.NET CF 3.5 Messages cab error not a valid WEC Setup file
I downloaded the * NETCFv35.Messages.EN.wm.cab installer from here to allow “to convert error numbers to readable string messages” as suggested.
I used it on a different project on VF61 CE6 and it just went as expected, now I’m trying to install it on a T20 WEC7 and I get the message “The file is not a valid Windows Embedded Compact Setup file”, preventing me to actually install it.
Any clues?
Also, do I really need it? I had a few chances already to make my testing application fail in doing an HTTPS request and I was able to clearly see the stack frame of the exception. Maybe is not needed on WEC7?
Thank you
Colibri T20 256MB IT v1.2A
Custom Board
WEC7 BSP 2.1
The particular CAB file is designed to be used for WinCE4-WinCE5. If you are satisfied with the verbosity level of error messages on WinCE7, there is no need to install that CAB file
Here is another version of this cab file I found in my PC:
ToradexNETCFv35.Messages.EN.cab (800.6 KB)
I do not know from where it comes from or what it does, so whoever is reading, take it with a pinch of salt.
I found it asI was now experiencing the same issue on another project running on VF61 CE6, and I knew I had it somewhere cause it did work for me in the past.
So now I found it, and it does install smoothly also on my T20 CE7, and show proper exception messages now.
Hope it helps.
