kyas
1
I have a WEC7 of Colibri iMX6.
I have developed an application using .NET CF.
However, it can not be a text file read / write of the Shift-JIS.
Dim enc As System.Text.Encoding = System.Text.Encoding.GetEncoding("Shift_JIS")
PlatformNotSupportedException occurs.
Please tell me if there is a better way.
Did you already try to install the additional fonts? You find some ressources and a how to on this Toradex Developer website.
kyas
3
Thank you to answer my question.
Yes. Additional fonts are installed. Registry is also configured. However, the application will output the exception. (PlatformNotSupportedException)
Is this, probably because does not contain a Japanese environment to WEC7 OS image?
