No screen output torizon
Hello support team
I’m currently experimenting with the new Torizon OS from you and I’m working through your quickstart tutorial. I arrived at Module 2 and at “Starting and Managing Containers with Portainer” you says under Step 1 that the Portainer login screen should be displayed after starting the module. But it doesn’t. Via web browser, I can access to the system as indicated in the example :8840. Before that, the Easy Installer was also displayed on the monitor. Is this correct? Did I something wrong?
Thank you very much in advance for an answer.
Greetings @JanP,
Just to clarify a few details. You list that you’re using Torizon 1.5.0 I assume you mean 5.1.0 correct? Also you didn’t mention this explicitly but I assume you’re using an HDMI display?
Finally is there any details about your display you could share like model, resolution, or any other special details?
Also can you SSH/serial into the device? If yes do you notice any boot logs or messages that concern the display you are using?
Here is the boot log:
Commercial temperature grade DDR3 timings.
Trying to boot from MMC1
U-Boot 2020.07-5.1.0+git.f34eb0c0ac97 (Jan 01 1970 - 00:00:00 +0000)
CPU:   Freescale i.MX6Q rev1.6 996 MHz (running at 792 MHz)
CPU:   Extended Commercial temperature grade (-20C to 105C) at 21C
Reset cause: POR
DRAM:  1 GiB
PMIC:  device id: 0x10, revision id: 0x21, programmed
MMC:   FSL_SDHC: 1, FSL_SDHC: 2, FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
Model: Toradex Apalis iMX6 Quad 1GB V1.1B, Serial# 10685321
Net:   eth0: ethernet@2188000
MMC: no card present
switch to partitions #0, OK
Scanning mmc 0:1...
Found U-Boot script /boot.scr
1007 bytes read in 11 ms (88.9 KiB/s)
## Executing script at 17000000
3835 bytes read in 22 ms (169.9 KiB/s)
69456 bytes read in 30 ms (2.2 MiB/s)
141 bytes read in 25 ms (4.9 KiB/s)
Applying Overlay: apalis-imx6_parallel-rgb_overlay.dtbo
766 bytes read in 32 ms (22.5 KiB/s)
Applying Overlay: display-edt7_overlay.dtbo
803 bytes read in 31 ms (24.4 KiB/s)
Applying Overlay: apalis-imx6_stmpe-ts_overlay.dtbo
402 bytes read in 30 ms (12.7 KiB/s)
Applying Overlay: apalis-imx6_hdmi_overlay.dtbo
398 bytes read in 29 ms (12.7 KiB/s)
8430080 bytes read in 250 ms (32.2 MiB/s)
8045022 bytes read in 238 ms (32.2 MiB/s)
## Flattened Device Tree blob at 12100000
   Booting using the fdt blob at 0x12100000
   Loading Ramdisk to 2f853000, end 2ffff1de ... OK
   Loading Device Tree to 2f81f000, end 2f852fff ... OK
Starting kernel ...
[    2.600671] rtc-ds1307 0-0068: hctosys: unable to read the hardware clock
Starting version 244.3+
Torizoncore Upstream 5.1.0+build.1 apalis-imx6-10685321 ttymxc0
@jeremias.tx
I didn´t see that you allready answered. I try that what you wrote. Thanks a lot.
Ahh okay I believe I understand now. So on the Apalis modules the default interface is HDMI, meaning VGA is disabled by default.
Though you should be able to easily enable this with a device tree overlay please see here on how to do this: Device Tree Overlays on Torizon | Toradex Developer Center
Thanks for quick answer @jeremias.tx,
I´m sorry. Of cause I´m using 5.1.0 from Torizon and no I don´t use HDMI. I use the VGA output of Evaluation Board. Its connected to a nomal lcd monitor with full hd resolution 1980x1080.
Parallel I will look to the boot log an share it here.
Hi @JanP
Is the issue solved?
