Dear Toradex,
I cannot get working the DVI-D output on EvalBoard V1.0A/V1.1A. Previously I had WEC7 installed on the board and the DVI-D was working well. Then I wanted to try Linux distibution LXDE 2.8.b1 but there is no DVI-D output. As I understood it well, the DVI-D should be working by default. On the board I am connected to connector X11 (which is the DVI-D) and also double checked the pin settings (X39 and X40 switched to DVI). It looks like there is something else I overlooked.
Here is the console listing
U-Boot 2016.11-2.8.1+g30a1208 (Dec 28 2017 - 22:16:36 +0000)
TEGRA30
DRAM: 1 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1, Tegra SD/MMC: 2
In: serial
Out: vidconsole
Err: vidconsole
MISSING TORADEX CONFIG BLOCK
Model: Toradex Apalis T30 1GB
Net: No ethernet found.
Thank you
With regards
Vlastimil
