasions this may happen are when resolving patches which cannot
# be applied, to use the devshell or the kernel menuconfig
# Supported values are auto, gnome, xfce, rxvt, screen, konsole (KDE 3.x only), none
# Note: currently, Konsole support only works for KDE 3.x due to the way
# newer Konsole versions behave
#OE_TERMINAL = "auto"
# By default disable interactive patch resolution (tasks will just fail instead):
PATCHRESOLVE = "noop"
# Disk Space Monitoring during the build
# Monitor the disk space during the build. If there is less that 1GB of space or less
# than 100K inodes in any key build location (TMPDIR, DL_DIR, SSTATE_DIR), gracefully
# shutdown the build. If there is less that 100MB or 1K inodes, perform a hard abort
# of the build. The reason for this is that running completely out of space can corrupt
# files and damages the build in ways which may not be easily recoverable.
BB_DISKMON_DIRS = "\
STOPTASKS,${TMPDIR},1G,100K \
STOPTASKS,${DL_DIR},1G,100K \
STOPTASKS,${SSTATE_DIR},1G,100K \
ABORT,${TMPDIR},100M,1K \
ABORT,${DL_DIR},100M,1K \
ABORT,${SSTATE_DIR},100M,1K"
# Shared-state files from other locations
# As mentioned above, shared state files are prebuilt cache data objects which can
# used to accelerate build time. This variable can be used to configure the system
# to search other mirror locations for these objects before it builds the data itself.
# This can be a filesystem directory, or a remote url such as http or ftp. These
# would contain the sstate-cache results from previous builds (possibly from other
# machines). This variable works like fetcher MIRRORS/PREMIRRORS and points to the
# cache locations to check for the shared objects.
# NOTE: if the mirror uses the same structure as SSTATE_DIR, you need to add PATH
# at the end as shown in the examples below. This will be substituted with the
# correct path within the directory structure.
#SSTATE_MIRRORS ?= "\
#file://.* http://someserver.tld/share/sstate/PATH;downloadfilename=PATH \n \
#file://.* file:///some/local/dir/sstate/PATH"
# Qemu configuration
# By default qemu will build with a builtin VNC server where graphical output can be
# seen. The two lines below enable the SDL backend too. This assumes there is a
# libsdl library available on your build system.
PACKAGECONFIG_pn-qemu-native = "sdl"
ASSUME_PROVIDED += "libsdl-native"
# CONF_VERSION is increased each time build/conf/ changes incompatibly and is used to
# track the version of this file when it was generated. This can safely be ignored if
# this doesn't mean anything to you.
CONF_VERSION = "1"
# Delete the the source/object/binary files once a package is built to preserve disk space
INHERIT += "rm_work"
# Add Toradex source mirror
INHERIT += "toradex-mirrors"
# Use this distro (filename from meta-poky/conf/distro/xx.conf)
DISTRO = "poky"
# What image type(s) are to be built?
# https://www.yoctoproject.org/docs/2.6/mega-manual/mega-manual.html#var-IMAGE_TYPES
IMAGE_FSTYPES += "tar.bz2"
# Don't generate the mirror tarball for SCM repos, the snapshot is enough
# BB_GENERATE_MIRROR_TARBALLS = "0"
PREFERRED_PROVIDER_virtual/kernel = "linux-toradex-rt"
PREFERRED_PROVIDER_psplash-support = "psplash-poky-img.h"
#PREFERRED_PROVIDER_psplash-support = "psplash-poky"
# DISTRO_FEATURES: The software support you want in your distribution for various
# features. In most cases, the presence or absence of a feature in DISTRO_FEATURES
# is translated to the appropriate option supplied to the configure script during
# the do_configure task for recipies that optionally support the feature. For example,
# specifying "x11" in DISTRO FEATURES, causes every piece of software built for the
# target that can optionally support X11 to have its X11 support enabled.
# A complete list of available options
# https://www.yoctoproject.org/docs/2.6/mega-manual/mega-manual.html#ref-features-distro
# Removes the Wayland display server protocol and libraries
# Removes the X server and libraries
DISTRO_FEATURES_remove = "wayland x11"
DISTRO_FEATURES_append = " x11vnc systemd zeroconf rng-tools"
DISTRO_FEATURES_BACKFILL_CONSIDERED = "sysvinit"
VIRTUAL-RUNTIME_init_manager = "systemd"
VIRTUAL-RUNTIME_initscripts = ""
IMX_DEFAULT_DISTRO_FEATURES_append = " systemd"
CORE_IMAGE_EXTRA_INSTALL += "dhcp-server"
TOOLCHAIN_TARGET_TASK_append = " kernel-devsrc"
# Warning: don't try to append canutils. First, it's already there. Second, it kills bitbake with a conflict in do_rootfs
IMAGE_INSTALL_append = " kernel-modules apache2 php php-cli mariadb mysql5 net-snmp-dev lrzsz dosfstools opkg ntpdate inetutils atftpd atftp nfs-utils-client postfix dpkg apt nodejs nodejs-npm tcf-agent openssh-sftp-server avahi-utils rpm dialog mysql5-client mysql5-leftovers util-linux dnf rng-tools smartmontools ruby libgpiod kernel-modules "
IMAGE_INSTALL_remove = "eglinfo-x11"
EXTRA_IMAGE_FEATURES = " \
debug-tweaks \
tools-debug \
eclipse-debug \
PACKAGECONFIG_GL_pn-qtbase = "gles2"
# This file does not need to exist, if it does it can be used to influence machine specific
# configurations without copying the machine file.
include conf/machine/include/${MACHINE}.inc
ACCEPT_FSL_EULA = "1"
