When I run nmcli device wifi list
on my module nothing gets listed. I am using a verdin imx8mp SoM on a development board, with a custom OS built using the following tcbuild.yaml:
# >> The input section specifies the image to be taken as the base for the customization.
input:
easy-installer:
local: ./static/torizon-base-images/torizon-core-docker-verdin-imx8mp-Tezi_5.7.2+build.20.tar
# >> The customization section defines the modifications to be applied to get the desired output image.
customization:
splash-screen: static/splashscreen/RadiaSoftLogo_1200x234.png
device-tree:
# >> Directories where to look for include files.
include-dirs:
- static/device-trees/include
# >> Custom device tree source:
custom: static/device-trees/dts-arm64/imx8mp-verdin-wifi-dev.dts
# >> Device-tree overlays configuration:
overlays:
# >> Whether to ignore all overlays from the base image (or ostree archive in the future).
clear: true
# >> Overlays to add to output image.
add:
- static/device-trees/overlays/touch-atmel-mxt_overlay.dts
- static/device-trees/overlays/verdin-imx8mp_sn65dsi84-lt170410_overlay.dts
- static/device-trees/overlays/verdin-imx8mp_sn65dsi84_overlay.dts
# >> The output section defines properties of the output image.
output:
easy-installer:
local: 5.7.2.CUSTOM
bundle:
dir: bundle/
I believe I’m using the right .dts and I didn’t see any missing overlays that seem wifi related. I don’t think the module is damaged because I’ve been able to connect the SoM to wifi last week, and I can’t think if a way my container bundle would cause an issue. Any ideas?
