Accessing my target from Ubuntu 14.04 and 12.04 works perfectly.
Accessing Ubuntu 16.04 from my target works perfectly.
Accessing other targets with other OS from Ubuntu 16.04 works perfectly.
Unfortunately the log is not very verbose.
I assume the reason is some encryption protocol mismatch, but I’m no expert.
Log and configfiles see here.
Any help is appreciated.
Thanks for your comment! The only difference between the permanent solution in the link and your configuration is HostName and User, but this really should not make a difference… The Host and HostName value depends on how you use the ssh command. Your solution should allow to use hostname and no user name, e.g. ssh target. When just using Host 192.168.3.* and no HostName/User configuration ssh root@192.168.3.11 should really work fine too.
