as I saw this issue seams to be quite common or at least I am not the first one w/ this problem. I started with the Quickstart Guide and i stuck since days that I did not get any HDMI signal or at least no image on the monitor.
Hardware:
Apalis iMX8QP 2GB V1.1C w/ Ixora V1.2A carrier board
Installed Operating system
TorizonCore with evaluation containers
The Toradex Easy Installer was displayed on my screen but after the installation of the operating system I am unable to get anything on my monitor.
I tried two different monitors
- BA92
- Acer BA247Y
For the Acer I tried different HDMI cables and several different resolution settings by the command “setenv tdxargs video=HDMI-A-1:…x…” and saveenv
For the other screen (BA92) I tried also everything I could find in this community but no success. Boot log and fbset attached
800x600.txt (2.6 KB)
Who can help?
Best regards
Greetings @Abfuellwelt001,
There is currently an issue on our 5.7.2 image where the default graphical UI is bugged and doesn’t show up. However, this is just an issue with the UI and not the actual HDMI interface itself. Can you try running something graphical on the command line like a Weston container for example:
docker run -e ACCEPT_FSL_EULA=1 -d --rm --name=weston --net=host --cap-add CAP_SYS_TTY_CONFIG \
-v /dev:/dev -v /tmp:/tmp -v /run/udev/:/run/udev/ \
--device-cgroup-rule='c 4:* rmw' --device-cgroup-rule='c 13:* rmw' \
--device-cgroup-rule='c 199:* rmw' --device-cgroup-rule='c 226:* rmw' \
torizon/weston-vivante:$CT_TAG_WESTON_VIVANTE --developer weston-launch \
--tty=/dev/tty7 --user=torizon
Make sure no other containers are running when you execute this.
thanks a lot for this quick feedback. As I am quite new to those kind of soft- and hardware I need some more support.
How can I check that no other containers are running?
How can I run your example?
In generall I assume that this is just a quick check wheather my problem is related to the known issue of image 5.7.2. But how can I fix it?
Kind regards
Hello @Abfuellwelt001
Run docker container ls
Just run the command that @jeremias.tx wrote. It should work.
Can you also send us the output of dmesg when you connect and disconnect the HDMI monitor?
Josep
thanks a lot. After I run the command that @jeremias.tx wrote the screen showed up a window (Wayland Terminal)
Afterwards I run the dmesg command:
- output of dmesg when HDMI monitor connected
dmesg w HDMI.txt (41.4 KB)
- output of dmesg when HDMI monitor disconnected
dmesg wo HDMI.txt (41.6 KB)
I could not detect any differences.
But after a reboot the screen is gone and I am unable to see the “normal” Portainer login window. So I cannot proceed w/ the Quickstart Guide as I am not getting to the Portainer view.
Is there any permanent fix for this issue?
Well as I said the current Portainer UI is bugged so it’s not showing up. Our team is currently working on releasing a fixed version soon. You can still proceed with using TorizonCore, portainer is just a UI and not required or vital for use on TorizonCore.
Hello @Abfuellwelt001 ,
Were you able to progress with the quickstart? Do you need any further assistance on our side?
Josep
