I changed config block to disable the splash screen.
However, the screen also doesn’t display anything after booting the OS image when ss.enable = 0.
This used to be a known issue which was fixed in BSP V1.1b2, but reappeared in V1.1b4.
We will reopen this ticket. Meanwhile there are two possible workarounds:
In the WEC7 registry, configure the following registry value:
[HKLM\Drivers\Display\Colibri]
UseSplashSettings = 0
If you didn’t do it yet, you also need to configure display resolution and timings in the registry.
set ss.dbginfo 0 , save ss
