Dear Community,
I’m facing an issue with NFS setting, my custom board does not boot over NFS.
I’ve followed the steps described in “Developper section” to install and configure tftp-hpa and nfs-kernel-server on my host machine.
The TFTP works fine, I’m able to load uImage and device tree with tftp command in u-boot prompt.
The NFS works fine, I’m able to mount the shared rootfs on embedded target through network (read/write is also ok).
But, when I want to achieve the final step i.e boot over NFS, the boot session stucks at the same point:
Apalis iMX6 # run nfsboot
Booting via DHCP/TFTP/NFS...
Using FEC device
TFTP from server 192.168.3.4; our IP address is 192.168.3.102
Filename 'test.dtb'.
Load address: 0x12000000
Loading: ################################################## 45 KiB
2.1 MiB/s
done
Bytes transferred = 46122 (b42a hex)
Using FEC device
Filename 'uImage'.
Load address: 0x11000000
Loading: ################################################## 4.1 MiB
6.5 MiB/s
done
Bytes transferred = 4327224 (420738 hex)
## Booting kernel from Legacy Image at 11000000 ...
Image Name: Linux-3.14.28-v2.6b1+g0bb38d1
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4327160 Bytes = 4.1 MiB
Load Address: 10008000
Entry Point: 10008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 12000000
Booting using the fdt blob at 0x12000000
Loading Kernel Image ... OK
Using Device Tree in place at 12000000, end 1200e429
Starting kernel ...
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.14.28-v2.6b1+g0bb38d1 (vincent@VM) (gcc version 5.2.0 (GCC) ) #2 SMP Thu Feb 13 02:35:21 CET 2020
[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Toradex Apalis iMX6Q/D Module on XX
[ 0.000000] cma: CMA: reserved 320 MiB at 3c000000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] PERCPU: Embedded 8 pages/cpu @ab713000 s8512 r8192 d16064 u32768
[ 0.000000] Kernel command line: enable_wait_mode=off vmalloc=400M nfsrootdebug root=/dev/nfs rw ip=192.168.3.102:192.168.3.4:192.168.3.4:255.255.255.0::eth0 nfsroot=192.168.3.4:/srv/screeni fec_mac=00:14:2d:00:00:00 consoleblank=0 no_console_suspend=1 console=tty1 console=ttymxc0,115200n8 vt.global_cursor_default=0 video=mxcfb0:dev=ldb,if=LVDS888 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=32M
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xc0800000 - 0xff000000 (1000 MB)
[ 0.000000] lowmem : 0x80000000 - 0xc0000000 (1024 MB)
[ 0.000000] pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
[ 0.000000] modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
[ 0.000000] .text : 0x80008000 - 0x80733fcc (7344 kB)
[ 0.000000] .init : 0x80734000 - 0x8077b140 ( 285 kB)
[ 0.000000] .data : 0x8077c000 - 0x807b62c0 ( 233 kB)
[ 0.000000] .bss : 0x807b62c8 - 0x80819f28 ( 400 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] L310 cache controller enabled
[ 0.000000] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32470000, Cache size: 1024 kB
[ 0.000000] Switching to timer-based delay loop
[ 0.000007] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
[ 0.000797] Console: colour dummy device 80x30
[ 0.001153] console [tty1] enabled
[ 0.001177] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[ 0.001205] pid_max: default: 32768 minimum: 301
[ 0.001377] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001399] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.009199] Initializing cgroup subsys debug
[ 0.009224] Initializing cgroup subsys freezer
[ 0.009260] CPU: Testing write buffer coherency: ok
[ 0.009563] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.009643] Setting up static identity map for 0x1057fac0 - 0x1057fb18
[ 0.011257] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.012060] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.012848] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.012950] Brought up 4 CPUs
[ 0.013011] SMP: Total of 4 processors activated.
[ 0.013025] CPU: All CPU(s) started in SVC mode.
[ 0.013616] devtmpfs: initialized
[ 0.017320] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.017663] pinctrl core: initialized pinctrl subsystem
[ 0.017984] regulator-dummy: no parameters
[ 0.047514] NET: Registered protocol family 16
[ 0.055927] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.056516] cpuidle: using governor ladder
[ 0.056535] cpuidle: using governor menu
[ 0.056750] CPU identified as i.MX6Q, unknown revision
[ 0.056848] Use WDOG1 as reset source
[ 0.064923] syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
[ 0.065251] vdd1p1: 800 <--> 1375 mV at 1100 mV
[ 0.065615] vdd3p0: 2800 <--> 3150 mV at 3000 mV
[ 0.065963] vdd2p5: 2000 <--> 2750 mV at 2400 mV
[ 0.066330] vddarm: 725 <--> 1450 mV at 1150 mV
[ 0.070485] vddpu: 725 <--> 1450 mV at 1150 mV
[ 0.070862] vddsoc: 725 <--> 1450 mV at 1175 mV
[ 0.072786] syscon 20e0000.iomuxc-gpr: regmap [mem 0x020e0000-0x020e0037] registered
[ 0.075526] syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
[ 0.079833] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.079860] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.080362] imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.087202] bio: create slab <bio-0> at 0
[ 0.087981] 1P8V: 1800 mV
[ 0.088194] 2P5V: 2500 mV
[ 0.088411] 3P3V: 3300 mV
[ 0.088718] usb_otg_vbus: 5000 mV
[ 0.088989] usb_host_vbus_hub: 5000 mV
[ 0.089299] usb_host_vbus: 5000 mV
[ 0.089364] usb_host_vbus: supplied by usb_host_vbus_hub
[ 0.089821] SCSI subsystem initialized
[ 0.090092] usbcore: registered new interface driver usbfs
[ 0.090172] usbcore: registered new interface driver hub
[ 0.090284] usbcore: registered new device driver usb
[ 0.090755] i2c-gpio i2c.16: using pins 80 (SDA) and 62 (SCL)
[ 0.091293] i2c i2c-1: IMX I2C adapter registered
[ 0.093376] stmpe-i2c 2-0041: stmpe811 detected, chip id: 0x811
[ 0.095589] i2c i2c-2: IMX I2C adapter registered
[ 0.096159] i2c i2c-3: IMX I2C adapter registered
[ 0.096303] Linux video capture interface: v2.00
[ 0.096366] pps_core: LinuxPPS API ver. 1 registered
[ 0.096382] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.096417] PTP clock support registered
[ 0.110522] imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[ 0.130520] imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[ 0.131896] Switched to clocksource mxc_timer1
[ 0.141502] NET: Registered protocol family 2
[ 0.142340] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.142435] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.142568] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.142641] TCP: reno registered
[ 0.142664] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.142724] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.143003] NET: Registered protocol family 1
[ 0.143280] RPC: Registered named UNIX socket transport module.
[ 0.143301] RPC: Registered udp transport module.
[ 0.143316] RPC: Registered tcp transport module.
[ 0.143329] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.143865] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
[ 0.144858] imx6_busfreq busfreq.14: DDR medium rate not supported.
[ 0.145343] Bus freq driver module loaded
[ 0.146233] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.153183] VFS: Disk quotas dquot_6.5.2
[ 0.155072] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.155784] NFS: Registering the id_resolver key type
[ 0.155852] Key type id_resolver registered
[ 0.155870] Key type id_legacy registered
[ 0.156507] fuse init (API version 7.22)
[ 0.157047] msgmni has been set to 2012
[ 0.159981] io scheduler noop registered
[ 0.160005] io scheduler deadline registered
[ 0.160183] io scheduler cfq registered (default)
[ 0.161390] backlight.15 supply power not found, using dummy regulator
[ 0.162805] MIPI DSI driver module loaded
[ 0.163297] mxc_sdc_fb fb.17: registered mxc display driver ldb
[ 0.181964] mxc_sdc_fb fb.17: 1280x800 h_sync,r,l: 40,64,64 v_sync,l,u: 6,5,5 pixclock=68932000 Hz
[ 0.201963] imx-ipuv3 2800000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
[ 0.251966] mxc_sdc_fb fb.17: 1280x800 h_sync,r,l: 40,64,64 v_sync,l,u: 6,5,5 pixclock=68932000 Hz
[ 0.281165] Console: switching to colour frame buffer device 160x50
[ 0.316399] imx-sdma 20ec000.sdma: no iram assigned, using external mem
[ 0.316722] imx-sdma 20ec000.sdma: no event needs to be remapped
[ 0.316991] imx-sdma 20ec000.sdma: loaded firmware 3.1
[ 0.319805] imx-sdma 20ec000.sdma: initialized
[ 0.321408] pfuze100-regulator 2-0008: Full layer: 2, Metal layer: 1
[ 0.322113] pfuze100-regulator 2-0008: FAB: 0, FIN: 0
[ 0.322197] pfuze100-regulator 2-0008: pfuze100 found.
[ 0.323716] SW1AB: 300 <--> 1875 mV at 1375 mV
[ 0.325138] SW1C: 300 <--> 1875 mV at 1375 mV
[ 0.325972] SW2: at 1000 mV
[ 0.326772] SW3A: 400 <--> 1975 mV at 1500 mV
[ 0.327598] SW3B: at 1500 mV
[ 0.328407] SW4: at 1000 mV
[ 0.329206] SWBST: 5000 <--> 5150 mV at 5000 mV
[ 0.330036] VSNVS: 1000 <--> 3000 mV at 3000 mV
[ 0.330291] VREFDDR: 750 mV
[ 0.331080] VGEN1: 800 <--> 1550 mV at 1500 mV
[ 0.331917] VGEN2: 800 <--> 1550 mV at 1500 mV
[ 0.332731] VGEN3: 1800 <--> 3300 mV at 3000 mV
[ 0.336474] VGEN4: 1800 <--> 3300 mV at 1800 mV
[ 0.340160] VGEN5: 1800 <--> 3300 mV at 2500 mV
[ 0.343788] VGEN6: 1800 <--> 3300 mV at 2800 mV
[ 0.346953] Serial: IMX driver
[ 0.350103] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58, base_baud = 5000000) is a IMX
[ 1.197174] console [ttymxc0] enabled
[ 1.204583] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 61, base_baud = 5000000) is a IMX
[ 1.216682] serial: Freescale lpuart driver
[ 1.224311] imx sema4 driver is registered.
[ 1.231503] [drm] Initialized drm 1.1.0 20060810
[ 1.239439] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[ 1.255696] brd: module loaded
[ 1.265600] loop: module loaded
[ 1.272143] altera_ps altera-ps.28: ALTERA Passive Serial interface driver
[ 1.283425] imx6q-pinctrl 20e0000.iomuxc: pin MX6Q_PAD_EIM_D24 already requested by 2020000.serial; cannot claim for 2008000.ecspi
[ 1.298268] imx6q-pinctrl 20e0000.iomuxc: pin-45 (2008000.ecspi) status -22
[ 1.308325] imx6q-pinctrl 20e0000.iomuxc: could not request pin 45 (MX6Q_PAD_EIM_D24) from group spi_csfpga on device 20e0000.iomuxc
[ 1.323548] spi_imx 2008000.ecspi: Error applying setting, reverse things back
[ 1.335653] spi_imx 2008000.ecspi: probed
[ 1.344330] 2188000.ethernet supply phy not found, using dummy regulator
[ 1.372259] pps pps0: new PPS source ptp0
[ 1.380515] libphy: fec_enet_mii_bus: probed
[ 1.389565] fec 2188000.ethernet eth0: registered PHC device 0
[ 1.398922] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.408886] usbcore: registered new interface driver usb-storage
[ 1.418991] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.433497] ci_hdrc ci_hdrc.0: doesn't support gadget
[ 1.441870] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.450019] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 1.471929] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.481256] hub 1-0:1.0: USB hub found
[ 1.488198] hub 1-0:1.0: 1 port detected
[ 1.498976] ci_hdrc ci_hdrc.1: doesn't support gadget
[ 1.509309] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 1.517348] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 1.541925] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 1.551146] hub 2-0:1.0: USB hub found
[ 1.558112] hub 2-0:1.0: 1 port detected
[ 1.574542] input: stmpe-ts as /devices/soc0/soc.0/2100000.aips-bus/21a4000.i2c/i2c-2/2-0041/stmpe-ts/input/input0
[ 1.588717] check_alarm_past: alarm in the past
[ 1.596879] snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
[ 1.608679] i2c /dev entries driver
[ 1.617082] mxc_v4l2_output v4l2_out.25: V4L2 device registered as video16
[ 1.627652] mxc_v4l2_output v4l2_out.25: V4L2 device registered as video17
[ 1.670854] sbs-battery 3-000b: sbs-battery: battery gas gauge device registered
[ 1.682598] imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
[ 1.694730] sdhci: Secure Digital Host Controller Interface driver
[ 1.704541] sdhci: Copyright(c) Pierre Ossman
[ 1.712534] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.723901] mmc1: no vqmmc regulator found
[ 1.771921] mmc1: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[ 1.784520] mmc2: no vqmmc regulator found
[ 1.811960] usb 1-1: new full-speed USB device number 2 using ci_hdrc
[ 1.831927] mmc2: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[ 1.843529] mmc0: no vqmmc regulator found
[ 1.891924] mmc0: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
[ 1.903479] mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
[ 1.916946] mxc_vpu 2040000.vpu: VPU initialized
[ 1.925672] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.935132] usbcore: registered new interface driver usbhid
[ 1.944582] usbhid: USB HID core driver
[ 1.952479] TCP: cubic registered
[ 1.960198] NET: Registered protocol family 10
[ 1.969458] sit: IPv6 over IPv4 tunneling driver
[ 1.978477] NET: Registered protocol family 17
[ 1.986722] Key type dns_resolver registered
[ 1.996111] Registering SWP/SWPB emulation handler
[ 2.005269] SW4: disabling
[ 2.011503] SW3B: disabling
[ 2.019519] SW2: disabling
[ 2.019829] input: eGalax Inc. eGalaxTouch EXC7200-786Bv1.000 as /devices/soc0/soc.0/2100000.aips-bus/2184000.usb/ci_hdrc.0/usb1/1-1/1-1:1.0/0003:0EEF:7200.0001/input/input1
[ 2.020145] input: eGalax Inc. eGalaxTouch EXC7200-786Bv1.000 Pen as /devices/soc0/soc.0/2100000.aips-bus/2184000.usb/ci_hdrc.0/usb1/1-1/1-1:1.0/0003:0EEF:7200.0001/input/input2
[ 2.020521] hid-multitouch 0003:0EEF:7200.0001: input,hiddev0,hidraw0: USB HID v2.10 Pointer [eGalax Inc. eGalaxTouch EXC7200-786Bv1.000 ] on usb-ci_hdrc.0-1/input0
[ 2.093729] regulator-dummy: disabling
[ 2.102917] imx mcc test is registered.
[ 2.113603] input: gpio-keys.27 as /devices/soc0/gpio-keys.27/input/input4
[ 2.127976] snvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 2020-03-12 19:38:33 UTC (1584041913)
[ 2.141966] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[ 2.241779] fec 2188000.ethernet eth0: Freescale FEC PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=2188000.ethernet:07, irq=190)
[ 2.260130] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 2.313053] hub 2-1:1.0: USB hub found
[ 2.320409] hub 2-1:1.0: 4 ports detected
[ 2.327126] mmc0: BKOPS_EN bit is not set
[ 2.342499] mmc0: new high speed DDR MMC card at address 0001
[ 2.352172] mmcblk0: mmc0:0001 Q2J54A 3.64 GiB
[ 2.360290] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 2.00 MiB
[ 2.369825] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 2.00 MiB
[ 2.380439] mmcblk0: p1 p2
[ 2.388842] mmcblk0boot1: unknown partition table
[ 2.398989] mmcblk0boot0: unknown partition table
[ 12.261972] Waiting up to 110 more seconds for network.
[ 22.271972] Waiting up to 100 more seconds for network.
[ 26.187331] libphy: 2188000.ethernet:07 - Link is Up - 100/Full
[ 26.201996] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 26.222337] IP-Config: Complete:
[ 26.233568] device=eth0, hwaddr=00:14:2d:00:00:00, ipaddr=192.168.3.102, mask=255.255.255.0, gw=192.168.3.4
[ 26.251958] host=192.168.3.102, domain=, nis-domain=(none)
[ 26.261133] bootserver=192.168.3.4, rootserver=192.168.3.4, rootpath=
From here, if I wait a couple of seconds, the kernel panic raises.
I suppose that there is a misconfiguration somewhere cause the elements work fine independently.
BR
Vincentt
EDIT: same result with apalis-imx6_console-image-tezi_3.0b4.254-20200421 BSP, stucked at :
[ 6.263080] IP-Config: Complete:
[ 6.270203] device=eth0, hwaddr=00:14:2d:00:00:00, ipaddr=192.168.3.102, mask=255.255.255.0, gw=192.168.3.4
[ 6.284444] host=192.168.3.102, domain=, nis-domain=(none)
[ 6.294398] bootserver=192.168.3.4, rootserver=192.168.3.4, rootpath=
[ 6.305907] ALSA device list:
[ 6.312035] #0: imx6q-apalis-sgtl5000
