Yes, standard images (1.2 and 1.3b) boot on this same module.
I also updated to bootloader 1.3b
Platformbuilder was installed 3 weeks ago so I assume it is nearly the same as in 1.3b
I have built now debug image and now I get the following output during boot:
Toradex Bootloader 1.3b2 Built on Sep 19 2017 13:29:17
Splash screen is enabled.
SPL enabled version.
Using 16MB of IPU memory and 80MB of GPU memory.
Board: Apalis iMX6 Quad 2GB IT
CPU is running at 792MHz.
Using eMMC boot partition (size: 32768 sectors).
Initializing L2 Cache.
Press [SPACE] to enter Bootloader Menu
System ready!
Preparing for download…
Loading uncompressed image…
Reading image size from sector 303105
Loading 89894920 bytes to RAM
Done.
Launching image at 10200000.
Toradex Windows CE 7.0 1.3b2
SMP support enabled
Detected 4 CPUs
Waiting for 4 CPUs
CPU0 is started
CPU1 is started
CPU2 is started
CPU3 is started
MP Detected, # of CPUs = 00000004
NKStartup done, starting up kernel. nCpus = 4
Windows CE KernelInit
Error Reporting Memory Reserved, dump size = 00100000
Booting Windows CE version 7.00 for (ARM)
Memory Configuring: Total pages: 431857, Filesystem pages = 32751
Booting kernel with clean memory configuration:
Total Memory Sections:8
[0] (static): start: 8580b000, extension/attributes: 00012000, length: 046f1000
[1] (dynamic): start: 001b0000, extension/attributes: 00040800, length: 10000000
[2] (dynamic): start: 002b0000, extension/attributes: 00040800, length: 10000000
[3] (dynamic): start: 003b0000, extension/attributes: 00040800, length: 10000000
[4] (dynamic): start: 004b0000, extension/attributes: 00040800, length: 10000000
[5] (dynamic): start: 005b0000, extension/attributes: 00040800, length: 10000000
[6] (dynamic): start: 006b0000, extension/attributes: 00040800, length: 10000000
[7] (dynamic): start: 007b0000, extension/attributes: 00014800, length: 05000000
Scheduling the first thread.
PGPOOL: Reserved 768 pages for Loader pool
PGPOOL: Reserved 256 pages for File pool
OSAXST0: Platform Name = Apalis iMX6 Quad 2GB IT
Message Queue support initialized, g_hMsgQHeap = b38a0010
Resuming all CPUs, g_pKData->nCpus = 4
CPU 4 started, ready to reschedule, ppcb = fffdd800
CPU 2 started, ready to reschedule, ppcb = fffd9800
CPU 3 started, ready to reschedule, ppcb = fffdb800
All CPUs resumed, g_nCpuReady = 4
ERROR: VMCopy - Failed, dwErr = 00000057
Exception ‘Data Abort’ (0x4): Thread-Id=00520002(pth=af80299c), Proc-Id=00400002(pprc=857e7ad0) ‘NK.EXE’, VM-active=00400002(pprc=857e7ad0) ‘NK.EXE’
PC=eff0433c(k.coredll.dll+0x000d433c) RA=efd28830(filesys.dll+0x00028830) SP=b38dfd90, BVA=b38f1000
RtlDispatchException: returning failure. Flags=0
Unhandled exception c0000005:
Secondary thread in proc 00400002 faulted, Exception code = c0000005, Exception Address = eff0433c!
Terminating thread af80299c
