I tried the “Getting Started”-Guide with my Apalis board. When I run the command
ifconfig
there ist no ipv4 adress for USB0.
eth0 Link encap:Ethernet HWaddr 00:14:2D:4F:65:4C
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1%1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:2490 errors:0 dropped:0 overruns:0 frame:0
TX packets:2490 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:179500 (175.2 KiB) TX bytes:179500 (175.2 KiB)
usb0 Link encap:Ethernet HWaddr 00:14:2D:FF:FF:FF
inet6 addr: fe80::214:2dff:feff:ffff%lo/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:139 errors:0 dropped:0 overruns:0 frame:0
TX packets:51 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:25113 (24.5 KiB) TX bytes:13722 (13.4 KiB)
When I try to set a static ip and run the savecopy from host, i only recognize that host is working, but nothing is printed out on console. What can I do?
