I am working on M4 core in colibri imx8x. the issue which i am facing is external interrupt is not working when Rpmsg is running. I have tried these two peripherals seperate and it was working.
Any interrups are used for Rpmsg.?
If used is that is making clash with externel interrupt.?
Ouseppachan CR
Hi @Ouseppachan,
What two peripherals are you refering to?
Please note that the demos/SDK are provided by NXP
Hi @sahil.tx ,
I am using Lpspi and external interupt and Rpmsg. for both external interupt and Lpspi i have enabled IRQSTEER.
Pins am using are,
externel interupt - LSIO_GPIO0_PIN_30
SPI pins - SC_P_SPI2_SCK, SC_P_SPI2_SDI , SC_P_SPI2_SDO.
In case of Rpmsg from SDK example only i took code.
Can is access shared memory in colibri imx8x board for communicating with linux and M4 core. If yes from what addres i need to use.
Hi @Ouseppachan ,
You can use RpMsg for communication between M4 and linux.
The demos are already provided by NXP inside the SDK.
Hy,
Solved this issue a decade before. thanks for the reply..
Thanks for updating and sorry for the delay as we are not actively providing support for MCU.
