[ 1.341033] pci 0000:07:00.0: BAR 0: assigned [mem 0x32100000-0x3211ffff]
[ 1.341067] pci 0000:07:00.0: BAR 3: assigned [mem 0x32120000-0x32123fff]
[ 1.341100] pci 0000:07:00.0: BAR 2: assigned [io 0x10000-0x1001f]
[ 1.341132] pcieport 0000:06:00.0: PCI bridge to [bus 07]
[ 1.341158] pcieport 0000:06:00.0: bridge window [io 0x10000-0x10fff]
[ 1.341187] pcieport 0000:06:00.0: bridge window [mem 0x32100000-0x321fffff]
[ 1.341317] pcieport 0000:00:00.0: BAR 8: assigned [mem 0x32200000-0x324fffff]
[ 1.341350] pcieport 0000:00:00.0: BAR 9: assigned [mem 0x12100000-0x122fffff 64bit pref]
[ 1.341383] pcieport 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 1.341414] pci 0000:01:00.0: BAR 8: assigned [mem 0x32200000-0x323fffff]
[ 1.341443] pci 0000:01:00.0: BAR 9: assigned [mem 0x12100000-0x122fffff 64bit pref]
[ 1.341474] pci 0000:01:00.0: BAR 0: assigned [mem 0x32400000-0x32403fff]
[ 1.341507] pci 0000:01:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 1.341537] pcieport 0000:02:01.0: BAR 8: assigned [mem 0x32200000-0x323fffff]
[ 1.341569] pcieport 0000:02:01.0: BAR 9: assigned [mem 0x12100000-0x122fffff 64bit pref]
[ 1.341602] pcieport 0000:02:01.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 1.341629] pcieport 0000:02:01.0: PCI bridge to [bus 03]
[ 1.341657] pcieport 0000:02:01.0: bridge window [io 0x1000-0x1fff]
[ 1.341690] pcieport 0000:02:01.0: bridge window [mem 0x32200000-0x323fffff]
[ 1.341724] pcieport 0000:02:01.0: bridge window [mem 0x12100000-0x122fffff 64bit pref]
[ 1.341765] pcieport 0000:02:02.0: PCI bridge to [bus 04]
[ 1.341810] pcieport 0000:02:03.0: PCI bridge to [bus 05]
[ 1.341855] pci 0000:01:00.0: PCI bridge to [bus 02-05]
[ 1.341881] pci 0000:01:00.0: bridge window [io 0x1000-0x1fff]
[ 1.341911] pci 0000:01:00.0: bridge window [mem 0x32200000-0x323fffff]
[ 1.341942] pci 0000:01:00.0: bridge window [mem 0x12100000-0x122fffff 64bit pref]
[ 1.341980] pcieport 0000:00:00.0: PCI bridge to [bus 01-05]
[ 1.342006] pcieport 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 1.342033] pcieport 0000:00:00.0: bridge window [mem 0x32200000-0x324fffff]
[ 1.342064] pcieport 0000:00:00.0: bridge window [mem 0x12100000-0x122fffff 64bit pref]
[ 1.344689] pwm-backlight pwm-backlight: unable to request PWM, trying legacy API
[ 1.344802] sysedp_create_consumer: unable to create pwm-backlight, no consumer_data for pwm-backlight found
[ 1.345711] tsec tsec: initialized
[ 1.347207] isp isp.0: initialized
[ 1.348216] isp isp.1: initialized
[ 1.349840] falcon vic03.0: initialized
[ 1.351063] falcon msenc: initialized
[ 1.353013] tegradc tegradc.0: probed
[ 1.353248] tegradc tegradc.0: parse cmd options for tegrafb0: 640x480-16@60
[ 1.353314] tegradc tegradc.0: switching framebuffer to 640x480
[ 1.353342] tegradc tegradc.0: Calculated sync href=0 vref=1
[ 1.353369] tegradc tegradc.0: using mode 640x480 pclk=25175000 href=0 vref=1
[ 1.386941] tegradc tegradc.0: nominal-pclk:25175000 parent:25125000 div:1.0 pclk:25125000 24923250~27440750
[ 1.404415] tegradc tegradc.0: fb registered
[ 1.405178] gpio wake4 for gpio=111
[ 1.406159] tegradc tegradc.1: probed
[ 1.407249] tegradc tegradc.1: use default mode for tegrafb1: 1920x1080-16@60
[ 1.407330] tegradc tegradc.1: switching framebuffer to 1920x1080
[ 1.407360] tegradc tegradc.1: using mode 1920x1080 pclk=148500000 href=1 vref=1
[ 1.408209] tegradc tegradc.1: nominal-pclk:148500000 parent:594000000 div:4.0 pclk:148500000 147015000~161865000
[ 1.409845] tegradc tegradc.1: switching framebuffer to 1920x1080
[ 1.409855] tegradc tegradc.1: using mode 1920x1080 pclk=148500000 href=1 vref=1
[ 1.412514] tegradc tegradc.1: nominal-pclk:148500000 parent:594000000 div:4.0 pclk:148500000 147015000~161865000
[ 1.412583] tegra_dc_hdmi_enable: HDMI clock already configured to target frequency, skipping clk setup.
[ 1.424084] Console: switching to colour frame buffer device 240x67
[ 1.435185] tegradc tegradc.1: fb registered
[ 1.435269] hdmi_state_machine_worker (tid edb855c0): state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[ 1.435402] hdmi_state_machine_set_state_l: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[ 1.438687] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[ 1.439471] Serial: 8250/16550 driver, 9 ports, IRQ sharing disabled
[ 1.441847] serial8250.0: ttyS0 at MMIO 0x70006000 (irq = 68) is a Tegra
[ 1.476904] hdmi_state_machine_worker (tid edb855c0): state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[ 1.476911] hdmi_state_machine_set_state_l: switching from state 1 (Check Plug) to state 2 (Check EDID)
[ 1.537823] hdmi_state_machine_worker (tid edb855c0): state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 1.667323] panel size 48 by 27
[ 3.909445] console [ttyS0] enabled
[ 3.909491] tegradc tegradc.1: switching framebuffer to 1920x1080
[ 3.909503] tegradc tegradc.1: using mode 1920x1080 pclk=148500000 href=1 vref=1
[ 3.909933] serial-tegra.1: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[ 3.910224] serial-tegra.2: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[ 3.910518] serial-tegra.3: ttyTHS3 at MMIO 0x70006300 (irq = 122) is a SERIAL_TEGRA
[ 3.912562] tegradc tegradc.1: nominal-pclk:148500000 parent:594000000 div:4.0 pclk:148500000 147015000~161865000
[ 3.912634] tegra_dc_hdmi_enable: HDMI clock already configured to target frequency, skipping clk setup.
[ 3.912826] tegradc tegradc.1: switching framebuffer to 1920x1080
[ 3.912836] tegradc tegradc.1: using mode 1920x1080 pclk=148500000 href=1 vref=1
[ 3.915584] tegradc tegradc.1: nominal-pclk:148500000 parent:594000000 div:4.0 pclk:148500000 147015000~161865000
[ 3.915657] tegra_dc_hdmi_enable: HDMI clock already configured to target frequency, skipping clk setup.
[ 3.916461] loop: module loaded
[ 3.916594] nct1008_nct72 4-004c: success in enabling rail vdd_nct72
[ 3.920270] gpio wake35 for gpio=70
[ 3.920360] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 3.920944] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 3.921851] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 3.923453] tegra_profiler: Branch: Dev
[ 3.923456] tegra_profiler: Version: 1.103
[ 3.923460] tegra_profiler: Samples version: 34
[ 3.923464] tegra_profiler: IO version: 18
[ 3.923470] armv7_pmu: arch: Cortex A15, type: 4, ver: 0
[ 3.923666] tegra_profiler: auth: init
[ 3.924042] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
[ 3.924531] tegra-sata tegra-sata.0: version 1.0
[ 3.924540] of_get_named_gpio_flags: can't parse gpios property
[ 3.925220] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[ 3.925232] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
[ 3.926492] scsi0 : tegra-sata
[ 3.926884] scsi1 : tegra-sata
[ 3.927108] ata1: SATA max UDMA/133 irq 55
[ 3.927111] ata2: DUMMY
[ 3.927561] tegradc tegradc.1: using mode 1920x1080 pclk=148500000 href=1 vref=1
[ 3.929173] gpio wake34 for gpio=82
[ 3.931837] tun: Universal TUN/TAP device driver, 1.6
[ 3.931840] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.932016] CAN device driver interface
[ 3.932061] Intel(R) Gigabit Ethernet Network Driver - version 5.3.5.4
[ 3.932064] Copyright (c) 2007-2015 Intel Corporation.
[ 3.932475] tegradc tegradc.1: nominal-pclk:148500000 parent:594000000 div:4.0 pclk:148500000 147015000~161865000
[ 3.978758] igb 0000:07:00.0: added PHC on eth0
[ 3.978765] igb 0000:07:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 3.978772] igb 0000:07:00.0: eth0: (PCIe:2.5GT/s:Width x1)
[ 3.978779] igb 0000:07:00.0 eth0: MAC: 00:14:2d:2e:85:85
[ 3.978795] igb 0000:07:00.0: eth0: PBA No: Unknown
[ 3.978818] igb 0000:07:00.0: LRO is disabled
[ 3.978826] igb 0000:07:00.0: Using MSI-X interrupts. 1 rx queue(s), 1 tx queue(s)
[ 3.978943] usbcore: registered new interface driver asix
[ 3.978989] usbcore: registered new interface driver ax88179_178a
[ 3.979027] usbcore: registered new interface driver cdc_ether
[ 3.979066] usbcore: registered new interface driver cdc_subset
[ 3.979097] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.979319] ehci-pci: EHCI PCI platform driver
[ 3.979595] tegra_xusb_read_usb_calib: usb_calib0 = 0x02848389
[ 3.980002] usbcore: registered new interface driver usb-storage
[ 3.980108] usbcore: registered new interface driver usbserial
[ 3.980144] usbcore: registered new interface driver usbserial_generic
[ 3.980178] usbserial: USB Serial support registered for generic
[ 3.980213] usbcore: registered new interface driver pl2303
[ 3.980243] usbserial: USB Serial support registered for pl2303
[ 3.980358] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[ 3.980500] tegra USB phy - inst[0] platform info:
[ 3.980503] port_otg: yes
[ 3.980505] has_hostpc: yes
[ 3.980508] phy_interface: USB_PHY_INTF_UTMI
[ 3.980511] op_mode: TEGRA_USB_OPMODE_DEVICE
[ 3.980513] qc2_voltage: 0
[ 3.980516] vbus_pmu_irq: 0
[ 3.980518] vbus_gpio: -1
[ 3.980521] charging: disabled
[ 3.980524] remote_wakeup: disabled
[ 3.985865] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[ 4.033034] as3722-rtc as3722-rtc.1: rtc core: registered as3722 as rtc0
[ 4.033041] as3722-rtc as3722-rtc.1: RTC interrupt 449
[ 4.104810] rtc-ds1307 0-0068: oscillator failed, set time!
[ 4.104987] rtc-ds1307 0-0068: rtc core: registered m41t0 as rtc1
[ 4.105472] tegra_rtc tegra_rtc: rtc core: registered tegra_rtc as rtc2
[ 4.105482] Wake16 for irq=34
[ 4.105502] tegra_rtc tegra_rtc: Tegra internal Real Time Clock
[ 4.105572] i2c /dev entries driver
[ 4.108968] nvavp nvavp: allocated IOVA at 8ff00000 for AVP os
[ 4.109737] tegra_dtv_probe: probing dtv.
[ 4.110159] setup_stream: bufsize = 4096, bufnum = 4
[ 4.110159] usbcore: registered new interface driver uvcvideo
[ 4.110162] USB Video Class driver (1.1.1)
[ 4.110666] zram: Created 1 device(s) ...
[ 4.111379] tegra_wdt tegra_wdt.0: last reset is due to power on reset
[ 4.111547] WDT heartbeat enabled on probe
[ 4.111550] tegra_wdt_probe done
[ 4.111880] sdhci: Secure Digital Host Controller Interface driver
[ 4.111883] sdhci: Copyright(c) Pierre Ossman
[ 4.111886] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.112234] sdhci-tegra sdhci-tegra.3: vddio_sd_slot regulator not found: -517. Assuming vddio_sd_slot is not required.
[ 4.112412] sdhci-tegra sdhci-tegra.3: Speedo value 2286
[ 4.112420] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1150
[ 4.232343] ata1: SATA link down (SStatus 0 SControl 300)
[ 4.705507] handle_check_edid_l: audio_switch 0
[ 4.712934] Display connected, hpd_switch 1
[ 4.719998] handle_check_edid_l: setting audio and infoframes
[ 4.728644] hdmi_state_machine_set_state_l: switching from state 2 (Check EDID) to state 4 (Enabled)
[ 4.740727] hdmi_state_machine_worker (tid edb855c0): state 4 (Enabled), hpd 1, pending_hpd_evt 0
[ 4.752788] mmc0: no vqmmc regulator found
[ 4.759944] mmc0: no vmmc regulator found
[ 4.766912] mmc0: Invalid maximum block size, assuming 512 bytes
[ 4.775899] sysedp_create_consumer: unable to create sdhci-tegra.3, no consumer_data for sdhci-tegra.3 found
[ 4.809325] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[ 4.823360] sdhci-tegra sdhci-tegra.0: Speedo value 2286
[ 4.831693] sdhci-tegra sdhci-tegra.0: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1150
[ 4.844401] mmc1: no vqmmc regulator found
[ 4.851583] mmc1: no vmmc regulator found
[ 4.858657] mmc1: Invalid maximum block size, assuming 512 bytes
[ 4.867782] sysedp_create_consumer: unable to create sdhci-tegra.0, no consumer_data for sdhci-tegra.0 found
[ 4.901326] mmc1: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA
[ 4.915799] sdhci-tegra sdhci-tegra.2: Speedo value 2286
[ 4.924240] sdhci-tegra sdhci-tegra.2: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1150
[ 4.936900] mmc2: no vqmmc regulator found
[ 4.944216] mmc2: no vmmc regulator found
[ 4.951425] mmc2: Invalid maximum block size, assuming 512 bytes
[ 4.960716] mmc0: BKOPS_EN bit is not set
[ 4.970624] mmc0: new high speed DDR MMC card at address 0001
[ 4.980942] mmcblk mmc0:0001: Card claimed for testing.
[ 4.989596] mmcblk0: mmc0:0001 016G30 14.6 GiB
[ 4.992329] sysedp_create_consumer: unable to create sdhci-tegra.2, no consumer_data for sdhci-tegra.2 found
[ 4.992329] mmc2: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA
[ 4.992479] gpio wake56 for gpio=170
[ 4.995862] tegra-se tegra12-se: tegra_se_probe: complete
[ 4.996063] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.996178] usbcore: registered new interface driver usbhid
[ 4.996180] usbhid: USB HID core driver
[ 4.996706] tegra-hier-ictlr tegra-hier-ictlr: probed
[ 5.069507] mmcblk0boot0: mmc0:0001 016G30 partition 1 4.00 MiB
[ 5.078895] mmcblk0boot1: mmc0:0001 016G30 partition 2 4.00 MiB
[ 5.087986] usbcore: registered new interface driver snd-usb-audio
[ 5.091492] tegra_offload_platform probe successfull.
[ 5.091496] succefully registered offload ops
[ 5.092376] tegra30_avp_audio_platform_probe successful.
[ 5.092377] sgtl5000 4-000a: sgtl5000 revision 0x11
[ 5.092632] 4-000a: 1200 mV normal
[ 5.092842] sgtl5000 4-000a: Using internal LDO instead of VDDD
[ 5.097417] tegra-snd-apalis-tk1-sgtl5000 tegra-snd-apalis-tk1-sgtl5000.0: sgtl5000 <-> tegra30-i2s.2 mapping ok
[ 5.097862] tegra-snd-apalis-tk1-sgtl5000 tegra-snd-apalis-tk1-sgtl5000.0: dit-hifi <-> tegra30-spdif mapping ok
[ 5.099835] oprofile: using timer interrupt.
[ 5.180968] GACT probability NOT on
[ 5.187888] Mirror/redirect action on
[ 5.187921] mmcblk0rpmb: mmc0:0001 016G30 partition 3 4.00 MiB
[ 5.204074] u32 classifier
[ 5.210222] Actions configured
[ 5.211080] mmcblk0: p1 p2
[ 5.212771] mmcblk0boot1: unknown partition table
[ 5.231088] Netfilter messages via NETLINK v0.30.
[ 5.232200] mmcblk0boot0: unknown partition table
[ 5.247187] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 5.257045] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 5.267342] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 5.276830] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.285629] arp_tables: (C) 2002 David S. Miller
[ 5.293608] TCP: cubic registered
[ 5.300435] NET: Registered protocol family 10
[ 5.309180] mip6: Mobile IPv6
[ 5.315436] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.324764] NET: Registered protocol family 17
[ 5.332468] NET: Registered protocol family 15
[ 5.340074] can: controller area network core (rev 20120528 abi 9)
[ 5.349949] NET: Registered protocol family 29
[ 5.357574] can: raw protocol (rev 20120528)
[ 5.365021] can: broadcast manager protocol (rev 20120528 t)
[ 5.373949] can: netlink gateway (rev 20130117) max_hops=1
[ 5.382682] NET: Registered protocol family 35
[ 5.390312] 8021q: 802.1Q VLAN Support v1.8
[ 5.397936] NET: Registered protocol family 37
[ 5.405546] Key type dns_resolver registered
[ 5.412870] NET: Registered protocol family 41
[ 5.421657] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 5.457131] Registering SWP/SWPB emulation handler
[ 5.464963] last reset is due to power on reset
[ 5.464963]
[ 5.476893] Disabling clocks left on by bootloader:
[ 5.484736] audio_2x
[ 5.490111] audio
[ 5.495164] audio4
[ 5.500256] audio3
[ 5.505306] audio2
[ 5.510296] audio1
[ 5.515267] audio0
[ 5.520276] hdmi_audio
[ 5.525542] entropy
[ 5.530523] dsi2-fixed
[ 5.535736] dsi1-fixed
[ 5.540929] mipi-cal-fixed
[ 5.546412] nor
[ 5.550893] trace
[ 5.555505] sdmmc3_ddr
[ 5.560519] sdmmc1_ddr
[ 5.565544] cclk_lp
[ 5.570251] pll_x_out0
[ 5.575191] pll_u_12M
[ 5.580036] pll_m_out1
[ 5.585026] tegra_dvfs: vdd_cpu connected to regulator
[ 5.592535] tegra_dvfs: vdd_core connected to regulator
[ 5.600117] tegra_dvfs: vdd_gpu connected to regulator
[ 5.608782] cpu_cold cooling device is registered
[ 5.615916] cpu_hot cooling device is registered
[ 5.616026] Tegra CPU DFLL is initialized with use_dfll = 1
[ 5.616081] CPU rate: 696 MHz
[ 5.777333] tegra dvfs: tegra sysfs cap interface is initialized
[ 5.785237] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[ 5.794024] tegra_actmon.emc: Completed initialization (0)
[ 5.801521] tegra_actmon.avp: Completed initialization (0)
[ 5.808879] tegra_mon.cpu_emc: Completed initialization (0)
[ 5.819024] VCC_USBH(2A|2C|2D|3|4): incomplete constraints, leaving on
[ 5.827370] VCC_USBO1: incomplete constraints, leaving on
[ 5.834636] +V1.8_VPP_FUSE: incomplete constraints, leaving on
[ 5.842344] as3722-ldo7: incomplete constraints, leaving on
[ 5.849741] VDDIO_SDMMC3: incomplete constraints, leaving on
[ 5.857273] as3722-ldo5: incomplete constraints, leaving on
[ 5.864804] VDDIO_SDMMC1: incomplete constraints, leaving on
[ 5.872321] as3722-sd3: incomplete constraints, leaving on
[ 5.879663] +V3.3_MXM: incomplete constraints, leaving on
[ 5.886910] regulator-dummy: incomplete constraints, leaving on
[ 5.895354] file system registered
[ 5.901370] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 5.910087] android_usb gadget: Number of LUNs=1
[ 5.916529] lun0: LUN: removable file: (no medium)
[ 5.923578] android_maxim14675_set_voltage: max_voltage (vbus) = 5000
[ 5.931883] android_usb gadget: android_usb ready
[ 5.938431] tegra-udc: bind to driver android_usb
[ 5.945131] of_get_named_gpio_flags exited with status 235
[ 5.945152] of_get_named_gpio_flags exited with status 117
[ 5.945198] gpio wake14 for gpio=235
[ 5.950660] _gpio_request: gpio-117 (WOL_GPIO) status -16
[ 5.950671] gpio-keys gpio-keys.3: Failed to request GPIO 117, error -16
[ 5.959278] gpio-keys: probe of gpio-keys.3 failed with error -16
[ 5.967645] as3722-rtc as3722-rtc.1: setting system clock to 2000-01-01 00:00:09 UTC (946684809)
[ 5.978983] ALSA device list:
[ 5.983639] #0: Toradex Apalis TK1 SGTL5000
[ 5.989633] #1: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 6.426550] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 268066
[ 6.426796] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 267204
[ 6.427273] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 262043
[ 6.427450] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 261996
[ 6.427546] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 261726
[ 6.427634] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 267369
[ 6.427817] EXT4-fs (mmcblk0p2): 6 orphan inodes deleted
[ 6.435279] EXT4-fs (mmcblk0p2): recovery complete
[ 6.449351] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.459629] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 6.471662] devtmpfs: mounted
[ 6.477245] Freeing unused kernel memory: 460K (c09f3000 - c0a66000)
[ 6.718813] init: plymouth-upstart-bridge main process (146) terminated with status 1
[ 6.729425] init: plymouth-upstart-bridge main process ended, respawning
[ 6.779236] init: plymouth-upstart-bridge main process (156) terminated with status 1
[ 6.789591] init: plymouth-upstart-bridge main process ended, respawning
[ 6.800820] init: ureadahead main process (149) terminated with status 5
[ 6.846915] init: plymouth-upstart-bridge main process (159) terminated with status 1
[ 6.857352] init: plymouth-upstart-bridge main process ended, respawning
[ 8.151104] init: idmapd main process (321) terminated with status 1
[ 8.151180] init: idmapd main process ended, respawning
[ 8.155611] systemd-udevd[318]: starting version 204
[ 8.561666] Tegra cpuquiet clusterswitch enabled
[ 8.654780] vi vi.0: vi_probe: ++
[ 8.657547] vi vi.0: initialized
[ 8.657811] vi vi.1: vi_probe: ++
[ 8.659423] vi vi.1: initialized
[ 8.733602] systemd-udevd[408]: renamed network interface eth0 to eth1
[ 8.868103] init: idmapd main process (444) terminated with status 1
[ 8.868129] init: idmapd main process ended, respawning
[ 8.872607] tegra-xhci tegra-xhci: Firmware File: tegra_xusb_firmware (134656 Bytes)
[ 8.872901] tegra-xhci tegra-xhci: Firmware DMA Memory: dma 0x80080000 mapped 0xf038b000 (134656 Bytes)
[ 8.873000] of_get_named_gpio_flags exited with status 222
[ 8.873038] of_get_named_gpio_flags exited with status 178
[ 8.873062] of_get_named_gpio_flags exited with status 74
[ 8.873814] tegra-xhci tegra-xhci: XUSB device id = 0xfa3 (T124+)
[ 8.883625] Bluetooth: Core ver 2.16
[ 8.883684] NET: Registered protocol family 31
[ 8.883690] Bluetooth: HCI device and connection manager initialized
[ 8.883713] Bluetooth: HCI socket layer initialized
[ 8.883724] Bluetooth: L2CAP socket layer initialized
[ 8.883754] Bluetooth: SCO socket layer initialized
[ 8.895478] apalis-tk1-k20 spi1.1: K20 FIFO Bug!
[ 8.923961] Bluetooth: RFCOMM socket layer initialized
[ 8.923971] Bluetooth: RFCOMM ver 1.11
[ 8.925425] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.925445] Bluetooth: BNEP socket layer initialized
[ 8.926402] tegra-xhci tegra-xhci: Firmware timestamp: 2014-09-16 02:10:07 UTC, Falcon state 0x20
[ 8.926466] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 8.926488] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 1
[ 8.927303] tegra-xhci tegra-xhci: irq 71, io mem 0x70090000
[ 8.927379] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.927386] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.927393] usb usb1: Product: Nvidia xHCI Host Controller
[ 8.927400] usb usb1: Manufacturer: Linux 3.10.40-2.7.5+g22e0897 tegra-xhci
[ 8.927408] usb usb1: SerialNumber: tegra-xhci
[ 8.927739] xHCI xhci_add_endpoint called for root hub
[ 8.927746] xHCI xhci_check_bandwidth called for root hub
[ 8.927843] hub 1-0:1.0: USB hub found
[ 8.927862] hub 1-0:1.0: 6 ports detected
[ 8.937335] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 8.937353] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 2
[ 8.937468] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 8.937475] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.937481] usb usb2: Product: Nvidia xHCI Host Controller
[ 8.937487] usb usb2: Manufacturer: Linux 3.10.40-2.7.5+g22e0897 tegra-xhci
[ 8.937491] usb usb2: SerialNumber: tegra-xhci
[ 8.937768] xHCI xhci_add_endpoint called for root hub
[ 8.937773] xHCI xhci_check_bandwidth called for root hub
[ 8.937855] hub 2-0:1.0: USB hub found
[ 8.937868] hub 2-0:1.0: 2 ports detected
[ 8.951334] Wake58 for irq=81
[ 8.951352] Wake40 for irq=53
[ 8.951357] Wake42 for irq=53
[ 8.951372] Wake41 for irq=129
[ 8.951377] Wake43 for irq=129
[ 9.135595] apalis-tk1-k20 spi1.1: Unsupported firmware version 0.0 and no local firmware file available.
[ 9.151682] apalis-tk1-k20: probe of spi1.1 failed with error -524
[ 9.229324] usb 1-2: new high-speed USB device number 2 using tegra-xhci
[ 9.240939] usb 1-2: New USB device found, idVendor=0424, idProduct=2514
[ 9.240947] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 9.241783] hub 1-2:1.0: USB hub found
[ 9.241938] hub 1-2:1.0: 4 ports detected
[ 9.303423] init: idmapd main process (542) terminated with status 1
[ 9.303448] init: idmapd main process ended, respawning
[ 9.501796] init: idmapd main process (568) terminated with status 1
[ 9.501820] init: idmapd main process ended, respawning
[ 9.604457] init: idmapd main process (589) terminated with status 1
[ 9.604481] init: idmapd main process ended, respawning
[ 9.689832] init: idmapd main process (603) terminated with status 1
[ 9.689856] init: idmapd main process ended, respawning
[ 9.823093] init: idmapd main process (618) terminated with status 1
[ 9.823118] init: idmapd main process ended, respawning
[ 10.018157] init: idmapd main process (650) terminated with status 1
[ 10.018181] init: idmapd main process ended, respawning
[ 10.339368] init: idmapd main process (749) terminated with status 1
[ 10.339393] init: idmapd main process ended, respawning
[ 10.497114] init: failsafe main process (699) killed by TERM signal
[ 10.621811] init: Failed to obtain startpar-bridge instance: Unknown parameter: INSTANCE
[ 10.666007] init: idmapd main process (826) terminated with status 1
[ 10.666044] init: idmapd main process ended, respawning
[ 10.806640] init: idmapd main process (857) terminated with status 1
[ 10.806667] init: idmapd respawning too fast, stopped
[ 11.098020] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 11.098028] 8021q: adding VLAN 0 to HW filter on device eth1
[ 11.381361] init: plymouth-upstart-bridge main process ended, respawning
[ 12.289208] init: plymouth-stop pre-start process (1165) terminated with status 1
[ 12.753267] igb 0000:07:00.0 eth1: igb: eth1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: None
[ 12.753429] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
